Question about Toshiba Satellite Laptop with AMD Turion X2 Ultra Dual-Core Mobile Processor ZM-80 - Fusion PC Notebook
Screen White Out
I bought a laptop last year and have pretty much had no problems with it until here recently. I treat it as gently as possible and have had no major drops or dings on the unit but here recently, when i open the laptop, the screen whites out in certain spots. (by that i mean certain positions of the lid, the screen is always full white out when this problem occurs) I am fairly certain that it is a lose cable from the display card to the monitor but am not very skilled with laptops. I have the warranty from bestbuy and the warranty from toshiba, but if its as simple as plugging back in the cable i dont want to use it or lose my laptop for a few weeks either. Any ideas as to anything else it could be? and if not, maybe a tut on how to take apart the laptop and get it back together? thanks ahead of time.
  • Frank Zhang
    Frank Zhang May 11, 2010
    it is better you bring to the shop because it is in the warranty. and no better yourself fix. now
No display when turned on
if you recently turn on the laptop but the screen doesn't show up not even a just a white screen then probably the power connection of the screen is broken, if just a white screen and no other display then you have a broken flex, a ribbon cable, other posibilities is that you might have a busted laptop. try removing the battery and plug directly to your power cable, long press the power button until you see led light turning on,. if your still not sure, you better bring it to a techinician, or to the store were you bought it if it still has the warranty.
Apr 04, 2014 | NEO Computers & Internet
Is it better to buy a stiff baseball glove or one that is already broken in?
As a pretty avid baseball player, I through about two gloves every other year. I personally think that it is better to get a stiff, strong leather glove so that you get more use out of it and mold it exactly to your hand.
Feb 06, 2013 | Baseball & Softball
My recently purchased used Compaq Presario V2665US notebook has a horizontal white line at the bottom of the screen below the windows Taskbar. The line actually cuts into the bottom of the Taskbar a...
the old dog Presairo. id buy something newer, sure would
2005 carbon dated by me? 12 years old now,
buy a used LT at Goodwill with Coa sticker with W7 on it.
and never any compaqs unless 2010 to 2013(last year made 13)
the best PC is one that is supported in 2017
and has future.
and not buying parts that cost 2 to 10 times
what yours is worth. right?
Time to upgrade, its not hard, the USA is in glut status in used PC. (vast numbers are scrapped here)
or sent to 3rd world. (on ships)
why post not telling the OS (oper.. system?) making answers 10 time more hard.> why?
no photos of said lines, pretty hard to tell in words what a complex screen shows. no? my guess is the screen is bad.
that is why you found it for nothing (hope) and 50 to $100 fix plus labor.
this no monitor, its Laptop screen so there are NO size buttons.
right click the screen desktop see those choices, that is all you get.
or control panel click display ,wysiwyg.
the lines,
if you gently twist the screen with 2 hands, do the lines change
i bet yes, telling you what?, "bad screen"
if you plug in a Desktop VGA screen to the rear.
then push FN+F4 key and pick external or both , bingo
you get that external screen working and now it works , right?
this PC is now listed as retired at HP
best is to own a PH that is 10 years or less old.
for sure.
NO OS stated. by you.
both XP and VISTA have no Support now.
zero. and will get worse.
(cost of ownership huge and down time endless)
Aug 17, 2017 | Compaq Presario V2665us Notebook
Hello. My SONY KDL-32M3000 gets vertical white lines when started then dark screen with ghosts. Tried to contact SONY but, no help Tv is out of warranty. Is that possible for a SONY tv ?. Is that the...
man, same problem here!! we got this tv, the same model as the one you have, we got this last 2008.. so basically its already 2years.. and last night.. i got this white stripes that are vertical then suddenly shuts down.. i dont know what to do.. im pretty sure sony wont cover this cuz its already more than a 1yr we got this tv, but still.. i cant believe tv like this has a short life span.. our old box tv was even more better.. it lasted 6yrs!!!
Sep 23, 2010 | Sony KDL-32M3000 32 in. LCD Television
HP Pavilion dv4ee LCD problem
u bought ur laptop in march 2009 and have 1 year warranty , i think u much take to brand hp to warranty, ur lcd have problem
Jan 16, 2010 | HP Pavilion dv4000 Notebook
Light on the screen suddenly disappers
there is a invertor (fluresan invertor) in the LCD. invertor makes your lcd white, bright , lightly.  i think your invertor is breaking down. take the laptop to service.  sorry for my english.
May 27, 2009 | Sony VAIO Notebook
ACER 3680 2022 LCD SCREEN PROBLEMS
It may not be a problem with the lcd.
This is most likely a problem in the video card of the laptop.
but you can test it out, if you plugin a extra screen to the laptop to see if the white dots come to the other monitor aswell.
If you see white dots in both of the screens this means the video card is about to fail. and would need to be replaced.
If you don't see any white dots on the external screen then the problem is in the lcd.
You can call bestbuy they should give you another phone number to call for repairs / parts.
Jun 10, 2008 | Acer Aspire 3680 PC Notebook
The inner screen of the monitor on the laptop has cracked and it is showing vertical lines
Hi. Not much you can do except treat it very gently until it's replaced. But if you are on a budget and want it to last a while just be really careful about moving it, and opening and closing it.
Cheers!
Apr 10, 2008 | Computers & Internet
HELP!!! Cannot start VAIO ARG230G
do safe mode, and find out if your disk is clean or overly fragmented
Mar 12, 2008 | Computers & Internet
Toshiba Satellite Laptop with AMD Turion X2 Ultra Dual-Core Mobile Processor ZM-80 - Fusion  PC Notebook Logo
222 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
