Question about Whirlpool Dryers
The prong on the electricle from the dryer is shaped differently then the wall outlet
  • 26 Answers
You need to get a matching dryer receptacle rated fro 220V and 30 Amps (in the US).
Make sure you have the power off before attempting to replace the old dryer receptacle.
I have seen many dryers connected to oven receptacles in the past. While incorrect this is not dangerous because the oven receptacles are usually 50-60 amp.
Paying a local licensed electrician $50/hr is a fair & safe way to make sure your dryer receptacle is installed correctly.
Posted on May 15, 2009
I have a 3 prong wall mount outlet for my dyer and want to put in a 4 prong. how do I do it?
Veronica,
If you are talking about the outlet you plug your dryer into, that would require an certified electrician to make the change since that is covered by electrical codes. If you are talking about changing the pigtail on the dryer, you could do that yourself. Just remember to take the brass strip off that goes from the middle of power cord block to the ground. You have to separate the neutral from the ground in a four wire situation. Hope this helps!
Mar 06, 2015 | Dryers
Dryer with 3 prongs 2 flat one L shaped
Yes, you can buy another pig tail with the set up you have incoming. Just be sure when you remove your old one, you note which wire goes where.
Jul 04, 2010 | Dryers
I have a 125/250 3 prong outlet but the current 3-prong plug on the maytag altantis dryer has an extra notch on one of the prongs. is there an adapter that i need to get to plug into my existing outlet?
The L shaped prong is for a 30 amp outlet and the 3 straight is for a oven and denotes a 50 amp circuit. Please use the proper connectors and wiring, Eric
Jun 15, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Wiring conia ccd4501
There could be two situations for you. For the wall outlet, you may have a four prong plug or a three prong plug. For a three prong plug the outlet has three prongs and the terminals inside match up with these prongs. The two slanted prongs on the top are the hot terminals and the red and black wires get connected to these (order doesn't matter but keep the wires matched up with the terminals on the same sides). The white wire is connected to the "L" shaped prong, the third lower prong. The bare copper wire is just bent out of the way. At the dryer for the three prong there will be three terminals 2 hot and one neutral. Usually, your dryer cord will have the neutral as the middle wire, but pay attention if your cord wires are color coded (where white will be your neutral wire). At the dryer there is a terminal which is connected to the frame of the dryer by a piece of metal. This is your neutral, connect your neutral wire from your cord up to this. The other two wires get connected to the other two terminals (order doesn't matter but keep the wires matched up with the terminals on the same sides). For the four prong its very similar but there is a small change, that bare copper wire is now used. The terminals on the wall outlet will line up with the prongs. The two vertical terminals on the left and right are your red and black wires. The "L" shaped prong is your white wire. Now the fourth prong, the one shaped like a semi circle is the terminal you connect that bare copper wire up to that is your ground. At the dryer for the cord (If its a four prong cord your wires should definitely be color coded). The terminal that had a connection to the dryer frame now will no longer have one. The terminal thats connected to the frame you connect the green wire to. The terminal that was connected to the "green wire terminal' is now the neutral terminal and your white wire gets connected to it. The other two terminals are where your connect your last two wires.
May 10, 2010 | Dryers
My four prong plug Kenmore dryer is different than my four prong wall outlet. How should I correct this
What you will have to do is buy th correct cord for you outlet. Most homeimprovement stores stock the or appliance store. Get the correct cord for your outlet and replace it on the dryer and it should plugg-in. These are pretty simple to replace with an sdjustable wrench and a screwdriver.
Jan 28, 2010 | Dryers
Dryer has power but will not start. tested wall outlet and dryer plug and both have power. blower motor and heating element both read 120v ac.
Assuming this is a full size 240v dryer (you never said what it is) you should have 240 volts across the two angled prongs in your receptacle (L1 and L2). 120v across either ONE angled prong to the "L" shaped prong (neutral).
If it a 120v dryer your voltages are alright.
It sounds like the door switch is open.
Jan 03, 2010 | Kenmore 500 6953 Dryer
I don't have the same plug as the one on my kenmore 70 dryer
Hi, You can either change the outlet or change the cord. Easiest would be to get a new caord. Make sure you get the right one. There are two different ground posts.
One is straight and one is L shaped.
I hope this helps you. Please let me know if I can assist you further.
Vic
May 30, 2009 | Kenmore 22422 Top Load Washer
Estates dryer by whirlpool has a 3 prong plug. the wall has a 3 prong w/an L shape. where can I get a wall switch to match the 3 prong without the L shape as this is a straight shape
Home Depot, Lowes, etc will sell these type plugs in the electrical section. If installing yourself, be sure you get the wires in correct positions, let me know if you need info on that.
Nov 16, 2008 | Whirlpool Dryers
Changing cord from 3 prong to 4 prong on frigidaire dryer
The following link explains how to convert your appliance from a 3-prong to a 4-prong power cord:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I hope this helps you. Let me know if you still have questions.
Nov 11, 2008 | Frigidaire GLER331A Electric Dryer
Dryers Logo
69 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
