Question about GE Nautilus 24" Built-in Dishwasher
Water in bottom of GE Nautilus dishwasher
I don't have the manual for this dishwasher. I have noticed the water is not draining completely. Pls help. thanx joann
I was having the same problem and downloaded a copy of the manual and found out it is normal for a couple of inches to remain in the tub! I can't remember where I downloaded the manual, but you can "Google" it like I did. Hope this helps :o)
Posted on May 19, 2009
Water didn't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 19, 2011 | GE Nautilus 24" Built-in Dishwasher
My 24" Nautulis dishwasher will
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Jan 29, 2011 | GE Nautilus 24" Built-in Dishwasher
Won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please note that dishwashers don’t drain out the complete water such that heating element doesn’t overheat.
Daniel
Aug 07, 2010 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
How do i drain my ge nautilus dishwaher
Pour hot water into the bottom and force the timer to drain cycle. Keep doing this until the suds are gone.
Aug 18, 2009 | Dishwashers
Water will not fully drain
put two dishwasher tabs in machine and run it as norm may be too much lime scale
Aug 18, 2009 | GE Nautilus 24" Built-in Dishwasher
Water not completely draining from dishwasher
clean and inspect pump broken fins may need pump kit
Aug 15, 2009 | GE Nautilus 24" Built-in Dishwasher
Water not draining completely from Dishwasher tub
That usually happens because of a faulty water level sensor, check it out.
May 12, 2009 | GE Nautilus 24" Built-in Dishwasher
GE NAUTILUS GSD3200-J00WN DISHWASHER WON'T COMPLETELY DRAIN
Dishwasher Problems - Water will not drain out
heatman101
Dec 27, 2008 | GE Profile PDW9880NSS Stainless Steel...
GE Nautilus 24" Built-in Dishwasher Logo
536 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
