Question about Toshiba Satellite Pro 6100 Notebook
Upgrading the RAM. Can't find where to put it.
  • wwfm May 15, 2009
    Can't find it under the keyboard but I only took off the front (hand rest) portion. Should I actually remove the keyboard its self?
  • 184 Answers
The computer has two memory expansion slots—Slot A and
Slot B. You can install one or two memory modules.
1 Shut down your computer completely using the Shut Down
command.
2 Unplug the computer.
CAUTION: Installing a memory module with the computer’s
power on may damage the computer, the module, or both.
3 Close the display panel and remove any cables you may have
connected.
4 Turn the computer upside down.
5 Locate and remove the screws that hold the cover plate in
place, then remove the cover from the bay.
Removing the memory module cover
CAUTION: Static electricity can damage the memory module.
Before you handle the module, touch a grounded metal
surface to discharge any static electricity you may have built
up.
To avoid damaging the memory module, be careful not to
touch its pin connector on the side you insert into the
computer.
6 Remove the new memory module from its antistatic
packaging.
7 Insert the memory module in the slot and gently press it down
into place.
The clips on either side of the module will click to secure the
module.
Inserting the memory module into the slot
8 Replace the cover plate and the screws.
9 Turn the computer over and restart it.
When you turn on the computer, it automatically recognizes
the additional memory.
Removing a memory module
If you need to remove a memory module:
1 Complete steps 1–6 in “Installing a memory module” to shut
down the computer and open the memory module cover.
2 Pull the clips away from the memory module.
The memory module pops partially out of the slot.
Adding memory
Pulling the clips away from the memory module
3 Carefully remove the module from the slot.
4 Replace the cover plate and screws.
5 Turn the computer over and restart it.Upgrading the RAM.  Can't find where to put it. - 5029d05.jpg
Posted on May 15, 2009
    Guru:
  • 832 Answers
Hi thanks for using fixya!
This might help you, please click HERE
Regards!
  • Dennis Jambalos
    Dennis Jambalos May 15, 2009
    hi again!
    Please check this website that might help you a lot, please click HERE
  • 253 Answers
Sometimes it will be located under the keyboard, Please give me a fixya if it solves or helps solve your prob
  • Gomez May 16, 2009
    sometimes toshiba will put RAM underneath the keyboard itself, but it is true, most have an access door on the bottom, if yours doesn't, it is usually under the keyboard, I have replaced RAM in an "Off-Brand" Laptop, and had to remove the whole Motherboard, On yours if this is right, it is under the cover right beside the battery, (remove Battery and power) then undo the two retaining clips on either side by seperating both slightly, the RAM should pop up, reinsert in reverse order. Here is the picture.
    http://www.irisvista.com/tech/laptops/To...
    I hope this is worth a fixya rating to you, if so, please give a fixya rating.
    Gomez
    I forgot this dissasembly Video in the last post sorry, here it is.
    http://irisvista.com/tech/laptops/Toshib...
    If this solves the problem, please give a fixya rating
    Gomez
How do i upgrade ram on averatecav1020-ed1
In upgrading the Ram of your laptop you need first to get a additional Ram that is compatible to your laptop and then when you have that already you can upgrade the Ram by taking the bottom cover out and there you will see the place where you need to put the additional Ram...
Jul 09, 2009 | Averatec AV1020-ED1 Notebook
Upgrading ram
Well with this type of motherboard yes you can put 1gb into it however you can put up to 2gb on it and be just fine. Hope this helps you out.
Apr 11, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Upgrading system ram
This computer supports up to 512 MB of RAM, so you can add another 256 MB of RAM....
Apr 10, 2009 | Toshiba Satellite 1805-S274 Notebook
1gb upgade
Reinstall the RAM board. Adding RAM should not affect your programs, unless you put the wrong type of board or size in.
Jan 31, 2009 | Dell Inspiron 1000 Notebook
Upgrading the ram
you can upgrade the ram upto 512, two ram sticks of 256 DDR 333MHz
Dec 17, 2008 | Computers & Internet
Compaq Presario M2000 PC Notebook
The Bios on the laptop motherboard only will recognize a total of 1gig Ram. So the 256 stick would be removed and 2- 512 sticks installed.
May 22, 2008 | Compaq Presario M2000 Notebook
RAM upgrade
you can put up to 3 gig on your note book you must replace your internal ram
Dec 12, 2007 | Computers & Internet
Toshiba Satellite Pro 6100 Notebook Logo
169 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
