Question about Camera Lenses
RICOH Caplio RR530
When i turn my camera on it comes up with a message saying V1.08RC, it then procedes to allow me to take the picture, but not letting me zoom in and out, or allowing the cover of the lense to open completly
  • 274 Answers
Re: RICOH Caplio RR530
For some reason its telling you your firmware version. You may need to update your "firmware" version.  Try here:
I was not able to get the file to download and I think its because of my location.  Go through your camera's menu and see if you can turn it off.  Also check to see if there is a command that trns off your zoom feature.
You can get more support here:
The lens issue could also be a mechanical problem and the camera may need to be cleaned at any photo repair shop.
Let us know what you find.
Posted on Oct 16, 2007
0 characters
3 Points
I just bought a Rokinon 10mm T3.1 Ultra Wide Angle Lens for my Sony Nex 7. I am getting an error message when attached that says Lens not recognized please attach correctly.
Samyang 10mm 2 8 Wide Angle Lens Unboxing Impressions Sample Pictures
Regarding a 3rd party lens it always have some problem. Manually pictures can be taken , if completely not supported. Check the video and find similarities. Like keep F- 22 IN LENS , ( or the highest FNumber ) .. turn on manual controls.. then shoot.. check if this helps and inform
Jun 23, 2015 | Rokinon Camera Lenses
Why! when i take a picture with my Olumpus sp-600uz camera and try to see picture it comes up with a picture error message
I had a similar problem. I had to clear all of the pics from the storage memory. All is good now. You need to move the pics to a folder and then delete them from the storage memory, not just delete the pics. There are still pics stored on the internal memory. If you need more info, I can tell you how to get rid of them.
Jun 04, 2014 | Olympus SP-600UZ 12MP 15x OPT Zoom Digital...
Why, when i take a picture and try to see it it comes up with a picture error on my sp-600z camera
The manual says:
Problem with selected image
Use photo retouch software, etc. to view the image on a computer. If the image still cannot be viewed, the image file is corrupted.
But try this. Switch of the camera, remove the battery and memory card. Check if all contacts are clean and shiny. On the battery, on the memory card and in the camera. Then replace the battery and memory card and switch on.
I hope this solves the problem.
Pictures coming out completely black?
Is the shutter opening? Put it on slow shutter speed and wide aperture say 1 sec at f4 or wider and look down the lens as you take photo. At some point you should see the sensor as the aperture is nearly fully open. If not then it isn't allowing light to get to the sensor, but if that's all working ok (and I assume you've looked at the photos on a computer and checked they are on the card and the exif info is sensible and they are still completely black) then you have a faulty sensor or processor. Remove battery reinsert and go into menu and reset the camera settings. Report back so???
May 13, 2014 | Nikon D3200 24.2 MP CMOS Digital SLR with...
Why does the camera keep saying 'turn off the camera and turn on again'
The camera is recognizing a problem, but it is not able to reset it self. It will have to be sent off for repair.
May 05, 2014 | Fujifilm FinePix L50
Tokina canon eos 350D error 99
1.Remove the battery, lens and CF card. Allow the camera to sit without power for 20 minutes and then reinsert a fully charged battery.
2.Turn the camera on and push the shutter button as if you were taking a picture.
3. If you don't get the error message reattach the lens and insert the CF card.
4. Check the below canon eos 350d service manual link:
it will help you to save a lot of money
Hope it helps, Thanks
Apr 08, 2013 | Tokina AT-X 124 PRO DX Lens for Canon
Have a message on our Canon camera that says it's
It sounds like your memory card is locked. There is a physical slide lock on the side of the card. Slide it one way to lock it and the other way to unlock it. There are similar instructions and pictures on the following web site:
Mar 19, 2010 | Camera Lenses
My camera cant focus on anything
It seems as if the lens isn't installed properly, make sure it's screwed in right in its mount.
Jun 20, 2009 | Canon EF 70-300mm f/4.5-5.6 DOIS USM Lens
Failure to operate - reimsert battery
Replace the battery. After you turn it off for a while, the battery comes back just enough to allow operation for a short time. After that time is over, the camera doesn't operate. Then if it sits for a while, the battery can power the camera for another short time.
Feb 01, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Error 99
i had the same problem and i found this guide online fixed my problem
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
Apr 19, 2008 | Canon 75-300mm f/4-5.6 III USM EF Lens
Camera Lenses Logo
50 people viewed this question
Top Camera Lenses Experts
Bart Pulverman
Are you a Camera Lens Expert? Answer questions, earn points and help others
