Question about Ovens
I have a Thermodore double oven and the display brightness is very weak. What if anything can I do? Thanks, Darell West darell@westronassociates.com
    Brigadier General:
  • 3,917 Answers
Dim display is a function of the drive voltages to it. A transformer creates these - and the DC voltage is stabalized by capacitors. The capacitors are only rated to 105 C - which means over time the heat will reduce the capacitors capacitance...lowering the drive voltage and diming the display.
Turn off the power - remove the keyboard panel and metal plate it attaches to. Remove the board attached to the metal plate (not the keyboard/board). Replace 3 capacitors (2 x 470 uf 35V, and one 68 uf 35v....highest temp you can get is 125 C.
Display works like a charm...for $10 in parts from radio shack... best is WHEN the display gets dim...its a straightforward fix.
Here are the pics of the parts that come with the kit.
http://www.appliancepartspros.com/pa...am_ id=194156
I'm guessing that the capacitors are on the top board (which is the actually display unit). Is there a tool that I should buy to test the capacitors to find those that have gone bad?
Thank You
Posted on May 15, 2009
OUr heating element died 00486945 for our 36 inch Thermodore oven range. Can you help us locate some type of replacement part
Just remove your heating element and take it with you to an applicance store. They will be able to order you a new one. Make sure you cut the power at the breaker before you remove it though.
Feb 01, 2016 | Ovens
My oven was working fine yesterday and now the bar underneath in the bottom oven glows but no fire starts. I don't have any $ to pay for this to get repaired and I definitely can't afford to replace a...
The ignitor should be real bright (hard to look at), if it is dim orange it is weak and a weak ignitor won't open the safety valve. This video explains how it works: Silicone carbide ignition
Jan 04, 2011 | Ovens
We just purchased a Kenmore Elite double oven (model # C970-600131); we don't like the intensity of the neon clock light; too bright to read the time from the next room; is it possible to turn this...
no it is pre-set and not adjustable.
perhaps some auto-tint over the display will help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 05, 2010 | Kenmore 43389 Electric Double Oven
Oven does not work,no display.
the display board itself would be the culprit,the part might be under warranty,if under 5 years consult manual or manufacturer for coverage....the part is probably expensive
Mar 06, 2010 | Whirlpool RBD305PD Electric Double Oven
Display reads code F03 on Whirlpool oven. Can I
Hi
Thanks for using FixYa. F3 error means Open oven temperature sensor or thermal fuse. You’ll need to replace oven temperature sensor or thermal fuse to resolve the issue.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Whirlpool RBD305PD Electric Double Oven
Our frigidaire model feb789wcc-c convection oven temp display isnt very bright and when oven gets to temp that it was set for it doesnt alert you but is working fine other than that but want to know what...
you actually have just one thing to replace to fix both of these issues. the main control board has to be replaced.
the display can get weak and not show very bright.
the beeper that alerts you is also on that same board.
replace the board and you should be back to seeing and knowing what you oven is doing again.
Jan 12, 2010 | Frigidaire FEB27S5A Electric Single Oven
Glow plug comes on bright orange but does not ignite gas.
If the bake igniter glows bright grange and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve will not let the gas out into the oven burner. A weak igniter must be replaced.
Oct 05, 2009 | Maytag CWG3100A Gas Single Oven
Stoves 900GRa spark ignition
i have a 900g stoves oven how do you change from auto to manual
Nov 02, 2008 | Stoves Premier 900GRa Gas Double Oven
Thermador model sc272t oven 2 doors have dim display
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
Nov 18, 2007 | Thermador SC272T Electric Double Oven
Ovens Logo
22 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
