Question about Canon PIXMA iP1800 InkJet Photo Printer
My canon pixma iP1800 went offline and I can't get it online
My canon pixma iP1800 went offline and I can't get it to go online again. Used windows add/remove to delete printer. Tried to reinstall using 2.05 driver. Tried to swap USB cables. Unplugged power for 10 minutes. and then reinstall. cleaned out registered versions from registry. Each new step got a clean Reintall.
Best I could do was get the driver to install and get an online status, but when I tried to print, the thing went offline and I was back to scratch. install to online was done by using 2.05 driver on lpt1: printer port, but I'm sure my computer only has USB.
HELP
SOURCE: Canon Printer Help.
I have just got a Canon PIXMA MP210 ALL IN ONE PRINTER My CD ROM reader is not working how can I install it
Posted on Jul 27, 2008
ginko
  • 19396 Answers
SOURCE: Canon PIXMA iP1800 InkJet Photo Printer for windows 98
I think I will save you some time telling you that there is no driver for Pixma IP1800 running on Windows 98/ME.
The printer had been built to work on windows XP/Vista, and drivers for 98 were never made.
Here or here you find two of the many threads on Win 98 driver for Pixma IP1800, all of them end in nothing. I can speak portuguese, the links wrongly provided are drivers for XP, and won't work on 98, and there is also no brasilian website distributing drivers for this printer on win 98, that was just a legend.
This printer won't work on Windows 98.
Posted on Oct 04, 2008
yooperbud
  • 8637 Answers
SOURCE: Canon Pixma iP2000: yellow power light blinks-reset doesn't work
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
SOURCE: Cannot install Canon PIXMA MP190 printer
Thank you for your promptitude.
Today I solved my problem. Was a cable connection problem. Cable incompatibilit or all 3 cables used before are damaged. Tuday I buy an other new cable and SUCCESS!!!: my computer see de printer ("new hardware found" when attach usb cable) , create virtual usb port, install the drivers (I have the drivers downloaded from the Canon web site) and printer is working fine.
Anyway, thank yow again for your support!
Posted on Jul 10, 2009
takibd
  • 26 Answers
SOURCE: Canon Pixma MP150 offline - won't print from computer
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-25
Posted on Sep 04, 2009
Is Canon PIXMA IP1800 can handle T-Shirt Transfer Paper? if it can, what kind of transfer paper that will be good for IP1800?
There are several brands of T-Shirt transfer paper out there, and all are designed to work with InkJet printers just like yours. Personally I've used the Avery brand sheets, and they are widely available at local stores like WalMart, Staples, OfficeMax, etc.
I've also provided a link to the sheets available for online purchase from Amazon.com -
http://www.amazon.com/Avery-Personal-Creations-T-Shirt-Transfer/dp/B004E2S3MC
May 05, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Canon ip 1980 offline problem
Saya Punya Printer Canon IP 1980, printer sudah terkonek ke PC driver sudah ok tapi ketika saya print tidak ada respon sama sekali saya cek kabelnya bagus tidak ada masalah . kepada para sahabat saya minta bantuannya dan solusinya ? ...
May 31, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
I have a Canon iP1800 color printer. I recently
Look around thoroughly in the Printers > Properties tabs. While in the shop, they have no doubt tested your computer (without your printer hooked up). Try letting your computer boot up without the printer, then with printer power on, plug in the USB cable.
Perhaps your printer is "offline." If so, right click on your printer's name in control panel. Choose "Use printer online".
Dec 20, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Cannot download driver for Canon Pixma ip1800 inkjet printer
Just Log on to this Link:  software.canon-europe.com/ - 85k
And u can download the Drivers from here
Jan 20, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Oct 04, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon Printer Help.
Jul 22, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Adding printer pixma ip1800
Hi there mosse_123
This happens a lot, you're going to be fine. The following links will get you up and running. I've included both Windows and Mac procedures. Use the ones that are applicable.
Click here to download iP1800 drivers.
  • Read the procedure.
  • Click the link in Option 1.
  • Question 1 = Printers
  • Question 2 = PIXMA iP series
  • Question 3 = PIXMA iP1800
  • Click GO
  • Select your Operating System and follow the prompts.
Click here for the iP1800 Windows install procedure.
Click here for the iP1800 Mac install procedure.
If you have any problems let me know. We'll get you up and running
Remember: good things happen to those who Rate.
Mike
Jul 21, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon iP1800 Driver for Windows 98
  • click here
  • Select your product, model no. etc.
  • And make download.
Thanks
Iqbal
Apr 26, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
270 people viewed this question
old marine
old marine
