Question about Sitecom (WL -004) Wireless Adapter
I WANT TO SETUP MY ROUTER TO WIRLESS
I WANT TO GO WIRLESS AND I CANNOT SETUP MY ROUTER I HAVE A SITECOM MODEL NO WL-114 ROUTER I WOULD UR HELP SETTING IT UP THANK U
  • 33 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Go to START and find RUN, then type in CMD and hit ENTER, should throw up a black box (Dos window) you will type IPCONFIG and it should give you an adapter gateway ip address like 192.168.0.1 or something like that, from there close out that box and launch internet explorer or firefox or netscape or whatever browser you use. Type in the ip address where you would normally type www.google.com. Hit ENTER, this will interface you with the router. It might be password protected. Usually the username and password are both the word admin. If not look at the bottom of router for password. Look for wireless tab once in router and select network type as wep. Look for the key that the router automatically generates. This will be your wep key. Now your wireless connection will be secure. Hope this helps...Tennis123
Posted on May 26, 2009
I want to setup my router drivers to be conected my router nr is 12107 serial : WL12773802229 MAC 000CF639BA44
Posted on Nov 19, 2010
Sitecom WL-342 Wireless Router won't access internet.
Make sure there is a network cable going from your ADSL modem into the WAN connection of the router.
If the ADSL modem is wireless, then it is also a router in whihc case you will want to bypass the WL-342 all together.
Thanks,
Pat
Apr 01, 2010 | Computers & Internet
I can connect a sitecom 300n(wl-330)but cannot get an internet connection the router is an Orange livebox
you need to put in the connection tab
the name of the router you are trying to get in to
and the security key (if enabled).
Try disabling the security key on the router to test this out.
You may also have MAC filtering on,
in which case you must disable it or
put in the MAC number written on the sitecom label  into the router.
Mar 07, 2010 | Computers & Internet
I selected an MAC adress in the software of my WL312Sitecom router.I guess the wrong one because now I can't access 192.168.0.1
Reset the router via the little hole in back/underneath. Then simply set it up again, properly. Below is a link for the manual it has a step by step walk through for setup to help you. www.sitecom.com/showdownload.php?id=3779
Mar 05, 2010 | Sitecom (WL -004) Wireless Adapter
I have same issue and using Asus WL-520GC
HI! I will be more than glad to assist u in this concern..the reason why page cant be displayed bcoz the router and the modem wont talk to each other.. u are connect to the router but not to the internet..this are the possible solution.. .. if you are using a cable modem from ur cable company provider- u need to do a mac clone on the router u have to clone the mac address of ur computer. normaly the mac of ur computer is the one register to your cable company and on the setup page of the router just selct on the internet setup, dhcp after clonning the mac address of your computer. u need to connect ur computer directly to the router and then after doing the process connect the router to the modem. if u are using a username and password, u have to use the pppoe settings on the router, if ur isp set a static ip , set it up to the router, to check the ip setting of your isp.. connect the computer directly to the modem and check if u have internet.. then click on start, run and type cmd,it will give u a dos prompt and from there type ipconfig/all and it will show u the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
Jul 30, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
Can't setup to virgin braodband
You mean ascii and hexadecimal.
  • Hard wire your router to your PC with an ethernet cable
  • Open your web browser, go to website http://192.168.0.1
  • Input username/password both are "admin" (without the quotes)
  • choose "wireless settings" (third tab from left)
  • go to "security" (fourth tab from left)
  • Choose WEP (if the first box on this page already says WEP you may skip this step)
  • choose 64-bit
  • type random 10 digit code into key 1 (eg. 38-38-2D-E3-B0)
  • Save settings (bottom of page)
  • write code down somewhere or make it easy to remember
  • disconnect your ethernet cable from router, try to connect to wireless network, enter code (from above) and it will connect.
Jun 26, 2009 | Sitecom (WL -004) Wireless Adapter
Problems configuring WL-130 Wireless Extender
http://192.168.0.1
then type user name:admin
password is:admin or blank
then enable DHCP.then u can get ip automatically.
Nov 12, 2008 | Computers & Internet
Problem with sitecom wl-130 connection
I think I have the solution: you have to click on the basic settings tab, then n "site survey" button, then (optional) on "refresh" button.
Now you will get the information about your network, and you just have to check the channel number of the signal from your main router. then you have to set that channel in the "channel" button of the basic settings tab. You also have to choose Universal repeater as working mode of the sitecom device, instead of Access Point.
Hope it helps.
By the way, all these settings should be automatic in such a device.... But this sitecom range extender is ****.
I suggest everybody is reading: DON,T BUY THIS ITEM!!!! Spend 10 bucks more and get a working one!!!
Jun 01, 2008 | Computers & Internet
Compatibility with Sitecom wl 031
This 10dBi omni directional antenna enables you to very easily extend the range of your wireless network. By linking the Omni Antenna to your wireless router, you gain the benefits of an optimum wireless signal while minimising the number of ‘dead spots’ (points in your home where the signal is either weak or lost).
However it does not fit the following types of routers,modems and accespoints:
WL-143
WL-122v2
WL-114/WL-517
WL-114v2
WL-108/WL109
WL-111
WL-106
WL-025
WL-018v2
These antenne's will also fit other brands of wireless products that use an SMA connector
Jan 29, 2008 | NetGear WGR614 Wireless Router
Sitecom (WL -004) Wireless Adapter Logo
304 people viewed this question
Top Sitecom Computers & Internet Experts
David Payne
David Payne
Are you a Sitecom Computer and Internet Expert? Answer questions, earn points and help others
