Question about Toshiba Televison & Video
60 in toshiba projection tv problem
Hello. i had to change my speakers on tv now the picture is out of wack. Almost like double vision when looking @ tv color spectrum is not alighn how do i fix this. read that the tv is magnitized and i need to demagnitize it please explain if this is the problem and how to correct. this thank you
    President:
  • Toshiba Master
  • 1,779 Answers
Your list under Projection so if that's what you have then it is not magnetized. You have inadvertently unplugged or moved the centering rings on the CRT's. If you did I would call a Service Co. to straighten them out.
Go over and re track every step and see if you un plugged a connector for the convergence. Each one of the tubes will have leads going down to the convergence board.
Posted on May 15, 2009
My Toshiba 53H71 rear projection TV's picture looks like double vision with a heavy tint outline how can I fix this???
Double vision/ picture problem occurs due to failure of convergence output ICs in rear projection tv and it is common problem of projection tvs.
Please replace convergence output ICs in tv to solve the issue, there is convergence repair kit available for $70 on This Site that has required parts/ ICs, instructions about how to replace ICs etc for a handy person.
Hope these info will help.
Thanks.
Jun 11, 2011 | Toshiba 53H71 53 in. Rear Projection...
We recently moved the tv and now when we turn it on it has double vision. It kinda looks like a 3d movie. What could be the issue? Is it worth fixing?
If tv picture was fine before moved then check dry/ cold solder joints/ connections on convergence output ICs and nearby circuit area.
Local tv repairman will resolder loose/ dry solder connections to solve double vision picture problem.
TV worth fixing if picture is good.
Thanks.
Feb 18, 2011 | Sony KP-57WV700 57" Rear Projection HDTV
Phillips 51pp9303h/17 red and green double vision of writen words and bowed line of red green at bottom. some objects in show look real shiney. and double vision of others.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 29, 2011 | Philips 9P6031C 60" Rear Projection...
Mitsubishi VS-60609 60 in. no pix /has sound
My Mitsubishi TV model VS 60609 is showing double vision on the screen.
Feb 24, 2009 | Mitsubishi VS-60609 60" Rear Projection...
RCA Projection TV not working properly
All I need to know is how to shrink the picture!
Dec 21, 2008 | RCA P61830BL 61" Rear Projection...
Phillips 60" projection TV Double vision
This is a convergence problem and is either bad connections at the convergence ICs or defective ICs. If you can solder, you can repair this yourself. Let me know if you wish to repair this and I can provide you with additional details.
Dan
Aug 08, 2008 | Philips 60P8341 60" Rear Projection...
Red Shadow on Picture
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 14, 2008 | Toshiba 61H71 61" Rear Projection...
Picture shadow on rear projection Sony big screen TV
OUR TOSHIBA HAS A DOUBLE VISION/BLURRIE PICTURE. THIS PROBLEM IS ALWAYS THERE. SOMETIMES THE PICTURE IS GREAT, BUT MOST OF THE TIME ITS BLURRIE/DOUBLE. LOOKS AS IF IT ALWAYS ON 3D!! ANY SUGGESTIONS? WE WOULD REALLY APPRECIATE ANY HELP WE CAN GET FROM ANYONE. THANK YOU!
Mar 03, 2007 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
56 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
