Question about Hotpoint Aquarius WMA42 Front Load Washer
Fitting new belt on hotpoint washing machine
My machine is not spinning and clothes are very wet when coming out
my husband fitted a new belt but now nothing is happening
  • 56 Answers
Check if plug is loose on motor,in the general area where the belt was changed has anything been disturbed,cables i mean?,sounds like the motor brushes may be worn(this would cause motor to stop),they are situated 180degrees apart at one end of motor,they are easy to change,there is a spot at brushes to put a screwdriver in to remove brushes-hope this helps
Posted on May 15, 2009
Hotpoint WF250 clothes coming out soaking wet after spin?
The fast wash cycle is for a reduced capacity load of approximately 3kg , it does not pump or spin long enough for a full capacity load
Jun 15, 2016 | Hotpoint Washing Machines
Hotpoint pump
Is the machine not spinning? May need new bushes. Sited underneath and wear down by making contact on drum.
Feb 05, 2012 | Hotpoint Aquarius WF210 Front Load Washer
Drive belt on hotpoint wm56 keeps coming off when machine goes on fast spin. I have fitted a new belt but it still keeps happening.
Make sure belt is reasonably tight, and it is in the center of the drum pulley, if it still comes off, then I would suspect that the drum bearings are worn, or the drum is running out of alighnment, or the motor bearings are worn, if it is noisy when you spin the drum by hand, then the bearings have definately failed.
Please rate my solution.
Thanks.
Sep 22, 2009 | Hotpoint WM56 Front Load Washer
Drum Paddle broken Hotpoint Aquarius
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
On hotpoint, creda, Ariston ,indersit and someother makes see video
To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine.
Huge selections of lifters are available on thewebsite DrumPaddle lifters
Mar 08, 2008 | Hotpoint Ultima WF860 Front Load Washer
Does not spin and rinse properly
Sounds like motor is not coming up to spin speed. May be overheating, in which case you would need a new motor.
Feb 16, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Clothes wet after spin cycle
if its not the belt its your brushes in the motor that need replaced
Jan 04, 2008 | Hotpoint VBXR1090D Top Load Washer
Washing machine does not spin out all water
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 02, 2008 | Washing Machines
Machine failing to spin correctly and drum wobbling everywhere
Open up behind, check to see if any spring/springs have come off. Check to see if one or more of the shock absorbers loose or faulty. The shock absorbers can be removed to be examined (note how they are fitted before attempting to remove) Faulty shocks shd be replaced. Wet clothes. Probably your exit is blocked with previous muck, check. Open out to clean well.
Apr 07, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WMA42 Front Load Washer Logo
898 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
