Dsl internet connection sharing
I have made the 3 computer with one wired and 2 wireless connection network .now i am new here with woking with this router .i have adsl line but i cant connect dsl on all 3 computers .what setting should i have't given or what i am doing wrong plz help me ..I AM USING LINKSYS WIRELESS-N ADSL 2 + GATEWAY
  • 49 Answers
Did you run the set up cd? If so, then try to do powercycle. Reboot everything. if your wired connection works then access the set up page by typing 192.168.1.1 on the address bar of the PC that is already online. Leave username blank, "admin"  (lowercase letters is your password). Click status, if you already have an ip address and Dns then you are good to go. If you dont have then do a mac clone under "set up" then check the password for wireless connection under wireless security. you can use that to log on to the wireless netowrk on your two pcs.
if all of these seems to be confusing, you can call. 18003267114 for manual help.
Posted on Oct 25, 2007
    Brigadier General:
  • 6,966 Answers
If you are using a LinkSys WRT300N, you may have to:
1. Connect a single PC direct to your modem via a LAN cable;
2. Make sure that you can go online & have internet access on that PC;
3. Insert the CD that came with the WRT300N;
4. Follow the on screen instructions carefully;
5. It will instruct you then when to disconnect the modem and how  to connect the LinkSys;
6. You may likewise have to check that the PC is set to auto Obtain IP settings/configuration. Alternatley, you may also use static IP address for the first PC; 192.168.1.2; 255.255.255.0; 192.168.1.1;
7. Connect the two other PCs;
8. For a wireless connection, try first without any security settings (no WEP, WPA or MAC filter).
Hope this be of some idea/help. Pls post back how things turnes up or should you need further information.
Good luck and kind regards.
Posted on Oct 21, 2007
SOURCE:
How to conect with wireless internet
The Network and Sharing Center in Microsoft* Windows Vista* can be used to set up a secure wireless connection to the Internet.
Note: If an Internet connection is not automatically made by the operating system, you may need to contact your access point (AP), broadband wireless router manufacturer, or Internet Service Provider (ISP).
Set Up a Secure Wireless Connection to the Internet
These steps assume that your network adapter; AP or router; and cable, DSL or another type of modem have already been physically connected and configured. They allow you to create a new connection and configure it accordingly.
Follow these steps to set up a secure wireless connection to the Internet.
Note: If a wireless profile does not exist, you will need to create a secure wireless profile before you can set up a wireless connection to the Internet.
1. Access the Network and Sharing Center.
2. Select Set up a connection or network.
3. Click Connect to the Internet.
4. Click Next.
5. Select Wireless. At this point, if the network(s) that are listed say that the network settings do not match the network requirements, as shown in Figure 1, create a secure wireless profile and then follow the steps again.
6. Select a network and click Connect. If you are not connected to the Internet, you may need to contact your AP/router manufacturer or ISP.
To access the Network and Sharing Center, use one of the following methods:
  • Start » Control Panel » Network and Internet » Network and Sharing Center
  • Start » Network » Network and Sharing Center
  • Right-click the network system tray icon (the icon that displays two computer monitors) » Network and Sharing Center
Jan 21, 2011 | Computers & Internet
Tip
Share Your Internet Connection with More Than One Computer- The Easy Way
Here is a simple way share your home internet connection with more than one computer. This will work for both wired and wireless and doesn't require alot of technical or computer skills to accomplish. I'm sure there are other ways, but if you're looking for a simple repeatable setup, here it is.
If you've got a dsl connection through a dsl modem, this TIP will work for you.
If you've got a cable modem, this TIP will work just as well.
Here's a list of what you'll need.
  1. Dsl or cable modem that works on your system and you can access internet with one computer (If you're using the internet, most likely you've got this already).
  2. Wired (Ethernet) or Wireless Router (wifi routers have 4-6 ethernet ports also).
  3. For Wired: Ethernet cable to connect modem to router.
  4. For Wireless: Wifi compatible computer or wifi card for your computer (follow manufacturer's instructions for proper install).
