Question about Mitsubishi VS-45609 TV
Color flickers off and on
My tv's picture flickers the color off and on. I'm not sure if the picture tube is going out. It's only about 4 years old and I'm worried that something is seriously wrong. Can you help?
  • Dianedwyer Oct 16, 2007
    I don't understand what the capacitor is? So this confused me...sorry, maybe its a girl thing.
  • 3 Answers
Most of the time TV problems arise by power supply noise. This noise in the supply is usually caused by Electrolytic Capacitor failure. If you are technical, you can get the schematic and look for the voltage regulator circuits. Measure the voltages with a DVM using both the DC and AC settings. If the DC setting is lower than normal, you will probably see about .5 to 1v of AC voltage on the line. Look for the large capacitor in the regulator circuit and replace them. Cost about  $.50 each. Get new caps with slightly higher voltage rating (if they will physically fit).
Good Luck
Posted on Oct 16, 2007
  • John Brunn
    John Brunn Oct 17, 2007
    I'm sorry. I assumed you had some technical background and were trying to fix it yourself. Most repair shops will charge you a fixed minimum of $150 or more just to look at it. Any other parts and labor will be extra (usually no guarantee of a maximum cost.) If you have a friend who is a technician or electrical engineer I can help explain to them how to troubleshoot your TV.
    This is the best I can do right now. Let me know if you can get the help you need.
    Regards,
    John
Rear projection tv colors flickering
Two types or more of sets: regular TV sets with a picture Tube, big rear projection sets, Plasma, LCD, DLP
A model number would allow me to give you the answer--I suspect you have a set with a picture tube(regular tv)
Let me know which so I can try to give correct answer.
Mar 28, 2012 | Televison & Video
The tv is at least 17 years old.The blinking red light blinks 5 times ,then the tv picture goes off . The voice is still on
Five blinks is the error code for an AKB (auto kine bias) error. What this means is that the set isn't able to balance the three color guns (red, green and blue) of the picture tube properly, and it's blanking out the screen.
To get the proper colors, the signals for the three colors need to be balanced, and Sony sets have circuitry to do this automatically. Other brands don't, and when they go out of balance you see a picture that starts to show tinting or colors that are off. As the picture tube ages, it gets harder to adjust the balance until finally the AKB circuit can't anymore, and poof, the picture goes away. With a 17-year-old tube, it's not surprising.
There isn't anything that can be done to fix the picture tube, it would need to be replaced. But the cost of the tube and the work required to get it set up after installation makes it completely uneconomical to repair this TV. A new picture tube is nearly $200. Then special tools are required to set the tube up (a process called convergence), so you'd need to find someone to put it in, and possibly pay to have the old one disposed of. A new 32-inch LCD set is around $350 now. Treat yourself to a new one.
Jan 01, 2011 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Projection television acting like an old picture tube TV.
Yes, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
Sep 16, 2009 | Toshiba 43H72 43" Rear Projection...
Our sony trinitron 27" wega less than 5 yrs old..when powered up flickered off three times now stays on but the color is very red no matter if we reset or do a color adjust or unplug it from the cable box...
sometimes picture tube tvs develop shorts between the internal electrodes usually cathodes to filaments causing the one or more of the guns inside the tube to go high in emission, when this happens the screen or picture you see will get excessively in this case red and some horizontal diagonal lines will also show causing the tv to shut down, another condition that may cause an excessive red screen may be a failure of one of the voltage source that feeds the color amp in this case the red ampl, this also may cause the retrace lines and tv shutdown.i hope this explanation helps you better understand what might be going on with your tv. In both cases technical analysis will be required and in some cases even the picture tube condition can be corrected with out having to resort to a picture tube replacement. i hope i answer the your inquiry to your liking and if so please let this site know by leaving some pos feedback.
Aug 22, 2009 | Televison & Video
Colors (tube tv) periodically become bright and flicker
this sounds like one of the tubes is shorting out ,or have you or do you know if your tv tubes have been serviced and the fluid checked in them reciently.i know sone tv proj carries some kind of solution in the tubes to keep them running cool ,call a service rep or the panasonic co and ask them tech support
Apr 16, 2009 | Televison & Video
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
Rca 62" PROJECTION FLATSCREEN - COLOR PROBLEM/FLICKERING SCREEN
Sounds like the red picture tube could be shorting internally which would cause the "all red" condition. In which case you'd have to replace the red tube. Are there horizontal (slightly slanted) lines through the picture as well when this is happening and a very very bright screen? If so it's most likely the tube.
Oct 06, 2008 | RCA F36645 TV
HELP MY PICTURE IS RED AND SLIGHTLY BLURRY
It is probably a convergence problem which would involve solder work to change convergence i.c.s or if there are not colored shadows around everything it could be a problem with tubes. On a few of these I was able to remove the front grill and take off the small door, and with an insulated screwdriver gently tap on the neck of the tubes with the set on. Now if the picture flickers you have some particles on the filaments of the tubes and sometimes the debris will break free when you perform this, allowing your picture to restore full color and brightness without changing any parts whatsoever. Otherwise, the convergence chips are located on a large metal heatsink and have a generic part number printed on the front of each. Sometimes you have to remove a pressure clip to see it. Hope this helps, Russmann.
Jun 13, 2008 | Hitachi 65S700 65" Rear Projection HDTV
Convergence
Color tubes are OK. Do not adjust. The issue at hand is called
convergence alignment.The repair involves-------
1)Pull chassis
2)Replace convergence IC's
3)Recheck alignment
work should be done by a skilled technician........T.
Oct 24, 2007 | Philips 60PP9202 60" Rear Projection...
Rainbow picture
The tube needs to be degausse you had maybe placed speakers beside the tv causing it to magnetize have a tech look at it to remedy the problem.good luck.
Apr 08, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Mitsubishi VS-45609 TV Logo
56 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
