Question about Washburn Amplifiers: 25 WATT Guitar Amplifier - Bad Dog - BD25R Car Audio Amplifier
My paeveybandit 112 is buzing when i turn it up
Hi i have a peavey bandit112 80 watt i love this amp but when when i turn it up it starts to buzz but when i give it a thump on the right hand side the buzzing stops please can enyone help thanks john
  • wesean44 May 17, 2009
    ok thanks a lot im goning to try that illkeep you posted weesean
  • 4,234 Answers
Check the power supply area for bad connections especially near the large capacitors. If one or more of those are disconnected, the DC voltage will have some noisy AC on it that will sound like a buzz.
Keep us posted.
Dan
Posted on May 15, 2009
Hi. I would suggest there was a dry joint in the power supply section or on the 'earth' side of the input jack socket. If you know about electronics this could easily be fixed. Make sure the amp is switched off and unplugged from the power first. You would have to take the chassis out of the cabinet and gain access to the under side (solder side) of the PCBs. You can then check for dry solder joints or even cracked printed circuit. These are very common faults. If you need to know what dry joints look like then go to about-guitar-amps.com where you will find some useful photos that will help you out.
Good luck
David
Test Electronic Components
Posted on Jun 15, 2009
Peavey problems
Numerous possible issues with your description. I would start with the tubes, and check if not one or more has faulted.
Jul 19, 2014 | Peavey Valveking 112 - Tube Guitar...
Peavey studio pro 112
Sounds like blown power amp / transistors. Don't switch it on anymore otherwise it will damage your transformer!
Feb 04, 2014 | Audio Players & Recorders
Peavey 6505 plus buzz...even when all controls on zero and no guitar plugged in
Sounds like a bad power supply filter cap...the buzz you're hearing is the 60 cycles hum that filter caps reduce or (hopefully) eliminate altogether. It may also be related to the tubes but finding the bad one will require some work. Any friends have this same amp? If so, try swapping one tube at a time and see if you get lucky. If this amp is new take it back ASAP as it is a manufacturing defect.
Dec 27, 2013 | Peavey 6505+ 112 Combo Amp Combo
Peavey bandit 112
have you tried using a foot pedal? Are you sure it is switching (green light turns red, etc?). On the lead channel are you turning up the gain all the way and the volume down?
Oct 12, 2013 | Music
Peavey Vypyr 30watt service manual
Have you tried requesting from Peavey directly? customerservice@peavey.com
Sep 23, 2011 | Peavey Vypyr 30 112 Guitar Speaker Cabinet...
I have a Peavey MAX 112 Bass Combo amp. When I turn on the amp and have it plugged into the cord and bass, it immediately begins emitting a "whump whump" sound similar to the sound a beating...
The amp is doing what is called "motorboating". This is usually caused when the voltages to sensitive preamp stages are inadequately filtered or regulated and the sudden load of the output stages cause a dip in the voltages sent to the preamps which in turn vary the input to the output stages starting the cycle over. This will require electronic troubleshooting and if your not skilled in that, then it is NOT a DIY fix. What you are seeing is NOT normal, there is a defect.
Apr 22, 2011 | Peavey Electronics Peavey Max 112 Bass...
How can I download a new owners Manual for my amp?
You can go to Peavey.com, support and seach manuals or go to: http://www.peavey.com/search.cfm?c=3&term=Ecoustic+112
I hope this helps and if it does would you mind rating the solution. Thanks
Nov 30, 2008 | Peavey Audio Players & Recorders
Washburn Amplifiers: 25 WATT Guitar Amplifier - Bad Dog - BD25R Car Audio Amplifier Logo
230 people viewed this question
Top Washburn Car Audio & Video Experts
xxxxxx xxx
Are you a Washburn Car Audio and Video Expert? Answer questions, earn points and help others
