I was having a problem with vista verses nvidia driver display stopped funtioning and has recoverd.So try ing to solve that problem i seen some changed there clcking speed but when i tryed changing my mem speed i get a beep + a black screen now
You'll probably have to default your CMOS, it's pretty easy. Just look for a jumper on the motherboard labelled CMOS or BIOS, you should just have to set it to the next jumper over, power up, then power down and set the jumper back to normal. If you can't find any jumpers that indicate they control the CMOS/bios, just unplug the PC, pull the battery on the motherboard for a few minutes, then put it back in, plug the PC in and power it up, that should effectively set your bios back to defaults.
Ik heb geheugen bijgestoken, deze zijn correct, nu start pc niet meer op, f2 of booten helpt niet,...
(More)
Ik heb geheugen bijgestoken, deze zijn correct, nu start pc niet meer op, f2 of booten helpt niet, ik trachte ook met opstartschijf.... Ik zie dat bios/cmos? niet opstart, op mijn scherm krijg ik enkele seconden "in power safe mode, press any key" ik probeerde al veel, batterij eruit gehaald en vernieuwd, videokaart gewisseld, scherm gewisseld, alle plug ins nagekeken,enz.... Kan iemand zeggen wat er aan de hand is en hoe ik het kan verhelpen, ik trachtte ook het oude geheugen teurg te plaatsen, dit zonder resultaat mvg Jan
i have a new dell inspiron 1525 , my problem is no display but the icons on the disctop can appear...
(More)
i have a new dell inspiron 1525 , my problem is no display but the icons on the disctop can appear during the day for the sun light i mean , the problem begins i closed the screen and the computre was running now the computre can not start unless to remove the buttery but can work normaly if connected other screen how can i solve this problem
intell E210882 DIAGRAM accidentally disconected the power, hd led and front panel wires of mother...
(More)
intell E210882 DIAGRAM accidentally disconected the power, hd led and front panel wires of mother board not sure which goes where. PC is a e machines T3624
Display only shows low 8 bit 800 by 600 Cant get on internet on this machine so need motherboard...
(More)
Display only shows low 8 bit 800 by 600 Cant get on internet on this machine so need motherboard drivers to download direct so i can put on disc to correct
necesito saber el numero impreso del circuito Q8F1 de la tablilla dell E210882. si alguien es tan...
(More)
necesito saber el numero impreso del circuito Q8F1 de la tablilla dell E210882. si alguien es tan amable de pasarmelo se lo voy a agradecer mucho.
