Question about Acer AL1916W 19" LCD Monitor
Dscaler when i use dscaler it cuts off some of the bottom were the bottom of the image  is.
    Problem Solver:
  • 16 Answers
Reset setting to factory defaults
Posted on Feb 13, 2008
Cuts off bottom of letters
It could be a problem with the drum, or more likely the toner cartridge and drum unit are not sitting firmly. If the assembly moves the image transfer will be interupted. Take out the drum and toner, and examine for any loose or damaged moldings. Also examine the surface of the toner cartridge for lines that would indicate the unit is "fluttering". It also occurs that you may be referring to the bottom of the page being cut off - in which case check your paper size setting is correct (i.e. A4 or letter).
Feb 20, 2015 | Brother HL 2140 Laser Printer
Dell 2300 MP Verticle lines distorted image
light engine or bulb is gettingbad ok how many hours on bulb fans clean ect thx nick
Feb 11, 2008 | Dell 2300MP Multimedia Projector
My Benq projector is cutting off part of the screen image (the top and bottom)...I've tried adjusting the resolution on my computer, but nothing seems to work. Any suggestions?
when you say its cutting off the image, do you mean it is blanking the top and bottom off the picture. Is the image that is displayed on the computer the same as on the projector or is it just a cinemascope version of the computer screen
Mar 10, 2011 | BenQ PE7700 Multimedia Projector
Screen cuts off top of heads
Check the menu settings for the picture. You may be expanding the image to fill the sides, in the process, cutting the top and bottom.
Mar 10, 2010 | Samsung LN-S4051D 40 in. LCD Television
I dont have pip is there any software i can buy
Yes there are many sorts, you can get USB, or Internal cards, I myself have a Pixelview PlayTV Hybrid, that allows me to view, HD DVBT & Normal TV as well. In fact I use two cards, another Pixelview internal BT878, chipset. I run them boyh, so I can work on one screen, and have HD TV, & Normal TV PIP'ed on my other monitor, it all works great. Dscaler is a wonderful software to use.. But the software that comes with the cards works well too. One Must be set to RGB & the other to Overlay, though to allow both to work at once. Download Dscaler below, it plays DVD;s great as well, simply the best out there. deinterlace.sourceforge.net/
Feb 27, 2010 | Panasonic PT-43LC14 43" Rear Projection...
The cricut does not cut through the paper, it only scores it enough to see the outline of the image to be cut. I have checked on line and the blade housing is installed correctly. Does the cutter have a...
Yes, there are three rollers that one adjusts your size of the image you are cutting that is on the right hand side of the machine. The other two are on the left side of the machine. The top one is your speed control and the bottom is your pressure. I would move it up to medium when cutting with cardstock or even up to high if it is thick cardstock. Hope this helps, any further questions feel free to ask me.
Dec 30, 2009 | Provo Craft Cricut Disney Font Cartridge
The display cuts off the bottom quarter of the image
you have a weird display resolution set somewhere on the laptop. The vplcs7 is relatively old. It only supports 800 x 600 (SVGA). If you are cloning your monitor, you need to set the output to the projector also to 800x600. Depending on how your laptop is configured you may need to set your laptop monitor to 800x600 while using the projector, then going back to the normal resolution when you are finished.
Feb 02, 2018 | Sony VPL-CS7 Multimedia Projector
Images displaced, cut off at bottom & extra content at top
Be aware of using your Flash because it has limit syncronization capability. if your flash synchronization limited only to 250 speed, and you make it 500, the images may turn half lighted and dark.
X synchronization is important to know.
Jan 10, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Images displaced, cut off at bottom & extra content at top.
flash trans. is broken i want to replace if there any matching ?
Dec 01, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Image "cut"
you search and search and search, and in the end you solve the problem, you don't even know how ?!?
Feb 14, 2008 | Samsung DVD-909 DVD Player
Acer AL1916W 19" LCD Monitor Logo
172 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
