Question about Maytag MZD2766GES Side by Side Refrigerator
Magic chef water running on floor, from under risper, i removed crisper did not see drain hole ice maker not hooked up
  • harpo79 Dec 29, 2007
    I am having water leak out of freezer side onto the floor. Looks like it is running down back side of inside freezer compartment.
  • Anonymous Feb 26, 2008
    water running onto floor from freezer; major ice build up on bottom of freezer
  • 89 Answers
Leaking from frig side or freezer side? If its freezer side the drain hole is behind back wall. Get you trusty blow dryer out...
Posted on Dec 16, 2007
Water puddle forms on the floor in front of my GE TBX18SISERWN frig
lokk under the crisper draws,if there's water under them you have a blocked drain in the freezer.if there's no water under the crispers check the pastic water lines going to the water valve and the ice maker.if it's the drainyou have to pull everything out of the freezer,remove the inside back wall of the freezer and melt out all the ice with a hair dryer then you have to clear the drain,i use a steemer to do this,you can use a turkey baster or anything will push air down into the drain hole,pour hot water into the hole and when the water goes down the drain you'll know it's clear.before you start you can advance the timer into defrost to help melt out the ice or shut down the control or unplug it,you don't want it to be running while you take it apart.hope this helps you figure out where the water is leaking from.
Sep 24, 2011 | Refrigerators
Water comes off somewhere in the bottom of my fridge. what could have caused it?
When your refrig goes into defrost , the water runs down the back of the refrig ( inside ) and out to the drip pan thru a drain hole under the crispers . If water is under the crispers , remove the crispers and you should see a " cap " covering the drain hole . Sometimes crud will cover the slots where the water is supposed to drain , causing water to pool under the crispers . Just remove this cap , clean , and reinstall .
Mar 20, 2011 | Magic Chef Refrigerators
There is a huge puddle of water under the front of the fridge ,this unit doesn't have an ice maker what could this be ?
The drain is clogged. You will have to remove the back wall of the freezer to access the drain. There is a hole under the coils, that is th drain. Remove the ice on top of the drain and clean the drain out by forcing hot water down the drain with a turkey baser untill water flows freely. Then mix baking soda with water and pour it down the drain. http://www.appliance-repair-it.com/refrigerator-leaking.html
Sep 28, 2010 | Magic Chef CTF2125 Top Freezer...
I have Magic chef Model # CTB1923ARW. We find water all over the refrigerator section. This unit does not have Ice maker
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Lightly hook the other end over the glass rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Sep 27, 2010 | Magic Chef Refrigerators
I have a 6-7 year old Magic chef top freezer, refrig which is collecting water each day at the inside bottom of the box, refrigerator section. I notice that a slight drip of water comes thru the middle...
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Magic Chef CTB1821AR Top Freezer...
Water leaking on floor. wateron top of crisper
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Make a clip at the other end of the wire , and " clip " it over the glass tube (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Nov 29, 2009 | GE (GTS16BCS) Top Freezer Refrigerator
We have a Magic Chef CTB177GR refrigerator (no ice maker hooked up) that leaks...from where I don't know. I took off the lower back cover, it is dusty but no water present there. I pulled out the crispers...
Good day.
Water can only come from one place, where the frost is melted off the coil in the freezer during it's normal defrost cycles that occur daily.
Two styles. One style allows this condensed water to run down the back wall of the inside of the refrigerator, under the crispers and thru a hole in the bottom of the cabinet into a drain pan positioned
under the hole.
Possible missing pan, not positioned properly, or crack in the drain pan itself.
The other style drains the water to a hose mounted on the back of the machine, down and then into the pan.
Possible hose blocked, not connected properly, or the other items as described in first style.
It's a look-see type of repair.
Nov 17, 2009 | Magic Chef CTB1722 Top Freezer...
Water seeps out of freezer side of fridg onto the floor, I have totally remover the water line going to the ice maker and it still has water seeping out. It builds up Ice on the bottom of the freezer and...
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 25, 2009 | Magic Chef Refrigerators
My 11 year old fridge has a slight leaking problem. on occasion i will find a small puddle in front of the fridge and sometimes a little bit of water under the right side crisper but i can't seem to find...
Hi, The drain hole for this model is located in the control panel. There should be 2 - 4 screws that hold the panel up. remove those screws and the control panel should drop down. Flush the drain hole out and check up inside the hole leading to the freezer drain and see if there is ice inside the drain hole.
Most of the time, the drain inside the control panel is the problem.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 27, 2009 | Magic Chef CTB1922 Top Freezer...
Water squirting from ice maker
Does it do it all the time or only when the ice maker call for water... you may have a bad water valve 67006531 VALVE, DUAL WATER or a ice dam in you icemaker let me know
Aug 25, 2007 | Magic Chef (CSD2610KRW) Top Freezer...
Maytag MZD2766GES Side by Side Refrigerator Logo
185 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
