Question about Panasonic PT-61LCX70 61" HDTV
Replace lamp unit
I have a Panasonic PT-61LCX DLP and I need to replace the lamp unit.
  • Anonymous May 15, 2009
    I ordered the new bulb and I need to know how to replace the lamp unit. I don't know how to access the lamp housing in the television.
  • Jim Krause May 11, 2010
    And what would you like to know ???
  • 19 Answers
SOURCE: reset lamp meter on Panasonic PT-43LC14 television
While TV is on, simultaneously press and hold both the TV's Volume Down button and the remote's PP/Play button for 7 seconds.
Posted on Jul 01, 2008
SOURCE: Need to reset the lamp timer / Panasonic PT-43LC14
hold the volume down on the TV and press and hold down the MUTE button on the remote control. Be sure to hold both buttons down at the same time and until the red light goes out.
This worked for me.
Posted on May 03, 2009
SOURCE: Panasonic pt-50lc14 lamp needs replaced.
You will find this very easy. Take the front panel off. It just pops off. Two screws..one on the out side door and one inside the door. You can do it from there. Oh yea put the back of the Tv back together....lmao.
Posted on Jun 02, 2009
  • 2318 Answers
SOURCE: how to reset a panasonic dlp lamp hours?
Try the following:
If you need to get into the service menu, you can do so by following these directions:
With power on, hold down VOL minus button on projection display and hold down the PIP or SPLIT button (try both) on the remote simultaneously for more than 5 seconds.
You can also click here to get more instructions if the above do not work. See post # 4.
Posted on Jun 17, 2009
  • 3 Answers
SOURCE: Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
Posted on Jul 25, 2009
Does my panasonic hdtv 1080i pt-50LC14 have a lamp
Yes it does! Behind the front bezel under the screen. you can buy it here. http://projectorlamps.com/panasonic-dlp-tv-bulbs-pt-50lc14.html PT 50LC14 Panasonic Genuine High Quality Original Projector Lamps now...
Refer to the manual or the instructions that are shipped with the lamp.
Apr 25, 2015 | Panasonic Televison & Video
Panasonic PT-52LCX66 blinks green then red lamp light comes on
Replace the lamp cartridge. You can get the replacement DLP lamp from www.tvrepairworld.com and the lamps come with installation instructions
Oct 27, 2012 | Panasonic PT-52LCX66 Projection Television
Panasonic pt-61lcx
The lamp will not cause this issue.
sometimes if set is not level or supported all the way across at the bottom the picture will be tilted.
Jun 13, 2012 | Panasonic PT-61LCX65 61" Rear Projection...
I HAVE A PANASONIC PTD5600U WITH BAD LAMPS BUT THE PROJECTOR IS TOTALLLY DEAD NOW. I KEPT RESETTING THE TIMER BECAUSE THE LAMPS WERE STILL GOOD. NOW, I REPLACED THE LAMPS AND THE PROJECTOR WILL NOT POWER...
You may possibly find that running on duff lamps or lamps that are too old has killed the ballast unit.
Replace the ballast unit and fit a new lamp will probably cure it.
Hope that helps.
Dec 06, 2010 | Panasonic PT-D5600U DLP Projector
PT-AX100U-EC DLP Projector: I replaced the bulb on the Panasonic PT-F1000NT pr...
1.Press the MENU button to display the menu screen, and
then press the F or G button to select the OPTION menu.
2. Press the ENTER button, and then press the F or G button
to select LAMP RUNTIME.
3. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, “LAMP RUNTIME
RESET.
” is displayed and select OK.
4. Turn off the power.
�� This will reset the cumulative usage time for the lamp
unit to zero.
***Here you go and best of luck!***
May 07, 2010 | Panasonic PT-AX100U-EC DLP Projector
Removal of the lamp unit from the tv
sometimes lamp is replaced in the front of tv.If so the panel under picture pulls out revealing lamp housing which is held in with a couple screws.replace lamp housing assembly
Feb 22, 2010 | Panasonic PT-50DL54 50" Rear Projection...
TV shut off and cannot turn back on
If your tv is around 2-4 yrs or used 6000-8000 hrs,never replaced the lamp before it could be time to replace it.The other most common failure is the board that powers the lamp,which is called the ballast.When its bad it will make a clicking sound or like wanting to turn on.The part # for your lamp is TYLA1000 you can find it here:http://www.discount-merchant.com/Panasonic-TY-LA1000-Lamp-DLP-TV-bare-lamp-p/panasonic-ty-la1000-lamp.htm Good luck and God bless you!
Feb 10, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic pt-50lc13 shutting off
i'm on my 3rd bulb in 5 yrs. i hate this tv. this time my bulb light didn't come on. instead the power light flashed green fast then went to red flashing after. i took out the bulb and it's blown!
Nov 19, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-61LCX70 61" HDTV Logo
107 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
