Question about Dryers
My dryer makes a screamming noise
  • cld_ferris Jan 04, 2009
    My dryer has started to screach, very loudly at times
  • Anonymous Mar 28, 2009
    We have replaced the roller guides and the dryer is still squeeking loudly
I have a WTL5400 screaming at me, so my Husband has taken the side and back panels off to investigate,and the noise was made by the air outlet plastic fan which spins when the tumble dryer is turning, this plastic fan thing was wibbly wobbly and the nut wouldn't tighten up. He has put in a couple of different size washers and tighten up the nut and hey presto no noise.
Posted on Apr 26, 2009
  • henrik_freds
    henrik_freds Mar 30, 2013
    Yes - same here - had difficulties in loosening the nut holding the fan. Tried by holding the nut on the opposite fan by another wrench and of course the wrong nut came loose. Removing the sidepanel on the right hand side (seen from front) gave access to the driveshaft itself so that i could prevent it from turning when loosening the nut. Thanks for your advice - guess you saved me 200$ here.
    Genius:
  • 1,601 Answers
Sounds like a bad belt
Posted on Oct 16, 2007
  • Thomas Christopher
    Thomas Christopher Oct 22, 2007
    more food for thought:
    Four possible areas:
    There is a small roller that tightens the drive belt for the drum. They can squeak. Remove the lower front panel and you should see the small roller near the motor and belt.
    Another is the two larger rollers that support the drum. You will see this if you remove the front lower panel.
    A another is where the drum rides on the upper round part of the door/opening and it has a plastic guide that seperates the metal drum from the metal door/opening. Over time this wears out and the two metal pieces will squeak.
    The motor bearings may be worn. Remove the drum drive belt and then start the dryer. If it squeals with the belt off then the motor bearings are likely worn.
    Thomas Christopher Nov 10, 2007
    Did this work for you?
3 Suggested Answers
miket756
  • 2702 Answers
SOURCE: my dryer is making a
it could be dry bearings in the motor a slosh of wd40 on it should stop that also check the drive belt if its smooth it may be sliping
Posted on Aug 07, 2010
heatman101
  • 43501 Answers
SOURCE: my hotpoint vtdoo tumble dryer is making a
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Sep 10, 2010
My maytag dryer is screaming at me!!
It could be the band slipping, depending on how handy you are, you can take out the back cover and check it out while it runs. I am assuming this is an electric dryer, so taking the back cover is not so difficult, just need to figure out what type of screws it has, find the corresponding tool and take it out (make sure power is unplugged while you do this) plug it back it and let it run, you can find where the noise is coming from. If you cannot figure it out, put everything back on and then it is best to call a technician.
Jan 22, 2018 | Maytag Dryers
My dryer screams when clothes are wet and gets quiet as they dry
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 05, 2010 | GE Dryers
When i turn it on it's making a skreeching noise from the back what could it be?
The most common stuff that comes to mind first:
1) one of the rollers (there are 2) has worn out and they skreech as
they're being killed. I've even seen rollers fall apart, with the outer
part of the roller (the rubber part) squeaking as it revolves around a
frozen-on roller bearing.
FIX: replace roller(s) that're making noise
Cost of part: $10
2) the motor bearing are shot - they scream as they're being ground to dust.
Fix: replace motor.
Cost: if dryer is old, replace dryer. If Dryer under warranty, use it.
Oct 23, 2010 | Whirlpool LER4634J Electric Dryer
The tumble dryer has become very noisy when warmed up almost lije a screaming noise
heatman101
Oct 13, 2010 | Dryers
My hotpoint vtdoo tumble dryer is making a screaming noise and belt is still inplace and turning.
We have made a few videos on these dryers and there are some very good repair guides on these.
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair
Sep 07, 2010 | Hotpoint Dryers
We have a Frigidaire Dryer Model GLER341as2 that is making a screaming or schreeching noise. The drum does turn though. The drum is not centered. More space at the bottom than at the top in relation to the...
heatman101
Aug 30, 2010 | Dryers
My dryer is making a loud screaming noise while it's runnig,what's the problem?
Aug 07, 2010 | Dryers
Dryers Logo
410 people viewed this question
Top Dryers Experts
Marvin
Marvin
