Question about Toshiba RD-XS32 DVD Recorder
Doesn't recognize any disks
This is my first DVD player and I didn't know you're supposed to run cleaning disks now and then.  After the warranty expired, it stopped recognizing all disks, so it won't even play a cleaning disk.  Gives an edit about the disk being the wrong kind, even though it used to play all of them before.
  • 3 Answers
Re: Doesn't recognize any disks
I updated my firmware from 1413 to 1416 found on avforums. This is for european units. I suggest you also complain to Toshiba Japan as there are known issues with the xs32. We all need a firmware update. See AVforums.
My unit will not recognise RAM discs anymore - even those that I had previously used.
Have you thought of replacing the DVD drive. See AVforums.
Posted on Jan 09, 2008
Stopped recognizing all disks, so it won't even play a cleaning disk.
Posted on Dec 05, 2008
0 characters
3 Points
DVD Player doesn't recognize disks present
Get a DVD cleaning kit and follow instructions, if this fails the laser pickup assembly will need to be replaced, not cost effective to repair cheaper to buy.
May 08, 2012 | Yamaha DV-C6480 Multi-disc DVD Player
The go video DV2130 will not read a dvd. It loads, but will not play. Can this be fixed? No longer under warranty
  1. Make sure you have a non home made DVD. Some DVD players will not play DVD'S in certain formats.
  2. If you have a normal DVD in the DVD player and are getting "NO Disk" then there is a real good possibility the lens is just so dirty that it is not recognizing your DVD at all. This happens a lot to all disk players that are neglected from the cleaning process. Get a disk player cleaner and run it through a few times until the disk is read again. Sometimes the lens is so dirty you have to try a few times just to get the cleaner disk itself to play just to do the actual cleaning. Make sure to run that cleaner disk through once a week. These disk cleaners "sweep" the lens and work well. You can get one at your local Best Buy for $8usd.
  3. The last thing it could be is that somehow the lens has come out of alignment. Just a millimeter out of alignment is all it takes to not be able to read a disk and DVD players get bumped and knocked off the shelf easy. So this can happen often especially with the more smaller travel DVD player.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 21, 2011 | GoVideo DV2130 DVD Player/VCR
We have an LG DVD DR7621W and it keeps telling us no disk although we have put a disk in.
try to insert other disk, make sure the file format with in the dvd that you use is applicable to the dvd player if not it will not if still other dvd's doesn't read try to clean the optic sensor with cd lens cleaner might be dusty.another way is manual cleaning with the use of smooth cotton buds with isoprophyl alcohol wipe the optic sensor do this gently not to damaged the optic sensor. good luck hope this will help you.
Jul 18, 2011 | LG DVD & Blu-Ray Players
DVD goes in and tries to start twice then says "no disc". What do I do to fix it?
Just a couple of questions.
1.) How old is the DVD Player?
2.) What is the brand of DVD Player?
3.) Does it do this for all DVD's or a specific DVD?
4.) Has anything changed in the last week or so?
If the DVD player is less than a year old it most likely has a Manufacturer warranty. Also if you haven't tried already try putting another disk in the dvd player and see if it will read it. If it won't read another DVD try a CD.
Please clarify the above so that I may help you further.
Sorry this is happening I know it's frustrating.
Mar 20, 2009 | DVD & Blu-Ray Players
No recognize disks CD and formats MP3
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Unfortunately, if the player will no longer read any commercial cd that you attempt to play or MP3 disks, the unit is defective and needs to be replaced. The unit has a 90 day warranty from the date of purchase. You will need the receipt in order to receive a warranty exchange.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Dec 01, 2008 | Coby DVD-224 DVD Player
I have had this on a number of other players. First try the disks in question on another DVD player after giving them a thorough clean. If they work there then you know the problem is not with the disks.
After that (assuming the RH299 is actually working in every other respect e.g. on HDD), run a laser cleaning DVD/CD in the machine to clean the laser lens. If your machine is out of warranty then you can try opening it and cleaning the laser lens with rectified spirits/pure alcohol. Then try the disks again. If they still don't play, then it's off to a local electronics expert to see if realigning or replacing the laser and transport mechanism is economically viable, or buy a new machine.
Jun 30, 2008 | LG RH299 DVD Recorder/VCR
Problems playing DVDs, Random Disk Error
To answer this I need to know the make, model and year of your DVD player, and if you bought it in northamerica, or europe.
Jun 24, 2008 | Sylvania DVR90VE DVD Recorder/VCR
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Dvd player doesn't recognize dvd's of any kind
jusguessin should call Toshiba quickly. The units have a 1 year warranty. Do not open the unit or it will void your warranty (I know, I do Toshiba warranty repairs on their recorders. If anything will make be void a warranty, it's a consumer who opens the unit and pokes around inside).
mooch, clean the laser head. I wish I could refer you to a FAQ because this is about the 10th time today I have written this.
Open the unit. Remove the DVD drive. Take the top off of the DVD drive. Clean the lense with a q-tip with a little windex on it. Work the head up and down gently. Reassemble and test. If problem presists, go buy a new one.
Sep 16, 2007 | Toshiba SD-V392 DVD Player/VCR
Toshiba RD-XS32 DVD Recorder Logo
559 people viewed this question
Top Toshiba DVD & Blu-Ray Players Experts
Are you a Toshiba DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
