Question about Sony DR-BT21G Wireless Headset
Hi. I have bought two pairs of Sony blue tooth headpones. I have connected them to an ipod via a Sony adaptor. Both headsets will not receive a signal in the left ear piece. What should I do?
  • 4 more comments
  • marcshaw May 15, 2009
    The adaptor is specifically for the ipod. Is there way of getting sound in both ears?
    I have 2 sets of blue tooth headphones (DR-BT21G) they come with a special adaptor for the ipod but only play sound in the right ear. What can I do?
    I tested it on my wife's Ipod and the same thing happened.
    The adaptor is specifically designed for the Ipod.
    Is it possible that Sony would sell an adaptor that wasn't stereo?
    I have two pairs of blue tooth stereo heaphones. They come with an adaptor specifically for the IPOD. I have tested them on two IPODS but both play only in the right ear. Any ideas?
    I went to EQ but there is no Stereo/mono option.
    the model number of the headphones is dr-bt21ik.
    the bluetooth transmittor is tmr-bt8ip
    thanks.
  • 103 Answers
The adapter has to be defective. Theres just no other explanation. if you look at the plug that goes into the ipod is there 2 black circles? or just one.
Posted on May 16, 2009
  • 355 Answers
Which model of bluetooth headset you are using?
Posted on May 15, 2009
  • Rohit  Asthana
    Rohit Asthana May 15, 2009
    i means which model you are using give me some specific model like sony- model no 1234
    this will help me to track the problem easily....
    on starter prob i think prob is that you set it into the mono....you have to just change it to sterio...
    waiting for your reply
  • 916 Answers
If you have another ipod or know someone who does test them in that. If the problem is not there then the port on your ipod is malfunctioning and needs to be repaired. If it does have the same problem then the adapter may be mono and you need a stereo adapter.
  • machadojr_fe May 15, 2009
    It is unlikely but possible I would check the package to verify
    President:
  • 987 Answers
The sony adaptor converts audio to mono in place of stereo so you are haveing sound in only one side ...
  • Sibananda May 15, 2009
    go to the setting selection on the main menu of the iPod and select equalizer. you can change the sound settings there. there u can can change sound output from mono to stereo...
I need to pair my bt2050 up to a new phone,it was originally paired wit another phone that i do not use anymore,im using a nokia x3 now and when im trying to find and pair up it says there is no device...
Hi Barbara,
Please follow the below steps, i hope your problem is resolved :-
  1. Make sure that your phone's blue tooth is out of hidden mode and , it now shows up as shown to all, in the connectivity settings.
  2. Make sure that you delete the pairing from the other phone , via it's blue tooth settings, if you are not using the phone and it's switched off , then you don't have to worry about it.
  3. Switch off the bluetooth and restart it , so that it's ready to accept new connections.
  4. Now go in your blue tooth option and search for a new paired device , it should reflect your Jabra blue tooth.
  5. If the above method does not work , sadly your phone does not support the Jabra blue tooth.
  6. You should also try connecting this blue tooth to someone else's nokia phone to check compatibility , if it's compatible with the other models, that means X3 is an exception to this compatibility.
Hope this helps.
May 11, 2011 | Jabra BT2050 Bluetooth Headset
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
CANNOT GET TO PAIR says it is but is not connected
Hi, It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps.
Thanks for using fixya.....
Nov 29, 2010 | Jabra Bluetooth Headset with Adjustable...
Code for sony dr-bt100cx bluetooth
Hi, when you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Hope that helps...
Nov 25, 2010 | Sony DRBT100CX Bluetooth Headset
How can I put use it on my samsung phohe
Hi, Problem solved. All you need to do is to know how to pair the headset with your phone. Ones you pair the phone to your headset,your done..
Hope it helps...
Oct 29, 2010 | Mizco Radio Communications
Need password to connect to my phone. Motorola bluetooth H371
Hi,it all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Hope it helps..
Oct 27, 2010 | Motorola Mobility H371 Bluetooth Headset
How to put a hbh705 into pairing mode
Take care.
Aug 06, 2010 | Sony Bluetooth Headst HBH705 Sandcolor...
How to connect sony ericsion w395 via blue tooth
Take care.
Jul 07, 2010 | Sony Ericsson W395i GSM Quadband Phone ...
Problem in transfering file via bluetooth
Take care.
Jun 17, 2010 | Sony Ericsson K750
Cellnet Pico Bluetooth Headset wont connect to nokia 5800
Take care.
Jun 10, 2010 | Cell Phones
Sony DR-BT21G Wireless Headset Logo
297 people viewed this question
Top Sony Radio Communications Experts
 Grubhead
Grubhead
Michial Gueffroy
Rob Beech
Are you a Sony Radio Communication Expert? Answer questions, earn points and help others
