Question about Konica Minolta bizhub 350 All-In-One Laser Printer
How to reset the copier after installing the new imageing unit c350
  • Anonymous May 26, 2009
    same problem here. how to do a rom reset?
    Habit-Forming:
  • 96 Answers
Normally it has no need for reseting.
In the moment you put the new image unit it resets the counter life, although you can reset by holding down the trouble reset button and in the screen you will see trouble reset.
touch it and switch in and off the machine with the main power button.
Posted on Aug 13, 2010
  • Boiken Verli
    Boiken Verli Aug 23, 2010
    hold down the utility counter
Bizhab c350 c13c8
A new installation is not detected when a new Transfer Cleaner Unit (Image Transfer Belt Unit) is installed.
Did you get some 3rd party transfer belt get a OEM and replace it.
Feb 15, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Image drum unit
Remove the image unit that the operating screen indicates then install the new one don't for get to pull the protective sheet once the image unit is installed Also en sure to shake the image unit There is what is called developer inside it shake I/U side ways to spread the developer along the hole I/u if not and all the developer is sitting at one end when the motor for that unit turns you will get a code or burn out the motor,
Jan 31, 2014 | Minolta C350 Printer
C0016 retraction
Black Image unit Motor failure to turn. Remove the black image unit then shake side to side. what you want to do is spread the developer (Located inside the unit) along the entire length of the image unit. BET the image unit was stored up instead of flat, person just picked it up and installed it. All the developer was sitting at one end so the motor could not turn correctly. NEVER EVER STORE I/U UP always Flat!!!. Open & close front door to reset. If it comes back then you might have already burn out the motor, worse case the Control board went bad.
Oct 08, 2013 | Minolta C350 Printer
MINOLTA C350 ERROR CODE C0200
Cyan image unit replace it. Reset code by opening and closing the front door. Also try reseating it.
Jan 15, 2013 | Minolta C350 Color Printer/Scanner/Copier
Ko0nica minolta c350 blad c0016
Pull out the black image unit shake the image unit side to side you are going to try to spread the developer and toner inside the image unit along the entire length of the image unit, I bet the image unit was stored standing up and the person just plug it in with all the developer sitting at one end the motor that turns the drum had a hell of time trying to turn always store image units laying down always before placing them inside the machine shake the image unit to spread the developer along the image unit, if this does not work get a new image unit or the motor is burned out worse case control board for the motor is bad$$$$$$$$$$$$$$. Open close front door to reset
Jul 26, 2012 | Minolta C350 Color Printer/Scanner/Copier
How to reset image unit for C350 bizhub?
well there is a chip on the image unit that image unit (all colors) you need special chip writer to reset. you may need to just buy a new unit or drop me a line i may be able to get one...
Oct 27, 2011 | Konica Minolta bizhub C351 All-In-One...
C-0202
C0202 on a Bizhub C350 means you have a Magenta PC Drum Charge Corona malfunction.
The charge corona is contained in the Magenta Imaging Unit. There are cleaning rods on each Imaging Unit. I would try pulling out the rods and cleaning the wires that way. Concentrate obviously on the Magenta unit. Run it in and out several times. Turn off the MAIN power switch (NOT the one up on the control panel) then back on to reset the code and see if it goes away. If not you may have to have your service company clean the Imaging Unit or it may have to be replaced depending on how bad it is.
Good Luck and Thank You for using Fixya.
Sep 19, 2010 | Minolta C350 Color Printer/Scanner/Copier
I install new imaging unit cyan and magenta but c350 machine shows still change imaging unit error. how to fix this error.
Did you turn the main power switch OFF then back ON? You need to do that to reset the counter. Also, did you put a brand new one in from a closed box or a used one? If it is a new one & it will not clear, return it to where you got it from... Good Luck
May 22, 2010 | Minolta C350 Color Printer/Scanner/Copier
My Bizhub C350 has locked due a imaging problem. There are solution without change the imaging unit?
once the machine locks you out for a imaeg unit you are done until the unit is replaced or reset chip is installed but there is new firmware that can be installed in the machine that wil not stop the machine from usage was the image unit has reached end of life so the next time a service tech comes out tell them you want the new firmwareand set image unit life to suspend
Dec 06, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
830 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
