What ideal temperature should be processor - Computers & Internet
  • 355 Answers
-70--/--75--75--75--75-- Hot
--65--/--70--70--70--70-- Warm
--60--/--65--65--65--65-- Safe
--25--/--30--30--30--30-- Cool ..."
Posted on May 15, 2009
What is the ideal refrigerator temp setting on a smeg sr650xa
It is the same for any fridge. I am a trade chef and catering manager :>)
The ideal refrigerator temperature is 35° F (1.6° C). You're not hugging the danger zone like you would be at 40° F (4.4° C), and you're distancing yourself sufficiently from 32° F (0° C) that you don't freeze half the stuff in your refrigerator.Jun 21, 2013
What Temperature Should You Keep Your Refrigerator Set At?
https://lifehacker.com/what-temperature-should-you-keep-your-refrigerator-set-533534...
what is the ideal refrigerator temp Google Search
Sep 26, 2017 | Smeg Refrigerators
Tip
How can test Laptop?s temperature and temperature should it be at?
<p><span>If your laptop is not working ideally it may be the cause of temperature. But most laptops naturally run hot, so a system utility that can access your laptop's internal temperature sensors can help you decide if you need to take some steps to keep your laptop cool down.</span><br /> <p><span><span> </span></span><br /> <p><span>Most CPU's maximum temperatures are around 100 degree Celsius. But you can look up temperature specifications for your specific laptop's Intel or AMD processor. Optimal operating temperature is 50 degree Celsius or below.</span><br /> <p><span> </span><br /> <p><span>Some programs will help you to test your Laptop's CPU Temperature that can show you the CPU temperature as well as other system details such as processor load, voltage, and more. And some of them can also automatically adjust the speed of your laptop's fan for better performance.</span><br /> <p><span> </span><br /> <p><b><span>Speed Fan</span></b><span>- In the case of monitoring fan speeds, voltage, and processor temperatures using your laptop's internal sensors, Speed Fan can also access S.M.A.R.T. information to set your hard disk's temperatures.</span><br /> <p><span><span> </span></span><br /> <p><b><span>Real Temp-</span></b><span> The real temp is specially designed to monitor temperature for all Intel single, dual, and core processors. In the case to showing the temperature and load the processor, it also shows the CPU's safe maximum operating temperature and how far from this maximum temperature your processor is running at. Another most important feature of Real Temp is tracking of your highest and lowest temperatures since you opened the program.</span><br /> <p><span> </span><br /> <p><span>These tips may help you to determine the exact temperature for your laptop. </span><br />
on Dec 24, 2010 | Computers & Internet
Fridge not cold enough
The higher the number the colder the temp is supposed to be.
In order to prevent the formation of bacteria and other such organisms to affect food the way it does, the ideal temperature range of refrigerators has been mentioned here. Before we look at these settings, it is important to know the format in which temperatures are represented within a refrigerator. Commonly, you will notice a dial representing the figures 1-5 or 1-9 in the refrigerator, and a dial representing the letters A-E in the freezer. The ideal setting is usually in the middle of such figures.
If the dial is in such a format in your refrigerator, try a setting at 3 if the range is 1-5, and at 4 if the range is 1-9. For the freezer, a setting at C is suitable.
The ideal temperature in the refrigerator ranges between 34 degrees F - 38 degrees F or 1 degrees C - 3 degrees C. So that foods such as vegetables and fruits remain fresh and crisp, the temperature may be set around 38 degrees F or 3 degrees C.
The ideal temperature in the freezer ranges around 0 degrees F (-18 degrees C) or lower.
Read more at Buzzle: http://www.buzzle.com/articles/refrigerator-temperature-settings.html
Mar 05, 2014 | Belling Refrigerators
Temperature of thermo defrost samsung
The ideal temperature in the refrigerator ranges between 34 - 38 degrees F or 1 - 3 degrees C. So that foods such as vegetables and fruits remain fresh and crisp, the temperature may be set around 38 degrees F or 3 degrress C.
