Question about LG 32LB9D TV
Can't turn tv on with remote, only manually, when on volume is at 100 and cannot be adjusted with remote or manually. channels cannot be changed with remote or manually. Changed batteries in remote,
The tv can only be turned on manually, when on the volume is at 100 and cannot be adjusted with remote or manually, will not change channels with remote or manually. Changed batteries in remote. Remote still operates PVR.
  • John Jun 28, 2013
    I have the same issue, tried to restart it. Remote doesn't work even after new batteries and when i turn the TV on the volume skyrockets to 100 and you cant turn it down as it goes straight back up. When you press the volume up button it goes down and then once released goes back up again? Really weird and annoying.
    President:
  • 1,734 Answers
If you have a Universal remote ask here for the remote codes. They helped me alread a lot!
Posted on Jul 08, 2009
Replace with new batteries and it works --- so simple
Posted on Sep 22, 2009
Sansui platinum plus tv
Are you using a remote control or the switches on the TV?
If using a remote;
First turn the TV off at the power point then wait for 10 seconds.
Then turn the TV back on
Then attempt top adjust the volume using the manual settings on the side or bottom of your TV, if that works then you may have a remote that either needs new batteries or does not work.?
Can you turn the TV on and Off with the remote control?
Can you change channels with the remote control?
If you can do both the above it would appear that the remote is working OK.
Does this fix the problem?
Jun 30, 2014 | Televison & Video
Remote volume will not work
HAD SAME PROBLEM RE PROGRAM FIOS REMOTE ENTER 4 DIGIT CODE AFTER LIGHT BLINKS PRESS VOLUME UP AND DOWN IT SHOULD WORK THEN PRESS ENTER OR OFF BUTTON FOR PROGRAM TO WORK TURN TV BACK ON.....FIOS PROGRAM MANUAL HAS SECTION FOR THAT PROBLEM...MINE WORKS FINE AFTER I DID THAT..
May 25, 2013 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Volume moving on it's own
Either the key/button the TV or Remote is stuck. Just remove the batteries of the remote and try. If same thing continues, do vacuum cleaning of the panel button/switch after switching of the TV, removing the plug from the power outlet. If the problem persists, this might require attention by a qualified service technician.
Jul 11, 2012 | Sanyo Televison & Video
Hi My matsui tv 1409T remote died (due to battery leakage!) so I have got a signalex universal remote as a quick fix replacement. I have set the remote to switch the tv on/off, change channel and adjust...
1) Change the batteries by alkalines
2) Retight the springs contacts with plyer for better contacts.
3) clean the contacts with special spray contacts.
4) Downloa the code or proceed with your instruction manual.
5) If the problem persist, you must return you remote control and buy other from Radio Shack I am recommending.
God bless you
May 14, 2012 | Televison & Video
My brighthouse remote can turn my tv on and off but not change channels
The remotes have several device keys at the top of the remote. They have abbreviations like "VCR", "DVD", "TV", "CBL". By default some actions are locked into a specific key. By default, the volume buttons will always control the TV volume and the channel buttons will always change channels on a digital box.
If you have a digital box, and the channels wont change, the default locks might have been removed. Consult the instruction manual that came with the remote and re-lock the buttons to the correct device key. Otherwise you will need to press the "tv" button when trying to change volume and the "cbl" button when trying to change channels.
If you do NOT have a cable box and are just simply trying to use the universal remote as a primary remote, you will need to unlock the global channel lock. Consult the manual for the remote or check online for the remote guide. The Company which makes the remotes is called Universal Electronics and you can find digital copies of their manuals on the Brighthouse Websites.
May 20, 2010 | Sylvania LC320SS8 32 in. LCD Television
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
While wathching TV, the typical volume level
Cleared all AV settings and reprogrammed.
Jan 30, 2010 | Onkyo TX-SR703 Receiver
Remote and caption problems
have you programmed the remote? or you can go into the menu button on the front of the tv, use the up down (either the volume or channel may move the selection) to locate the caption on/off control and turn it off that way. if you need the manual try here
http://tv.manualsonline.com/manuals/mfg/philips/19_inch_color_tv_cover_l9_pr1903c1.html
Dec 02, 2008 | Philips Magnavox Learning Universal Remote
Mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Jun 27, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
LG 32LB9D TV Logo
783 people viewed this question
Computer Repairing
Computer Repairing
