Question about Kenmore Washing Machines
F51 code - Kenmore Washing Machines
  • 15,935 Answers
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 11, 2010
Whirlpool cabrio washer showing F51 error code
Hi Craig,
Just saw this post come up among F51 error codes (as it will show previously posted and answered questions ) and wanted to add some info I have regarding this exact issue you may or may not already have, no harm in posting either way.
The F51 typically indicates a failed "RPS" has been detecected...but it can be the result of other issues...just for future reference and if anyone has not come accross this before.
The scenario you describe is usually associated with a item stuck under the tub or a loose stator or a faulty "RPS" device or connection at the "RPS"...but I don't know if you checked that yet or if you know how, thus the error F51.
**The repair tip below is directly from Whirlpool**
F51 is usually associated with the rotor and stator/RPS assembly and quiet often it is initiated due to a loose rotor or bad RPS...I'd start by checking the bolt.
There is a repair tip regarding this which suggest checking the wires to the RPS and then the rotor, while insuring the center bolt is really tight via applying some "lock tight".
I actually see a lot of these and most times it's a loose rotor bolt, that is where I always start my diagnosis. Here's an exert from my files directly from Whirlpool...
You may want to check the rotor, I've seen the center bolt become extremely loose, thus causing the F51 error, this is where and what to look for shown below...
...but either way that should help out with the repairs and good luck.
Regards,
Macmarkus :)
Dec 21, 2011 | Whirlpool Washing Machines
Am getting a F51 error code
The electronic control displays an F51 code.
There is an intermittent connection at the Rotor Position Sensor, (RPS), causing the electronic control to indicate an F51 code.
Remove and reinstall the connector at the RPS at least three times to clean off any corrosion built up on the connector and RPS due to the intermittent connection. Confirm that the connector is fully seated onto the RPS control upon final connection and verify there are no damaged wires.
If you still receive the error after this, replace the electronic control with part #W10130544. This new control is designed to check the RPS sensor differently and is less sensitive to intermittent RPS connections.
Dec 25, 2010 | Whirlpool Cabrio WTW6600SBK
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Error F51 for Kenmore Elite Oasis Toploading washer??
bad main board or motor possitioner sensor.. most likely motor sensor.
China made junk parts with a million problems
Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool washing machine - F51 code
F51 - This is a motor Rotation Positioning Sensor failure. If this persists you will eventually need to call in a service engineer to repair it as the machine will eventually stop working altogether.
Sep 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F51 code
From experience, I know this is an Oasis. F-51 can be caused by a fauly main control, a bad wiring harness or something stuck between the basket and tub. There is a recall going on with these, you might want to look into.
Apr 22, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
290 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
