Sony PlayStation 2 (PS2) Console Logo
Posted on Oct 16, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nascar 08 can't play 2 players
Will only play one player. Seems to be pausing the 2nd player. Have tried wireless and wired controller. Same results. Any suggestions?
Anonymous
Level 3:
Guru:
  • Master 1,463 Answers
  • Posted on Oct 25, 2007
Anonymous
Master
Level 3:
Guru:
Answers
1463
Questions
0
Helped
964912
Points
3853
Having tried different controllers and still the same have you tried the game in another playstaion see if the game at fault or the console .also you might find here helpfull as well .
http://forums.ea.com/mboards/category.jspa?sls=2&categoryID=66
riz.
1helpful
3answers
What is the code to make LG DP522H DVD player region free (0)/ multi-region? (this replaces my question yesterday where I got the LG model wrong!)
Ok so here is how it was done.
Press the Pause button on your remote control. Using your remote control enter the code 3, 1, 4, 1, 5 and 9, Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2. Press the Pause button on your remote control. Power off your player and wait a few seconds. Power on your player
Or
Press the Setup button on your remote control then, Step, Next, Up and Down, select the region of your choice or Bypass for region free, save and then Exit the menu.
LG 3200E, LG 3520, LG 4351, LG 4721P, LG 4730, LG 4821P, LG 4950S, LG 5083, LG 5822N, LG 593W
2answers
Hi, I recently purchased a Panasonic DVD S48 dvd player. I was assuming when I bought it that it was a multiregion product. This seems not to be the case as it will not play region 1 dvd's that I...
hi Pjkgbr.
this is all i could find out, now if you do try this do so at your own risk.
This hack requires the S48 remote plus a universal remote configured for the S48 with a separate 'Pause' button (or another Panasonic DVD remote with a separate 'Pause' button may work).
I used a cheap universal remote.
1. Select DVD device on remote.
2. Hold magic button until the DVD button blinks twice.
3. Enter device code 0490 (DVD button blinks twice)
Neither the 'Play/Pause' nor 'Frame' buttons on the S48 remote work for this hack.
1. Power on.
2. Open tray.
3. Using the S48 remote press Audio, 1, 9, 8, 2, Subtitle
4. Using the other remote (URC 7562) press Pause.
5. Using the S48 remote press 0.
The DVD front panel should now show the text "on".
The DVD should now be region-free. Region code hack posted by spook65, December 12 2012:
DVD-S48EG-K (Region 2)
This is the process for unlocking, the Panasonic DVD-S48 for
multi-zone.
Please note, you will need a universal remote control which
has a PAUSE button in order to unlock this player.
1. Turn the power ON
2. Open the disc tray
3. Using the remotes, press AUDIO 1 9 8 2 SUBTITLE PAUSE 0
4. Switch the player to STANDBY and then switch ON again.
The display should read ON after you enter PAUSE 0.
If this doesn't happen, switch the player off and start the
sequence again.
The remote supplied with Panasonic player has a PLAY/PAUSE
button rather than a separate PAUSE button. If you use the
PLAY/PAUSE button, the tray will close and the unlock
sequence will be aborted.
To get round this, you need a universal remote set-up to use
with the DVD player. After pressing SUBTITLE on the
Panasonic remote, quickly press the PAUSE button on the
universal remote, then press 0 on the Panasonic remote to
complete to unlock code entry.
or this one.
What is the process for Multizoning a DVD-S38 / DVD-S48 / DVD-S58 / DVD-S68 / DVD-S500 / DVD-S700 DVD Player? Providing your DVD Player is one of the below models, you can multizone the unit yourself using the remote supplied with the product and another Panasonic product remote thas a Pause button on it
Applicable Models:
Multizoning Process:
1. Power on the unit and open the disc tray
2. Using the remote that came with the player, press the following buttons in sequence
3. AUDIO 1 9 8 2
4. SUBTITLE
5. Using the other Panasonic Remote (not the one that came with the player), press the PAUSE button
6. On the remote that came with the DVD player, press the 0 (zero) button
7. If you have followed the above process correctly, the word ON should be shown on the front panel display of the player*1
*1 Please note: The models DVD-S500 and DVD-S700 do not have a front panel display,
so the only way of confirming that the multizoning process has been done correctly, is to
try playing a DVD disc from another region code other than region 4
How do I connect the 2nd wii controller for donkey kong country returns? It does not allow the 2nd controller (two players) to play the game
First, make sure the 2nd controller is paired with your Wii. Then make sure you're in 2 player or co-op mode. I think when I played it all we had to do was turn on a 2nd controller and Donkey Kong automatically added the 2nd player in.
3helpful
I purchased dvds from ebay and they will not play on my dvd player. Is there a way i can unlock or change the region on my Sony DVP-SR200P DVD Player? Please help!!!
Turn on the unit with the remote controller, Wait until "no disc" appears in the unit's display. Press the keys: PAUSE, 3, 1, 4, 1, 5, 9. And "CODE" will appear in the display. Press the number key that corresponds to the disc zone you want to play within the next 5 seconds:0: All regions / 1: Region#1 / 2: R#2/... and so on. Then, within 5 seconds, press: PAUSE, POWER... and voilà. If you don't have good results, disconnect the equipment and repeat.
Or
Put your player in standby mode and then enter: [[0] [ENTER] Default Default region code [1] [ENTER] or [UP] [ENTER] Region 1 [2] [ENTER] or [RIGHT] [ENTER] Region 2 [3] [ENTER] or [DOWN] [ENTER] Region 3 [4] [ENTER] or [LEFT] [ENTER] Region 4 [5] [ENTER] or [TITLE] [ENTER] Region 5 [6] [ENTER] or [DVDMENU] [ENTER] Region 6 [7] [ENTER] or [RETURN] [ENTER] Region 7 [8] [ENTER] or [DISPLAY] [ENTER] Region 8
Or
Put player into standby modes by pressing power button on remote control. Then press Title button. Press Clear button. Press Power button.
I found these codes for all the other DVP-SR series players, yours was not listed but I thought was worth a try.
2helpful
How do you create a 2 player game for nascar09 ps3
nascar 09 is only 1 player unless online. it stinks.
i hope i helped
Question
nascar 09 is only single player. it stinks.
i hope i helped
5helpful
5answers
I need an unlock region code for my Zenith DVD2200 player
After getting clarification from Fixya I can pass the links below to you to check yourself
Some players are harder than others to do this but you may want to
try here or here
Comments:
Toshiba's and JVC's are the harder ones to do
I use a Phillips myself as it is not only cheaper but has much more going for it than many of the higher end units. i throw anything at it and it just plays
The older the unit that harder it is to do the region free thing with.
I let my EX have the panasonic (big grin)
If you cant find a fix then look at the codes available for cheaper brands and how easy it is to do it before you purchase one.
Just a thought.
Dubbing from vcr to vcr
Connect with RCA cable to RCA jacks\plugs::
output [player] audio to INPUT [recorder]
OUTPUT [player] Video to INPUT [recorder]
Place blank tape in RECORDER, Tape that you want to record from into PLAYER.Press Record [recorder machine], wait one second, press PAUSE.( thats to give record tape "breathing" space.) Set up your player tape to start playing. When you know what you want to record, press PAUSE again to begining recording. Press PAUSE after the recorded section to install 2nd tape, etc. etc.
NOTE:: some VCRs use PAUSE 2nd time to release and continue recording, while some machines you must press RECORD button again to release PAUSE. you must expirement before begining your project.
My DVD player is not working properly
It sounds like the player is defective, try to get a RMA ,or it or bring it back to where you got it from.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
