Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
How to remove rear wheel of lawn tractor
The tractor is a mtd limited edition model# 136M675G192
  • 376 Answers
You should be able to remove the bolt from the center with a 1/2" socket an slide it off the axle. You do not want to do any heavy hammering on the wheel because you could possibly drive the axle out of the transmission. MTD mowers are notorious for being hard to get the rear wheels off. If you do get them off or ever buy a new one, remove the rear wheels and coat the axles with anti-seize compound. Good luck
Posted on May 15, 2009
  • vern May 14, 2013
    with mine axle has come away from transmission. What next?
  • john wood Oct 10, 2013
    i just did the same .axle came out now what . what did you do
How do l remove both rear wheels from a mtd lawnflite mower
depends which model,but undo the 1/2" bolt in the centre of the wheel and slide wheel off axle. However by experience i know that if the axles havent been removed and axles greased regularly then you will have trouble getting them off, You will need to spray wd40 or similar dowm the axles and then jack up rear of machine, get a block of wood and a big hammer and knock the wheel from the inside while sprying wd40 onto the axle every time the wheel moves a bit
Feb 17, 2015 | Mtd Garden
Why doesnt my MTD 42" lawn tractor move but it will start?
If the transmission is belt drive, check the belt, worn/oily? If you have a hydrastat tranny, make sure that the bypass plunger is pushed in. Check that the belt goes around the tranny pulley. If still no luck, turn mower off, jack up and support the rear frame, with the real wheels hanging in the air(just an inch or two is plenty) try turning the wheels -1st, with the gear selector in "N". then 2nd, with the gear selector in "D". This should narrow the problem down a bad tranny or a sheared keyway in the axle.
Jun 03, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How to remove rear drive wheels on old MTD 21
Daren Ingold's suggestion works only for the right rear wheel on my 19+ year old MTD Yardman 21" self propelled mower. The ratchet spur on rear left wheel is held on by a bolt in the center of the axle and a spline. Remove the center bolt and washer. Pry the ratchet spur off the spline by using three medium blade screwdrivers wedged between the wheel and the spur gently tapping the three screwdrivers in succession until the spur is half off the spline. It will come off easily after that. Remove the spur, noting direction, and remove the wheel and replace it with one of the front wheels (they're all the same design) if it is in better condition and use the rear wheel for the front. Good luck ever finding a new replacement for this particular wheel. My mower is 19+ years old but runs perfectly otherwise. Stored in dry basement.
Sep 23, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Mtd removing rear wheels from axel
Be very carefull, if you pull the wheels hard enough the half shaft will pop the circlip on the inside of the gearbox and come away with the wheel, this will then require a gearbox strip down, leave it soaking in penetrating oil and try again.
Jul 11, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
Rear wheel is broken need replacement
I believe they carry them at Sears, since many of the Sears mowers use the high wheels. Tractor Supply also has a pretty large selection of mower wheels. Best of luck to you.
James
Aug 25, 2011 | Mtd 22" White Outdoor Self Propelled High...
I purchased a older MTD 12 HP lawn tractor. How do I remove the rear wheels in order to replace the tires? Do I need a special tool. I can not see anything to put a wrench to.
theres a screw and a bell washer in the center of the rear wheel , maybe covered by a cap, check this link for a breakdown on that machine as its what I located with the specs you gave http://www.searspartsdirect.com/partsdirect/part-model/Mtd-Parts/Riding-mower-tractor-Parts/Model-33925A/0736/1509200/WL000275/00009
http://c.searspartsdirect.com/lis_png/PLDM/WL000275-00009.png thats the rear wheels diagram
Jul 11, 2011 | Garden
Remove rear wheet
YOU'LL NEED AN EXTENTION FOR A SOCKET,BUT 1'ST REMOVE THE LITTLE CAP AND REMOVE THE COTTERPIN,MAKE SURE IT'S IN GEAR IT WILL KEEP THE WHEEL FROM TURNING.hope this helps
Apr 25, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
18.5 hp MTD lawn tractor has some type of transmission problem. Will not move causing belt to slip and burn. When rear wheels are jacked up and wheels are turned by hand they turn in opposite directions
When the back wheels are on the ground...can you push or pull the mower??
If not, the brake is jammed and needs to be repaired/replaced
Mar 31, 2009 | Garden
Hi Folks,
Try using penetrating oil and soak it up good tap the inside easy a few times hopefully it will break loose.
Mar 16, 2009 | Garden
REAR WHEEL REMOVEAL
it depends on which style mower most ayp (poulan craftsman husquvarna....) are put on with a e clip they may become froze to it but can be removed. now most mtd (yard man yard machines bolens troy bilt...) have a revers thread bolt with a tapered shaft trust me i worked on theses for 10 years. why would you want to take it off anyway? everything can be done with it still on
Dec 08, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
1,030 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
