Question about Weather King 10AJA4201AH Air Conditioner
Is there a reset for the a/c unit itself
Yesterday the air conditioner was working fine, turned on today and nothing, not a sound. the breaker box has no tripped breakers, I reset the control panel. is there a reset for the a/c unit itself, weather king model #13AJA36A01 manufactured 03/2006
  • 116 Answers
Check for fuses in disconnect at the out door unit or a reset button where the copper line set goes into the unit at make sure stat wires have not been damaged hope this helps
Posted on May 15, 2009
It wont turn on
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem.
For more a/c information check us out at AC Service West Palm Beach
Apr 26, 2016 | Heating & Cooling
My fan and heater work fine, but today I turned on my air conditioner for the first time this year. It did not feel like it was getting cooler so I went outside and noticed that my outside unit was not...
You had a refrigerant release. Probably two lines rubbing together in the outside unit. I have
repaired several of these with this problem. It involves repairing the lines by silver soldering
then pulling a vacuum/ purging with nitrogen and installing a filter dryer and recharging
system. Several hours work, and you must have a licensed tech do this as refrigerants are
involved. Luckily you were able to shut it down quickly (this helps).
Feb 22, 2011 | Carrier 36KCARMS Air Conditioner
I have a goodman CKJ42-1B air cond. unit. It keep tripping my AC breaker although continues to blow air - just not cool air. Once I turn OFF then ON the breaker the AC works fine for about a day. Then...
try cleani ng the unit outside with your garden hose first .sounds like its kinda dirty .the dirty er the coil is the higher the amp draw is when it is running .what size is the breaker in the box .thats a 3 an a half ton condensor
Aug 06, 2010 | Goodman CKL36AR36 Air Conditioner
Wont turn on
When you turn on the cooling, does the blower inside run? On the indoor unit, is it a air handler or a gas furnace?
If the indoor blower runs, then the eastiest thing to check is the A/C breaker and near the A/C there should be a disconnect box, usually has fuses located inside of it,,,,,turn off power at the breaker before opening the disconnect box, the fuses will have to be ohmed out, you can't tell anything just by looking at them.
What brand is the system?
On the thermostat, if you switch the fan to the "on " position, does the fan come on?
Please check this stuff out, and get back to me and we'll see if we can figure it out for you.
Sincerely,
Paul Gibson
Apr 04, 2010 | Heating & Cooling
Duo therm AC/ furnace in Puma not kicking on
there is a "control unit" inside the bottom cover of the A/C on your cealing ... inside there is the control box that controls itself. Has a silver peice bout 2'' thick and the size of a quarter this is your freeze control, if your A/C gets TOO cold and might damage itself it kicks on and shuts down your unit(yes even your furnace) need to have a tech come out and fix/replace it, RV Tech, most A/C repair companies know NOTHING about RV's
Nov 17, 2008 | Dometic Rooftop RV Air Conditioner
Carrier air conditioner
Sounds like you either blew a transformer, have a bad circuit breaker or blew the main fuse in the outside disconnect. If the indoor unit is still blowing air (no matter what temperature) start looking at the power supply to the outdoor unit. From the circuit breaker, the power will go to a small box located within a few feet from the outside unit. This box will have either a lever on the side or you will be able to open the box and pull out the fuses. From this box the power goes to the condensor. The first thing you should do is to turn off the breaker to the outside unit. Flip it back on and if you have a call for cooling, after about 3 minutes the outdoor unit should start. If it does not, shut off power again to the unit by switching off the breaker, go outside and pull out the fuses in the disconnect box. Using a multi meter, check for continuity thru the fuses. If you have continuity, call your technician. If one or both fuses show no sign of continuity, replace the fuse(s). Make sure that the thermostat is working and sending a signal to the indoor air handler. You may be able to check this by turning the fan switch to "Fan" and see if the blower turns on. You may just have a bad thermostst. Caution should be used anytime you are near electrical components. If you do not have the skill-set required to test electrical equipment, leave it to a proffessional.
Sep 03, 2007 | Carrier 38CKC036 Air Conditioner
Weather King 10AJA4201AH Air Conditioner Logo
1,254 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
