SanDisk Sansa e200 MP3 Player Logo
Posted on Oct 16, 2007
Problems transfering playlists and files; plus a few others things.
1.After I have successfuly  ripped a CD, using Audiograbber and created a playlist using Real Player, I synchronize with my e280,or manualy transfer some songs and only to have them come up emply. The song info is correct, but the file size is 0. On a playlist it might be everyother song. On some rare occations, I've been able to change the file name and get it to work. Why would it rip correctly on computer, but not transfer all of the songs correctly to the player?   2.Also, on the player I see a large number of songs listed as Unknown, and/or Tracks do not appear when I look for them on the PC using Window Explorer. Any idea why not?   3. Somehow I seem to have deleted from the player the names of all the artists. I have no idea what I did or how I might get the info back.   4. Does it make any difference that when I first transferred songs to the player they were not placed in the Music folder, but went to the players hard drive?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Oct 29, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1284
Points
0
Forget using all those programs just do this go download lime wire beta install it ( use trial version its free and only nags u when u load the program from start ) then just download your songs put them into a empty folder and copy paste onto your music section of your sansa and it will work and be identical to what u originally found
2helpful
3answers
How do I transfer a playlist from I-Tunes to my I-pod?
Connect your iPod to computer, iTunes will detect the iPod automatically, then click iTunes menu "File -> Sync iPod", the songs will be transferred from iTunes to iPod.
Or You may try this ipod transfer, it's an iTunes alternative that can help you manage iPod files including delete, upload, play, copy, etc. It's much easier to use than iTunes. It can also help you manage multiple iPods on one computer or manage iPod on multiple computers, even copy music and video from iPod back to computer or iTunes. So you will not lose your iPod files even though you switch to a new iTunes library. My friends recommend it to me, it works pretty well.
http://www.ipod-transfer-copy.com/ipod-iphone-to-computer-transfer-cucusoft.html
Hope it helps. Feel free to email me if you need further help.
tip
How to Play iTunes Music on Windows Media Player
There's a good chance when you buy music from the iTunes Store that the files that you download will be copy protected by Apple's FairPlay DRM system. It's a great system that protects the rights of the artist and publisher by making it difficult for the consumer to distribute copyrighted material. However, DRM can also be very restrictive by stopping you playing legally purchased music on your MP3 compatible hardware. So, what happens if you want to play your DRM'ed music on a non-iPod?
This tutorial will show you a way to produce DRM-free music that doesn't require any special software that you would normally need to buy. All you'll need is the iTunes software, and a blank CD (preferably a rewritable (CD-RW)).
Before we begin, check for any updates that are available for your iTunes installation, or download the latest version from the iTunes website。
Configuring iTunes to burn and rip an audio CD
CD Burner Settings: In order to set up the iTunes software to burn an audio CD, you first need to go into the settings menu and select the correct disc format. To do this, click on the Edit tab on the main menu and select Preferences from the menu list. On the preferences screen, select the Advanced tab, followed by the Burning tab. First, make sure your CD burner is selected from the drop-down menu alongside the CD Burner option. Next, Select audio CD as the disc format that is to be written by your CD drive.
CD Import Settings: While you are still in the preferences menu, click on the Importing tab to access the CD ripping settings. Verify that the On CD Insert option is set to Ask to Import CD. Next, set the Import Using option to a format of your choice; the MP3 Encoder is your best choice if you want to import audio CDs as MP3 files that play on virtually all compatible devices. Choose an encoding bitrate from the Setting option; 128Kbps is the normal setting that is good enough for the average listener. And finally, make sure the Automatically Retrieve CD Track Names From Internet and Create File Names With Track Numbers and both checked. Click the OK button to save your settings.
Making a custom playlist
To be able to burn your DRM copy protected songs to audio CD you will need to make a custom playlist (File > New Playlist). You can add music tracks to a playlist easily by dragging and dropping them from your music library to your newly created playlist. For instructions on how to achieve this, why not follow our tutorial on How to Create a Custom Playlist Using iTunes.
While creating a playlist, make sure that the total playing time (displayed at the bottom of the screen) doesn't exceed the capacity of the CD-R or CD-RW you are using; typically, the total playing time of a 700Mb CD is 80 minutes.
Burning an Audio CD Using a Playlist
Once you have created a playlist, simply left-click it (located under the playlists section in the left pane), and then click on the File tab on the main menu, followed by Burn Playlist to Disc. The CD drive tray should now automatically eject so you can insert a blank disc; ideally use a rewriteable disc ( CD-RW) so you can reuse it multiple times. Before iTunes starts burning the DRM protected songs, it will remind you that creating an audio CD is for your own personal use only; once you have read this notice, click on the Proceed button to start burning.
Ripping an audio CD
The final step in this tutorial is to import (rip) the songs that you burned onto audio CD, back to digital music files. We have already configured iTunes (step 1) to encode any audio CD that is inserted into the CD drive as MP3 files and so this stage of the process will be mostly automatic. To start ripping your audio CD, simply insert it into your CD drive and click the Yes button to start. For a more in-depth look at this process, read the tutorial on How to Import CD Tracks Using iTunes.
Once this stage is complete, all the files that have been imported into your music library will be free from DRM; you will be able to transfer them to any device that supports MP3 playback.