Procedure:
  1. Turn all components off. This includes anything on your existing network- computer, modem, printer and any router you may currently be using.
  2. With all power off, connect an ethernet cable between your modem and your new cable/dsl router(wired or wireless).
  3. Turn on the power to your new router only and let it boot up completely.
  4. Turn on the dsl/cable modem and allow it to boot. Since the router was booted first, the modem with recognize the router's MAC address (ethernet numerical address) and connect that address to the internet.
  5. Connect all the other components onto the router with the ethernet cables as needed and turn on the components- no particular order is necessary after the router and modem are booted. Your router will assign MAC addresses to all the ethernet components. Once the MAC address is assigned, your computer should work correctly with the internet and shouldn't drop out when the second computer is turned on.
  6. For wireless connections, boot up your computer with the properly installed Wifi card, airport card and allow it to "find" your router. Once you get confirmation of the signal, you're good to go.
Following this procedure will allow your modem, your router to use their designed software to connect you without a bunch of programming. You will actually enjoy having more than one computer sharing an internet connection.
Remember this procedure and follow the steps again if you lose power and have to reboot your network.
on Dec 04, 2009 | Computers & Internet
I hooked up my D'link to modem and computer and connection is good. But i can't find it when i search on laptop wireless connection. I think you need i driver but i can't find one. Thank You
4. Click Next.
B52Computers
Jan 14, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Can't get my lap top to connect wirelessly to my router. Model # WRT54G2. The laptop says it is reaquiring the network address, but nothing happens.
4. Click Next.
Jan 10, 2011 | Linksys Wireless-G WRT54G Router
I got this computer for christmas and I cant get it to connect to any wireless wifi system. I dont know what I'm doing wrong. Could you please give me some instructions on how to connect it to a home...
4. Click Next.
B52Computers
Chris Thrash
Jan 10, 2011 | Computers & Internet
Having trouble connecting to an AT&T 2-Wire 2701 HGB Wireless Router (DSL).
Hi John,
I got your issue that you have trouble connecting with the At &t wireless modem ,
If Your comp if its win 7 Operating system
1. Click on start go to control panel--> go to
2. In network and sharing centre in the left hand side click on manage wireless network
3. In manage wireless network, you can see the networks which you have connected before , right click on the network name and select remove network. In the same way remove each one of them, the screen should me empty. there should be 0 items.
4. Then go back to network and sharing centre and click on connect to a network, you can see your network name , click on the network and click on connect to connect to the network.
If Your comp if its win Vista Operating system
1. Click on start go to control panel--> go to network and internet and then click on network and sharing centre
If Your comp if its win XP Operating system
1. Click on start go to control panel--> go to network and internet connections
2. Then go to network connections
3: You can see wireless network connection , right click on it and go to properties and go to the wireless networks tab
4. In wireless network tab, under preferred networks, if you see any network , remove it and then push ok
5. Then right click on wireless network connection and go to view available wireless networks
6. here you can see the network and you can connect with your password.
Please try this, im sure this will work
Thanks & Regards,
Prema
Oct 06, 2010 | Computers & Internet
How do I do file transfers from one wireless laptop on a westell 6100 dsl model to another wireless laptop on the same modem. Neither laptop in connected to the modem via eithernet. how would I set this...
Hi There.. Please follow te below steps..
1) Connect your old computer to the wireless network. Nowadays most people use the internet through a wireless network. So basically, if you have wireless internet and you are able to get on the internet... that means you are connected.
2) Go into the networks settings. This is usually as simple as right clicking the network's icon and then clicking properties. What you want to do is turn on, "file and printer sharing" within the network
3) Now, go to the folders/data that you want to transfer. Right click or get into the properties of that folder. Check the box that says "share this folder with network".
4) On the new computer, connect to the wireless network. Under control panel or possibly the start menu, there should be an option for "My Network Places" or "My Network". In this folder you should find the data that you chose to share from your old computer. You can simply copy/paste or drag/drop the files to your new computer.
