Question about Cyberhome DVD Recorder - DVR1600
Led screen not lit
It seems to be working otherwise, just the front panel not lit. I opened it up, and i could atleast check the lithium battery, and the fuse seemed intact.
    Scholar:
  • 51 Answers
It must have some display or power supply problems.
If it's warranty, check with the dealer.
If it's not, you may want to start shopping for a new one.
Posted on Oct 16, 2007
Where is the LVDS sreen fuse located on mother board HP 6050A2498701 MB A02"?
Have you fitted the correct screen? Make sure the part numbers are identical otherwise the LCD screen is similar to the LED screen.
Check your model number.
Jan 07, 2015 | HP Computers & Internet
3 yr old KDL-40V3000. Remote suddenly stopped working. Changed batteries twice - didn't make any differnence. Then noticed no LEDs lit on TV front pane! But TV is powered on. Also TV can be operated...
U have a Digital Camera turn it on,take ur tv remote pushes all the remote buttons on the front of the Digital Camera.One by one buttons.If all buttons of the tv remote work will register on the Camera viewing screen,because the Digital Camera able to read infer red signal output.Will figure out wright away the tv remote work or not easily.Tv remote sensor/board have no LED power light lite up might just be a lose connection or just a dead LED lamp only,because all the buttons on the remote sensor/board to the tv panel work wright?Try website Remotes.com to buy tv original remote.
Jun 10, 2011 | Sony BRAVIA KDL-40V3000 Television
Dryer GEW9250PWO control panel will not work or light up. Lamp inside dryer works. Also hold End Of Cycle button down and does lock panel...but still nothing other than that lights up. Any ideas?
Take a close look at the front LED panels, are some of the LED's lit up ever so slightly when this occurs? If so, it seems to be a very common problem with Whirlpool.
Nov 28, 2010 | Whirlpool GEW9250 Electric Dryer
I have RV082 Router , and Diag Led is constant what to do
Checking the Router's LEDs
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router check the lights on the front panel of the router.
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router, the following should be lit:
  • 1 - 8 (LAN)
  • DMZ/Internet (WAN2)
  • Internet (WAN1)
  • Diag
  • System
Step 1:
Make sure the System LED is lit.
NOTE: If the Diag LED doesn't goes off, you need to upgrade the router's firmware. For instructions, click here .
Step 2:
Make sure the LAN 1-8 ports is lit depending on the computers connected to the designated Ethernet port.
NOTE: If the LAN 1-8 port is not lit, make sure that the computer is powered on. You can also try connecting the PC using another working cable.
Step 3:
Make sure the Internet (WAN1) and DMZ/Internet (WAN2) LED is lit.
NOTE: If the Internet or DMZ/Internet LED is not lit make sure the Broadband modem is powered on and that the modem is properly connected to the Ethernet port
You can access the web-based user interface utility of the RV082 by using one of two methods:
  • Through the RV082 IP address (192.168.1.1 by default), or
  • Through its default hostname ("RV082")
1. Open a web browser (Internet Explorer or Netscape Navigator)
· By IP address: Type http://192.168.1.1 (192.168.1.1 is the default IP address of the RV082)
and click Go or press the [Enter] key.
· By Hostname: Type http://RV082 and click Go or press the [Enter] key.
2. When the username and password prompt appears, type admin in both the username and password fields. (admin is both the default username and default password for the RV082).
Nov 08, 2010 | Linksys RV082 Router (RV082-AU)
Hi There, When I turn on my emachines D620 lab top the screen does not come on. It seems that the lab top is booting correctly but no screen. Can you help with this problem?
I would like to understand if the screen atleast flicker when the system is turned on. Is the screen power led lit on or flickering. In case you have no signal on the screen or no blinking also, you may have to get the lap for a HW repair as it could be a lap monitor HS issue. Else it should show atleast the initial screen while boot up as the screen would be working with the basic Bios Instructions which doesnt have any driver or complicated OS Code to run the screen. So ideally it should work at the initial stage of Bios to confirm that the screen has no hardware issue. Good Luck.
Feb 14, 2010 | Computers & Internet
Doesn't turn on, Red LED light stays lit
Try restoring the blackberry using the blackberry firmware update utility, if the problem persists, it's a logic board issue. there are blackberry repair websites that show you how to do the replacement yourself, otherwise here is a service that can repair any Blackberry Bold, Storm, Pearl, Curve, 8800 for screen, lenses,
track balls, usb ports, waterdamage etc.
The website is: Blackberry Repair
May 31, 2009 | RIM Blackberry Curve 8300
Pc will not power on .Press main power button on the front of the server,all fans work and front Disk LED glows yellow. Power LED at rear glows green but LED on the front(light bulb symbol) not lit....
Open the case and check the connection between the case power button and the motherboard. unplug that connection and short out the pins on the mb. The computer should start up. If it doesn't, there is something wrong with the mobo. If it does, there is something wrong with the switch, or the connector wasn't tight.
Sep 06, 2008 | Compaq Computers & Internet
Battery replacement navman icn530
Besides the two screws the back lit is "clicked" to the front lit. I used a small screwdriver and carefully pushed it in between the front and back lit and after some careful manouvering it clicked open at several positions. My battery was glued to the electronic print! Again using the small screwdriver and watching carefully not to turn on the power I was able to remove it. This procedure is certainly not an advocate of Navman! But in my case it worked ....
Aug 18, 2008 | Navman iCN 520 GPS Receiver
Kenmore HE4 no power to control, no sound, but the drum light bulb on when door opened
Another post reported replacing the power cord. I am trying to determine if this is a factory defect. Check the power at the power cord connections inside the dryer. You could have lost power on one leg and the other 120 volt leg is letting the light work. Let me know what the model and serial number is.
InMrFixIt
Aug 15, 2008 | Kenmore Elite HE4 Electric Dryer
No power/no led
first you need to check the fuse which is right on the inside after you take off the back panel. I suggest you get someone with electronic experience to help you
Nov 18, 2006 | JBL PSW-D110 Speaker
Cyberhome DVD Recorder - DVR1600 Logo
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