Note:The only downside in using this method is that if you have a lot of files that you need to convert, then it ends up a slow and tedious process. With this in mind, use a legal drm removal tool if you have a large quantity that you need to convert.
on Aug 25, 2010 • Computers & Internet
3answers
My friend has given me an mp3 player to download cds on to but i'm not sure how to do this? I thought i might try spotify or itunes but i don't know if you can download cds off either of these sites on to...
Go to the player manufacturer's website. They should have software you can download that may make the process much easier. If not, on plugging the player into your computer, it should recognize it as an 'external' drive in which case you can treat it as you would with any external drive.
3answers
Make a new playlist?
To create an M3U playlist On your PC, create a new empty .txt document using word pad, type nothing but save the file as a .txt. go in to my computer -->> explore and find the file and rename the .txt document so it has an m3u file extension (example: my_list.m3u). Open the m3u file with wordpad, notepad, or a text editor. In the first line at top of the page type #EXTM3U. After the first line, start listing your music files, copy and paste the song names , (with extension ie .mp3). One music file name each line. Exit the text editor and save the m3u file once you are finished. Drag and drop the M3U playlist to the player's MUSIC folder, your done.
4helpful
How to create playlist on e260 sandisk sansa pm3 player
this is from sansa website FAQ... check it too for ur other concers... well i hope this is what ur looking for...
How do I create and transfer playlists into my MP3 player using Windows Media Player 11?
STEP 1 – Create a playlist
  1. Run Windows Media Player.
  2. Click Create Playlist located in the top left corner.
  3. Type in the name of your playlist.
  4. Drag and drop music files into the Playlist Window.
  5. Click Save Playlist to save the list.
STEP 2 – Transfer the playlist to your device
  1. Click the Sync tab on the top bar.
  2. Drag and drop your playlist from the left window into the Sync List window on the right.
  3. Click Start Sync.
15answers
How do i transfer Music to my Iphone from my computer, Once plugged into the computer the songs that are currently in the iphone are unhighlighted and cannot move songs to or from the iphone.. Please help
You need to create a playlist for the iPhone. This isn't intuitive and I don't know why it's this way. It works great, there just isn't anything explaining what to do. This seems to snag Windows users the most. Maybe Mac users are already used to doing things this way? I don't know.
Below is a picture of my iTunes. Look down in the lower-left corner and see that my playlist is highlighted. At the very bottom-left corner you can click the plus sign to create a new playlist. Then drag all of the music you want to the playlist. Finally, in the music tab of your iPhone, make sure you click the playlist you just made to sync all music on that list to your phone.
This will do the trick.
1helpful
I can't get a playlist onto my Sansa m240. I tried the method described on this site, and the name of the playlist came up, but said it had no files.
Creating Playlist
To create a playlist for Windows Media Player, follow these steps:
1. Launch Windows Media Player.
2. Clear the List pane by clicking the Clear List pane button.
3. Click the arrow below the Library Tab then select Create Playlist.
4. Type in the name of your Playlist.
Loading Content 14
5. Click Songs from Library then drag them from the Details pane to the List
Pane.
6. To rearrange the songs, drag them up or down in the List pane.
7. Click Save Playlist.
Transferring Playlists
To transfer playlists to your Sansa player, follow these steps:
1. Connect your Sansa player to the computer.
2. Select Sync digital media files to this devices using Windows Media
Player on initial connection.
3. Right-click on Your Sansa Player, then select Set Up Sync.
Loading Content 15
4. Select Personal Playlists from the drop down menu on the left pane.
5. Highlight the playlists you want to transfer to your Sansa player, click Add,
then Finish.
6. Synchronization will start as soon as you click Finish. To see the Sync
progress, click on Sync Results.
1helpful
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
2helpful
2answers
How to rip musc to my harddrive
Play Recordable CDs Containing MP3/WMA Audio Files
To play recordable CDs containing MP3 and/or WMA audio files:
Press the eject button on the Xbox 360 console (or select Open Tray from any area of the Xbox Dashboard) to open the disc tray.
Place a data CD-R or CD-RW containing MP3 and/or WMA media on the disc tray with the label facing up (to the right if the console is vertical).
Press the eject button (or select Close Tray from any area of the Xbox Dashboard) to close the disc tray.
Go to the Media area of the Xbox Dashboard. Select Music, Current Disc.
To play all tracks on the CD, select either Play All or Add to Current Playlist.
If you have an existing playlist open, Add to Current Playlist will append all tracks on your current CD to that playlist. Selecting Play All will clear a current playlist and create a new one consisting of all the files on the current CD. (Be sure to save your playlist, if desired, prior to selecting the Play All option.) Files are added to a playlist in alphabetical order by file name. Playlists start again from the beginning once the final track has played.
riz.
2answers
IPOD ? playlist backup
If your IPOD is set to automatic song transfer, and you created an ?on the go? playlist, the IPOD will automatically transfer all songs along with the playlist. I haven?t tried the following myself yet, but this is the only way that I can think of: Cancel the auto transfer option ? from the source list in itunes choose the iPod icon and press on the options button. Choose ?manually manage songs and playlists? If it doesn?t work then I guess its more of a one directional thing, that you get more options going from the PC to the iPod then the other way around.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