Now you are offset to transfer the files from one laptop to another...
Was this information is helpful. Kindly revert if this helpful..
Jan 12, 2010 | Westell Wirespeed LiteLine 6110 Modem
Fifth computer unable to connect to internet
-- ckeck if you see 'wireless connection' in the network connections, in order to find it, click start --> control panel --> network connections and you must see wireless connection in case of win xp..
start --> control panel --> network and internet --> network and sharing center --> manage network connections and you must wireless network connection under LAN or hi speed connection... in case of win vista
--if you have that ikon that means you have your drivers installed on the computer properly
--right click wireless network connection and click "view available connections" in case of  xp and "connect/disconnect" in case of vista you must find the network and get connected..
letme know if you have problems connecting..
Jan 24, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Internet connection sharing
To share an internet connection, you need to have two network connections, one for the internet connection, and another for your network.
If your DSL has a USB connection, plug it into one of your computers and then then go through the network setup wizard, from there it will walk you through sharing an internet connection.
If all the computers have wireless, you can set up an adhoc network, and share the connection that way.
Honestly, the easiest method would be to go out and buy a router.
Aug 24, 2008 | Microsoft Windows XP Professional With...
Can't connect to 3Com Office connect wireless from Apple Mac Pro
PPPoE connection is set up
1. Control Panel, double-click Network Connections. 2. Click the PPPoE connection under the Broadband group that you want to share, and then click Change settings of this connection under Network Tasks. 3. On the Advanced tab, click to select the Allow other network users to connect through this computer's Internet connection check box. 4. PPPoE connections behave in a similar way as do dial-up networking (DUN) connections, and you may want the connection to be automatically dialed when another computer on your network attempts to connect to the Internet. To do this, click to select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box. 5. If you want to allow other network users to enable or disable the shared Internet connection, click to select the Allow other network users to control or disable the shared Internet connection check box. 6. Under Internet Connection Sharing, in Home networking connection, click the LAN (Local Area Network) connection that connects the computer that is sharing its PPPoE Internet connection to the other computers on your network.
Feb 07, 2008 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Open Questions:
ZOHO password recovery phone number +1800 365 4805 KO RAJAN Get ZOHO 1800 365 4805 password recovery phone number easy steps to forgot or change ZOHO password recovery via phone number #1-************ just follow some steps to recover ZOHO password while you want. In varoius conditions many people lost their account password and much more secure information or information may be hacked by anyone so in that case people want to configure ZOHO with ZOHO or other microsoft account services. Their are many certified officer to suggest people that how to change or recovery ZOHO voicemail password using phone number in easy mode wih simple procedure. Hence search engine suggest many combinations to recovery ZOHO password to recovery or change it quickly, if you have any of them so contact to get well ZOHO support form us. ZOHO password recovery not working ZOHO password recovery phone number ZOHO password recovery contact number ZOHO password recovery help ZOHO password RECOVERY support ZOHO password recovery wont work ZOHO password RECOVERY wont work ZOHO password recovery link ZOHO password RECOVERY issues ZOHO password recovery usa ZOHO password RECOVERY customer service. ZOHO email account password RECOVERY ' free ZOHO email password recovery ' cannot RECOVERY ZOHO email password ' ZOHO email password recovery ' ZOHO email password recovery download ' ZOHO email password recovery software ' free ZOHO email password recovery. ZOHO email password change, ZOHO email hacked password changed, ZOHO email hacked can't change password, change ZOHO email password on iphone, change ZOHO email password on ipad, change ZOHO email password on android, ZOHO email account hacked can't change password, how to change ZOHO email password on droid, ZOHO email password problems, ZOHO email password not working, ZOHO email account password recovery. ZOHO password recovery phone number.
Apr 26, 2019 | Microsoft Computers & Internet
Computers & Internet Logo
362 people viewed this question
Alun Cox
k24674
