Home | Nokia | IP380 Firewall | How to identify a IP3...
Nokia IP380 Firewall
Problem for Nokia IP380 Firewall
How to identify a IP380 is online
By zy_yong on May 15, 2009
We know the ping test is blocked be default at IP380 firewall. How can I identify the firewall is still on-line. I only have the IP of firewalls.
Thanks.
Cliff
Comments:
Jun 16, 2009
- @jcoady Thank you. But none of above method works after I tried to telnet the ports 22,80, or 21. Is there any policy blocks this. My PC is in the safe subnet of firewall. However, I don't have any management/monitoring permission. I only have their IP address.
Solution #1
posted on May 21, 2009
Not Rated)
jcoady
Rank: Guru
Rating: 86%, 44 votes
If you know the IP address then you have two choices:
Indirect method: Test a 'listening' port on the firewall. For instance, if there is a web server behind the firewall, check HTTP (TCP/80) or FTP (TCP/21).
Direct method: If it is enabled for remote management you can check the remote management port, typically SSH (TCP&UDP/22).
If you've never done port level testing there are a number of ways to do that. Microsoft provides a commandline tool named portqry: http://www.microsoft.com/downloads/details.aspx?familyid=89811747-C74B-4638-A2D5-AC828BDC6983&displaylang=en
As well as a gui interface for it: http://download.microsoft.com/download/3/f/4/3f4c6a54-65f0-4164-bdec-a3411ba24d3a/portqryui.exe
For instructions please visit http://support.microsoft.com/?kbid=310099.
Comments:
Jun 15, 2009
- Are you now able to monitor the firewall?
Which method did you use?
I forgot to mention using SNMP queries, but it sounded like you were looking for a less direct method of identifying the firewall status.
Jun 18, 2009
- It sounds like your only option is passive monitoring, which means you must know what is allowed to pass through the firewall and test communicating with the 'allowed' device. It helps to have more than one to test against, since the firewall could be 'up' and a single device could be offline. That's where the port tests mentioned above will come in handy.
For instance, if a web server is allowed passage, you could check port 80/TCP against it's IP (not the IP of the firewall).
Do you have any insight into what is allowed through? It helps to know both outbound and inbound allowed activity. In some rare instances a firewall is established with no allowed activity, waiting for that first request. Maybe you could request passage for a couple of devices outside your firewalled area and use them to test against.
Good Luck!
Was this helpful?
Yes
No
Popular Solutions for Nokia IP380 Firewall
Questions and Unsolved Problems for Nokia IP380 Firewall
Do you recommend Nokia IP380 Firewall?
Answer
Answer
I have a netgear router with a double firewall aol cannot connect
Answer
maintenance service for firewall IP380
Answer
I have a Nokia IP380 that I am trying to reimage a hard drive for. Another IP380 that is full... (More)
Answer
Hi, My IP380 is installed with Checkpoint firewall software. The equipment is installed in a LAN... (More)
Answer
Does anyone have the proceedures to load a harddrive from scratch on a Nokia IP380? I have the... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nokia IP380 Firewall:
Top Firewall Experts
Rank: Guru Guru
Solutions: 1133
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Firewall Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
