Question about Bose ® QuietComfort® 2 Acoustic Noise Cancelling® Headphones Headset
My front pc headset cant be used
When i plug my headset at my pc back i cant hear the voice,, but when i plug it at front. its not work
  • Coldtoon
    Coldtoon May 11, 2010
    dose the front work with other types of headphones
I can hear their voice but they cant hear my voice
There's a problem with your headset, check your headset, it was your mic is not working try another headset. Or download and install audio drivers for your PC with the specific model upon downloading.
Sep 25, 2011 | Google Talk
I cant hear the game sounds through my headset i can only hear people voices, and i have everything plugged in the right spot
Some games only transfer people's voices to the headset while others transfer all the sound. Check your game setting for headset options
Jan 18, 2011 | Steel Series Spectrum 5XB Xbox 360 Headset
Mic is synced but cant use online
my problem is the mic wont syncronize and wont respond to my voice and i cant hear other people through it .it still flashes blue and charges fine
Aug 30, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
Mic broke
Try using your X1 with your computer. Plug the X1 green plug into the green jack on the PC. Plug the X1 pink plug into the pink jack on your PC. Try using the headset to listen to the sound of your voice. Can you hear your voice through the headset? If yes, then the mic is OK but the chat-controller cable needs to be replaced. If not, then you should contact Turtle Beach tech support at support@turtlebeach.com.
May 23, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
Cyber acoustic ac 208
The issue lies in the glass fiber wire, the wire is coated with a conductive metal only a fe mircons thick.
Simply put the headset is a poor production model, the use of glass fiber wire more often than not results in a short in the wiring. Thus the sound will come out of one side, not at all, etc.
Jan 25, 2008 | Cyber Acoustics 3-in-1 Headset/Mic Headset
Logitech headset - sound
me too! but I am using XP
Oct 06, 2007 | Logitech Premium Headset
Logitech headset, new vista operating system
either the headset is not supported by Vista, or you need to right click on both speaker icons, normally coloured red and black and in the properties you need to see if your headset is listed as one of the microphone input devices, if you need to make the Logitech headset the default mic and not the windows generic mic. If you do not see it in the properties then it may not be recognised by Vista.
Aug 13, 2007 | Logitech Internet Chat Consumer Headset
Echo problems
Check that the MIC is muted in the volume control but not in the recording settings. This could just be feedback.
Mar 20, 2007 | Plantronics .Audio 340 Headset
Cant talk
Try going to Control Panel -> Sounds and Audio Devices Click on Voice Tab and make sure the proper device is selected. Click on Volume and make sure levels are appropriate. Lastly, click on Test Hardware and wait until you can speak into the mic to see the voice levels. If you can see the voice levels, then your mic probably works and it is just an issue of configing the COD settings. goodl luck
Mar 15, 2006 | Altec Lansing AHS-502 Headset
Radio Communications Logo
Top Bose Radio Communications Experts
 Grubhead
Grubhead
Michial Gueffroy
DIY-Dan
Level 1 Expert
Are you a Bose Radio Communication Expert? Answer questions, earn points and help others