The ideal temperature in the freezer ranges around 0 degrees F (-18 degrees C) or lower. See more at:
Mar 01, 2014 | Refrigerators
What would cause my aspire 5630 to shut down sporadically?
Shut down sporadically, caused by rising temperatures on the processor (processor overheat). Processor overheat, caused by damage to the processor fan. Processor fan function to reduce the processor temperature.
Possibilities and solutions
1. The possibility of sluggish processor fan. Processor fan spins, with a low speed, so it can not reduce the processor temperature.
Solution: clean the processor fan with a vacuum cleaner, or replace the processor fan.
2. The possibility of fan processor die.
Solution: replace the processor fan.
The characteristics of damage to the processor fan
After the laptop is turned off (more than 1 hour), the laptop can turn on and survive + - 30 minutes. In the period of + - 30 minutes, the laptop died suddenly, because the processor temperature exceeds safe limits (shut down temperature).
How to check
Laptop is turned off (more than 1 hour), then turn on. Download and install software to check the processor temperature. Ex. Real Temp 3.60. See the change in temperature. If the temperature continues to rise, it can certainly cause damage to the processor fan.
- Normal temperature, when first turned on + - 38oC
- Normal temperature, after turn on for hours 40oC - 45oC
- Temperature overheat processor, when first turned on 60oC - 65oC
Nov 18, 2011 | Acer Computers & Internet
Rise in the Temparature & Processor Fan's Speed
Games and graphics place a huge demand on the RAM (memory) and processor. It is for this reason that gamers buy expensive video cards with huge amounts of RAM inbuilt into the card (The cards are almost computers in their own right).
Your processor has to deal with a lot of information when you watch dvds or play games .. it works damn hard ... hence the heat .
Your best option is to fit an additional cooling fan (computer shops have them in stock). Try removing the side of the computer casing to allow more air to circulate. Die-hard gaming enthusiasts add all sorts of extras to their computers .. water tubes to circulate water .... that sort of thing.
Your processor will become hot .. that happens in all computers. It's EXCESS heat you want to avoid. As a general rule of thumb, a processor's ideal temperature is 40 degrees C, though they do go beyond this temperature at times, without adverse effect.
May 18, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Troubleshooting
No, that's definately not the problem. The airflow seems to be adequate and the temp reading is effecient enough. Ideally, te the idle temperature of any AMD processor should not exceed 30 deg celcius. Look in the bios and make sure your speed is set for clocking to match the ram. Other than that, instead of hardware, I'd look into software config. IE, spyware/adware, Viruses. Beyond that, I will need system specifics in order to help further.
Mar 16, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Problem after installing catalyst 7.10 drivers
The CPU should be kept under 55C.
The heating you mention is completely normal. An active processor generates more heat. Thus with the CPU usage issue you mentioned, the processor works harder and produces more heat. The heat levels you report are still very normal.
You don't state your video card, but if you are having problems with the 7.10 drivers, try older or newer ones. Also make sure you have the correct/latest motherboard drivers installed.
Finally (unrelated to posted problem), keep an eye on that PSU. If you have a power hungry video card, it maybe too much for it to handle.
Dec 05, 2007 | ASUS M2A-VM (0610839149438) Motherboard
Intel p4 3.0ghz with 800fsb fan makes more noice
Hello Prask, Cooling the Intel's LGA775 CPU presents quite a challenge due to it's high operating temperatures, and while the ideal solution would be to use water, not all of us are ready to make the jump. The best solution I found for an easy replacement of the stock cooler is nMEDIAPC ICECONE Pure Copper CPU Cooler. It is an easier install than Thermaltake, and is just as quiet. You can find it here for the best price: http://www.directron.com/icecone.html Let us know if you need any additional assistance. Best regards, nightdiver
Aug 16, 2006 | Intel Pentium 4 630, 3.0 GHz...
Computers & Internet Logo
551 people viewed this question
David Payne
David Payne
