Question about Dryers
Replace on / off switch on a dryer?
How do you take off panel to fix on / off switch on a dryer?
  • tashaalexand May 16, 2009
    How do I fix the "turn to start" switch on my Frigidaire Gallery Electric Dryer? Some time ago, the knob broke off the front and we were using pliers to turn the dryer on. Now the pliers will not turn the switch on. I took the back cover off of the dryer to find the small sqaure switcher box. Can I find a replacement switcher at my local Sears and just replace or is it more complicated than that? I really don't want to call a repair man if I can help it and need my dryer today!!
  • 47 Answers
THERE ARE SOME SCREW ON THE BACK OF THE TOP OF YOUR DRYER, THAT YOU CAN REMOVE AND LOOK AT THE TIMER. IT SHOULD BE A PIECE OF CAKE. WHAT BRAND IS YOUR DRYER?
Posted on May 16, 2009
I need to replace lid switch on Whirlpool Thin Twin washer/dryer unit. How do I get the switch out and the new one in
The 3 screws across the front of the slanted panel need to be removed, then the panel. At the left and right rear of the main washer top are 2 5/16" screws, these need to be removed, there is a loose fitting steel clip through a slot on the main top these are holding down, when the 5/16" screws are removed slide the entire top forward and it will release from the front fixed clips. Unplug the lid switch unit and the main top can be set aside to replace the switch. Pleazer Appliance...
Jan 14, 2015 | Whirlpool Thin Twin Washer and Electric...
Replacing start switch on kenmore dryer
If you order the new Switch from sears parts direct.... Then when you replace the switch, make sure you unplug the dryer before you take the front panel off. Replacing the switch is quite easy... 4 screws total.
Jul 17, 2014 | Kenmore Dryers
What would cause my dryer to run but not heat?
test this steps and fix it. GOD BLESS YOU
Power From The House
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replace the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to REPLACE the power cord and the terminal block inside the dryer to which the wire is attached.
Jul 23, 2013 | Whirlpool Dryers
No heat when drying
see this causes and fix it. God bless you
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 27, 2012 | Dryers
I have a duet electric dryer GEW9250 about 5 years old. It stopped working last week. The light inside works but nothing else (no control panel buttons or lights or the digital display). A repairman...
Hello there and thank you for choosing fixya
To tell you the truth i dont think the contrlole panel was the problem the control panel rarly goes out here is a list of the most common things that go out and are a lot more cheep to replace
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. To determine if the door switch has failed, watch the part testing video at the bottom of this page. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) To determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page.
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Aug 05, 2011 | Whirlpool GEW9250 Electric Dryer
I have a dlg5932w dryer that will not heat. From reading posts, it sounds like I need to reset a safety thermostat switch. How do I find it so I can reset it.
Unplug the unit. Remove the top cover by unscrewing the 3 screws in the back and sliding the cover back and up. At the control board, disconnect all the wires from the board, remove the screws holding the panel and pop the panel off. Remove the front panel of the dryer. Down on the right bottom corner inside the dryer, look for the large round tube where there are 2 sets of wires connected around it. There are 2 high limit switches, one on top right and one on the bottom left. The high limit switch on the bottom left has the reset button in between the wires. Push it and you should hear a click. That will reset the switch. NOTE: this is only a temporary fix. The manufactures recommends replacing that switch if it should trip because it will trip again. Good luck
Jun 20, 2011 | LG DLG5932W Gas Dryer
Dryer will not turn on. Start button light is blinking. All other lights functioning.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 22, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Hello I have a general electric dryer model DBSR463EG6WW serial number TR775112A and was wondering how do I bypass the start switch because it is broken
please there is no need to start your dryer without the switch. you can easily replace the switch yourself just follow this instructions below to replace your switch. things you will need are philip and hex and nut screwdrivers, putty knife and Replacement "start" switch. then Disconnect the dryer from the electrical outlet. Slide the dryer out from the wall and disconnect the dryer vent from the dryer's back panel.
    1. Loop a piece of string behind the "Start" button and pull forward on the string to pop the knob off the switch's post.
    2. Access the interior of the control panel. Depending on your model of dryer, there are several ways to access the interior of the control panel. On older dryers, there will be an access panel along the back of the control panel that can be removed once all of the retaining screws have been removed. On newer dryers, the control panel is held in place by screws in the front or spring clips. Remove the plastic end caps on the control panel and remove the screws underneath. If your dryer has no end caps, slide a putty knife under the corners of the control panel and lift up on the knife to release the clips. Rotate the control panel toward the rear of the dryer to access the interior.
    3. Unplug the wires from the switch by sliding them off the contact terminals on the switch. Make a note which wire connects to which terminal so you can easily connect them to the new switch.
    4. Press the release tab to unlock the switch and slide it out of its socket. If you have an older dryer, remove the retaining screw to remove the switch. Slide a new switch into the socket and press it down until the release tab locks into place. If you removed a retaining screw, replace the screw. Reconnect the wires.
    5. Rotate the control panel back down on the dryer or replace the rear access panel. Replace the knob and reconnect the dryer vent. Plug the dryer back into the electrical outlet.
Dec 24, 2010 | Dryers
Dryer will not start, just beeps once when start button is pressed. I hear a single click behind the control panel/head too.
HAVING SAME PROBLEM TURNED OUT TO BE THE TEMP SWITCH ON THE DRYER BLOWER DUCT,CALLED THE THERMAL FUSE .SIMPLE REPLACEMENT DRYER RUNS FINE COST AROUND 30.00 DALLORS TO FIX.
Mar 07, 2010 | Kenmore 67032 Dryer
The dryer would not start, it was dead, opened and slammed the door shut, it worked fine. 2 days later it went dead again, sounds like the door switch, any ideas?
Sounds pretty good, actually. Insert screwdriver on either end of bottom/top panel and lift. Find the door switch and bypass it for a quick fix (just remember that dryer will operate when you open the door - not recommended if small children are present in the home). My advice is to replace the switch.
Nov 16, 2009 | Estate TEDX640JQ Electric Dryer
Dryers Logo
110 people viewed this question
Top Dryers Experts
