Question about Kenmore 62602 Electric Dryer
Gas......starts to heat then quits minutes later.
Worked fine.Thin belt broke, replaced it ok. Now this?????
Model# 97585200 stock # 75852
When started, burner came on, minutes later the flame went out. Tried 3 or more to start, only glow plug did its thing....did not light. Pulled exhaust tubing completely off, glow, no light.. ideas???
Automatic Intermittenttypr ignitor activates gas burner....will try again and see if it fires up w/ vent tubing off...
    Scholar:
  • 85 Answers
Problem is your gas solenoid coils. When they get worn they will open til they get out then shut. They will need to be replaced.
Part number 279834 replaces for most models.
Posted on May 18, 2009
Engin runs fine for about twenty minutes then quits. oil level is full
try and run it with a loose gas cap the vent could be clogged then check for spark when the engine dies or even better get a inline spark tester then you can see it when its dieing
Jul 12, 2012 | Garden
Kenmore dryer model 97585200 is running but there's not heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 13, 2011 | Dryers
I have a Kenmore 72602 dryer, my dryer starts fine, but after about a minute the burner turs off and there is no heat, What causes this? is it an easy repair
It is an easy repair. The sensor and ignitor are ok since it will work one time when it is cooled don. The problem is with the coils. They get hot and quit. Common failure on gas dryers.themobilian_150.jpg
HOW TO REPLACE
Nov 16, 2010 | Kenmore 72602 Gas Dryer
Our dryer is getting hot then it turns off 3 minutes later
When you say it turns off do you mean motor quits it that the case you motor is over heating and needs to be replace. It wll shut off for a while and then later work fine for three more minutes and do the same. If you mean it quits heating the the thermostadt is sticlking and need to be raplaced.
Apr 21, 2010 | Whirlpool LGN2000LWH Gas Dryer
It Starts and runs fine for about 15 minutes then
I think that your right. Sounds like your ignition coil witch is most likely located under the the flywheel cover. I know that on some briggs and stratton engines they are actually under the flywheel, just trace the sparkplug wires to know for sure. When the ignition coil beginns to fail they start slowly (spitting and sputtering) and then they get to the point to where they stop firing after getting heated up and adventually quit all together.
Jul 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
03 suburban ac problem
Put a new belt on it and spray the condenser coil in front of the radiator with a hose when it gets up to temp or the sound starts and see if it stops. Thats what I did today. Flapping/clacking stops for about 10 minutes until thing get hot again.A/C blowing cold air the entire time.
Jun 24, 2009 | 2004 Chevrolet Suburban
My ge washer starts spining to drain water then stops
Sounds like the belt is loose. The burning smell is the belt heating up. The motor shuts down because it's heating up from spinning on the belt.
Apr 30, 2009 | Washing Machines
Amana gas range bake burner does not heat
Pull the bottom of the oven off. You will see 2 to 4 screws that hold the panel on. The ignitor is under there. Look at the ignitor carefully for breaks. I say carefully as the ignitor is very easy to break.
Feb 03, 2008 | Ovens
Kenmore 62602 Electric Dryer Logo
100 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
