Question about Garden
String broken inside spool - Garden
5 Suggested Answers
  • 130 Answers
SOURCE: string wont advance from spool
sometimes thows automatically spool go bad
afterwhile.get a new one
Posted on Jul 21, 2009
s_s_m_o_k_i_
  • 162 Answers
SOURCE: String caught in spool. Need to remove spool but
look for a notch in trimmer head above spool close to shaft and corrosponding notch in shaft.
these notches are for holding shaft in place with a screwdriver so you can losen the tap cap screw...
speakin of screwdrivers anyone see where my vodka went?? lol
Posted on Jul 31, 2009
SOURCE: Echo srm-225 string broke off inside of the spool.
I solved the problem myself. I found the manual online and followed the directions that were given. Having the manual helped because it allowed me to know how to open up the spool without damaging it.
Posted on Oct 01, 2009
  • 18 Answers
SOURCE: The string on my spool ran out.
• Turn off the trimmer and remove the battery
• Press the release tabs on the line spool cover and remove the cover by pulling it straight off. replacement spool is AF-100
• Lift the spool of nylon line out of the hub and clear any broken line and debris
• In case of jams and tangled line unwrap about one foot (30cm) of line to ensure that it is undamaged. If it is OK rewind it and insert the line end through the eyelet in the spool hub.
• Pull the line through the hole to maintain tension while placing the
spool down into the hub with the notched side exposed.
• Press the spool down GENTLY and rotate it until you feel it drop into place. (When in place, the spool will turn a few degrees left and right freely.)
• Snap the spool cover back on.
Posted on Jul 08, 2010
I need to know how to restring my Twist & Edge RTE weedeater. I've looked everywhere & can't find an answer that makes sense. PLEASE Help.
I found this solution on the net. I hope it helps.
Unscrew cap and remove. Remove line guide ring. Note which way to put line guide ring back on, slot to outer edge. Remove the empty spool.
Don't take spool apart unless you need to get inside to remove string. The outer half should be yellow. Cut 25 ft. of .065 line. Start pushing the line inside the spool from the center making sure the string is winding inside in a counter clock direction which should be shown on the spool. Keep pushing until there is about only 6 in. left.
Replace spool. Then the line guide ring, making sure to pull the string through the middle of it. Then hold the string on the slot in the ring while replacing the cap.
Oct 07, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
Trying to get the spool off. The plastic rig around the nut is gone nut is stripped. I am trying to disassemble from the motor thinking the cable is broken but still can't get it apart. Stihl fs 45
Maybe you can lock up the motor and just remove the whole string head as a complete assembly...Try taking the spark plug out of the engine...turn the engine over till the piston is near bottom of the cylinder, then insert a length of clean pull rope or curtain cord or even nylon rope into cylinder..then when your turn the spool or string head the engine piston will come up and compress the material inside...effectively locking up the motor to allow removal of the spool.
Jul 17, 2010 | Garden
Jul 06, 2010 | Black & Decker String Trimmer Cordless 12"...
How do I load string in a P2500 string trimmer??
Remove spool by firmly pulling on tap button. Cut two pieces of line (0.080) about 12 feet. Insert the two ends of the line into the small holes inside the spool. Wind the lines evenly and tightly on the spool. Wind the string in the direction of the arrows on the spool. Push the lines into the notches on the spool leaving three or five inches hanging there. Insert the two ends in the two holes in the hub. Align the notches on the spool with the holes in the hub and push it in until it snaps into place. Pull on the lines to release them from the notches.
May 03, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Have a S-M portable (5T231908X). -String Off Rewind Spool
Wind the spool clockwise at least 5 rotations. hook the string on the top and carefully let the spring take up the slack. You will need a hook of some type to pull the string through and under the carriage to hook to the other side. You may need more tension on the spring if it will not move the carriage all the way to the left. It is possible that the spring has broken inside the housing. In which case you will have to take it to the shop.
Dec 22, 2009 | Office Equipment & Supplies
Cub catet weed wacker needs new string and I don't know how to put the string on....
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Jun 30, 2009 | Garden
How to change the string
Jim
Jun 29, 2009 | Homelite Mighty Lite Lawn Trimmer
How do you wind replacement line to the Poulan Pro String Trimmer?
Jim
Jun 28, 2009 | Poulan Pro Pp125 25cc Gas Straight Shaft...
How to string a st3812b string trimmer
Wind the string on in a clockwise direction.
If it is a duel line then: Cut two separate pieces of string, about 7 ft. each.
Jim
Jun 26, 2009 | Garden
Step by Step spool filling on my NEW Black & Decker GH700
Check the bottom of the spool. See the pattern that looks like a circular saw blade. Ensure that the raised edges, do not have any broken/missing sections. Also, check that the pivot lever in the cap, moves freely and engages the space between the same, saw-blade-like edges in the spool correctly. If there are broken/missing sections of the spool, replace the spool with a good one.
Apr 29, 2009 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
103 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
