Question about SanDisk Sansa e250 MP3 Player
Refresh Database??? When I turn on my Sansa e260 MP3 the menu says "refresh database", briefly stays on, then shuts off and starts again and so on. I tried the previous advice for updating the firmware but then I get an ERROR message saying "Application failed to read the version details". Any help is greatly appreciated!!!
Re: Refresh Database???
Dude, i have the same problem and it sucks. pls do inform me if you came up with a solution.tnx
Posted on Oct 30, 2007
  • 626 Answers
The application failed error means the you have a different version, not supported by this file.
You have a Rhapsody version.
You will need to contact SanDisk to have the recovery files sent to you.
SanDisk Technical Support 1-866-726-3475
Best of Luck.
Posted on Oct 16, 2007
0 characters
3 Points
Refresh database
I think that there is viruses on it. Try to scan it and see what happened.
Feb 24, 2010 | SanDisk Sansa e260 MP3 Player
Can't get past "Refresh Database" Screen
Try taking it back to the shop.
If not go to
Jul 21, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260 frozen on refresh database
Make sure USB mode is MTP....If this doesn't work make sure that you are connected to a 2.0 USB port....I had to install the update on to my labtop and finally it recognized it and updated
Push the power button in until it turns off then proceed with the above
Apr 11, 2009 | SanDisk Sansa e260 MP3 Player
"Refresh Database" never ends!
If you try to load too many songs onto the player initially, it may take up to an hour to get past Refresh database. Unfortunately, if you shut the player off while it is refreshing, it will more than likely ruin your player. Run the Sansa Recovery Tool or Update the Firmware on your Player as a workaround. Make sure the hold/lock switch isn't activated, just as a safeguard.
-Tha Mp3 Doctor
Mar 17, 2009 | SanDisk Sansa e250 MP3 Player
Refresh database error
Used the Firmware Updater to get the latest firmware and this updated my Sansa E260 player which was in Recovery mode. The player then completed the refresh database process. No data was lost. The player is now functiining correctly.]
Jul 27, 2008 | SanDisk Sansa e260 MP3 Player
SANSA e260 will no longer get further than 25% of refresh database & freezes
I would recommend that you update the firmware on the device..Once the firmware is updated you shouldnt have that problem anymore..I hope that helps
Please rate accordingly
Thank you
Mar 17, 2008 | SanDisk Sansa e260 MP3 Player
Refresh database on screen
how do you put on recovery mode?
Dec 01, 2007 | SanDisk Sansa e260 MP3 Player
Frozen screen says: refresh database
tyr taking the battery out or try holding the power button and the play button at the sametime for 20 secs.
Oct 21, 2007 | SanDisk Sansa e260 MP3 Player
"refresh database failed" how do I do a database refresh?
i have the same problem ... refresh database fail .. i can put songs on the player but it doesn't show them or play them :-( HELP!!!!
Nov 15, 2006 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
76 people viewed this question
Top SanDisk MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk MP3 and Digital Media Player Expert? Answer questions, earn points and help others
