Question about Frigidaire Dryers
How to Replace Dryer Motor
How do I remove the motor from a Frigidaire stack dryer FLSE72GCS1? Thanks.
    Problem Solver:
  • 14 Answers
Make sure its unplugged,pull over the pulley to losen belt,unplug electrical connector from motor,take any bolts and nuts lose.remove motor.install new motor in opposite of removal.
Posted on May 15, 2009
I have a stacked Frigidaire FEZ831CA washer/dryer combo and when running the dryer it makes a very high pitched (AND LOUD) screeching sound. Any ideas as to what might be the problem? Thanks, Sean
screeching sound
Sean, Bad felt gasket body to drum, if belt drive on dryer, it could be worn and slipping, making a screech, or if not the belt, the drum may have a worn bearing on its hub allowing it to run crooked and rub where it should not.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Disassembling reassembling stacked clothes dryer
Frigidaire Stacked Laundry with Noisy Dryer
How to Replace an Electric Laundry Center Dryer Drive Belt Kenmore...
Mar 29, 2016 | Frigidaire Washing Machines
Where can I locate the blown fuse/s of a frigidaire dryer?
There are no user servicable fuses in the machine, I believe they are talking about your breaker box.
A 220 dryer requires two 110 volt circuits to run the 220 volt heater
The motor and control circuits only require 110 and are run from only one of these two lines. If the other line blows the dryer will still run but there will be no heat.
Good Luck
Quentin
Jul 06, 2009 | Frigidaire FEX831CS Top Load Stacked...
Dyer no movement/heat on stack unit- washer fine
It sounds like the dryer motor please change thanks
rate me
Apr 20, 2009 | Dryers
Frigidaire Glet1041AS Pump Drain replacement
washing machine is leaking from the bottom left what could this be
Nov 08, 2008 | Frigidaire GLET1041A Top Load Stacked...
Frigidaire stacked gas dryer flsg50rgso
Hello sdusharm
Welcome
You said, You have a gas stacked frigidaire dryer and washer. I assume the motor has gone because one you push the start button the drum does not turn. How do you get to the motor to replace. Does the top and back come off and how do you do it. alan
Below I will paste the site that will have the repair diagrams needed for you to see how to replace the motor if you choose to!
Find the diagram "#5 Dry MTR ,BELT" When you click the page and it opens inthe upper right corner it will say,Open This Diagram in a New Window.The motor is #28 in the Diagram.
28 5303937189 MOTOR & PULLEY In-Stock $ 112.80 Diagram and parts site location
http://www.pcappliancerepair.com/model-display.php
Let me know how it goes for you!
Huuum,
Please remember to leave a rating.
I believe I solved your request!
Sep 25, 2008 | Frigidaire FGQ332ES Gas Dryer
Frigidaire Gallery Front-loading Dryer Stops Tumbling
I have a stacking Frigidaire washer/dryer. The dryer will not start at all.
Thanks for any info you can offer.
Dec 23, 2007 | Frigidaire GLEH1642DS Front Load Stacked...
Stacking Instructions
You will need a stacking kit 5303937141 to stack them, Feel free to ask for any more advice.
Nov 24, 2007 | Frigidaire FEQ332E Electric Dryer
Dryers Logo
122 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
