G2p cannot on or shutdown the laptop but it's bulb on
I have a g2p laptop,it's bulb being on for a long time,on other hand i cannot on the machine or shutdown the laptop
so can you help me with this
thanks
see the diagram attached, and fix it. God bless you
Light bulbIf your
microwave light bulb is not working, perhaps it has blown. The first
step is to replace the bulb and power on the microwave. If this does not
correct the issue, the next step is to check the socket and wiring to
verify if that is the problem.
Light bulb socket & main control boardIf
your microwave light bulb is not working after the installation of a
new bulb, check the light socket as well as the wiring to ensure they
are properly operating. If these sources are functioning properly, the
next step is to check for a faulty control board as a possible root
cause to your microwave light bulb malfunction.
I suggest try to call the manufacturer because if happens that its causing plastic burnt or dent due to overheating that means the hardware of the machine is failing, also the automatic shutdown is caused by overheating. If your going to call the manufacturer they have special support for those kind of issue.
Please try this: Connect your laptop to a working monitor. Then use the monitor as your temporary monitor. If this works, then the screen in your laptop is broken or damaged. If this still doesn't work, your laptop might be broken. In this case, try formatting it.
OkI want you to get the latest video drivers for your unit and install them. Also check for any BIOS updates. This sounds like a driver problem, and pressing those keys, is "Toggling" between External & Internal screens, and each time it is done it "Resets" the driver & video. So we must rule out drivers first. Also disable any screen saver for now.
You got two memory ports. One on the bottom of the unit.The second one is on top of your Notebook. To reach it you have to remove the keyboard. There are three small points on the top of the keyboard to unlock it. Under the keyboard you will find a metal protector with one screw which protects the second ram... By the way: The Bios only recognizes up to 2 of ram. System ProfileASUS G2P
Standard Memory
0 MB (removable)
Maximum Memory
2.0 GB
Slots
2 sockets
System Notes
PC2-4200/5300 DDR2 SDRAMSODIMMs
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
either the latch thats on the door is bad,,or the catch on the tub is out of line,,,now if the dishwasher door drops hard and wont stay up ..you need new door spring and the weight makes it pop[ open..
