Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door closes , than a few hours later it opens on its own it only does this during the day
    President:
  • 3,197 Answers
The most common cause of this is a bad wall control or the wiring going to the control. You can do a process of elimination by removing the 2 wires on the back of the wall control and later on you can remove the wire from terminal 1 on the back of the motor unit. Be sure to remember where the 2 wires go on the control as they are color coded.
Posted on May 15, 2009
The door on the freezer will not keep closed. What could be the problem?
There must be something your not seeing, get an extra set of eyes on it.
Oct 25, 2015 | Frigidaire LFFH17F7HW 16.6 Cubic Feet...
Liftmaster 3265M Garage Door Opener opens on its own
Sounds like one of your neighbors may have recently replaced their own garage door opener and it coincidentally operates in the same frequency band as yours. One of them may also have purchased a new car and recently programmed it to open their door, but it inadvertantly interferes with yours. Depending on the quality of your door opener's receiver and how old it is, some receivers are not as good as others in their ability to discriminate against similar transmitted codes in the same frequency band. When the door opens by itself immediately go outside and see if a neighbor's door has just been opened (or closed) at the same time. Does your door open by itself at similar times during day? Like when a neighbor might be leaving or returning home from work? When someone uses a remote to close their garage door when leaving home, they (and the remote) are usually located in their driveway, but when they use it to open the door upon arriving home, they might be located right in front of your house.
Nov 25, 2012 | Home Security
Why is Fridge not cooling well?
The part number you need is going to be WR09X10050. This is for the damper assembly, but while you are at it change out part number WR55X10150. this is the part that controls the damper and more than likely if one fails the other will be soon to follow
Jun 05, 2012 | Hotpoint Refrigerators
My husband took my Odyssey through the car wash in -4 degree temps. A few hours later after opening the sliding doors we couldn't get them to shut automatically. Today one door will open and close...
On the 05 Odyssey there's a problem with the rear latch assembly(about $140each) located in the rear of each sliding door. The problem is that the latch assembly was not seal proplery and water can get into the latch cause the sliding door to act funny. Maybe replace the latch assembly will help you.
Jan 19, 2011 | 2005 Honda Odyssey
Door open alarm come on when door is closed
I think you have a faulty door switch, you should try to replace it. Normally located at the top of the door frame.
Nov 06, 2009 | Sewing Machines
Door won't open at end of cycle
Thank You for contacting Fixya.com
The most common cause of this problem is
1. A faulty or broken door catch.
2. A faulty interlock. This is the part that the door closes in to.
also worth checking the spring inside the door lock mechanism attatched to the door, as these can become dislodged.
To open the door you will either require an engineer as the repair necesitates the removal of the lid. The engineer will ensure the machine is disconnected from mains of course. He will double check power is off before reaching down inside the machine to press over the door latch, which is just visible as a white pointed object, poking through the door mechanism. The engineer will push it towards the door seal.
Some older models have other devices that will prevent machine opening if it has not pumped out fully, or mechanical devices that check for drum rotation that can be knocked during the spin. Could really do with age and model No. of machine.
Have a nice day.
GodBlessU
Sep 12, 2009 | Asko W6021 Front Load Washer
Accidently started clean, food inside,hit cancel,can't open
you would have to disassemble the cook top in order to get the the locking mechanism to manualy unlockit
May 01, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Opened door on cycle, will not continue cycle after closing door
The most common problem for a dishwasher to not restart after the door being closed is a failed door latch interlock switch. Adjusting / repairing it is not too difficult.
Of course this assumes that the Dishwasher power circuit from the circuit breaker remains powered up.
Post back here if you are looking for more details.
Good Luck!
Apr 16, 2009 | Bosch 24 in. SMU40 Built-in Dishwasher
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
88 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
