Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Maintenence Hi i would like to know if i should clean the bulb in my tv or do somekind of maintenence so it would last longer or maybe just call someone certified the come and do a quik tune up??? my tv work great!!
  • srevan Jan 07, 2008
    recently I noticed my tv is getting dull. Does not have same brighteness.
    Any has any solution?
    Problem Solver:
  • 11 Answers
No.
Posted on Dec 13, 2007
I have a Mitsubishi 60inch 60737 replaced the bulb last month.now it keeps cutting off,cleaned the filter before.someone said to reset bulb timer,how do I reset it.
The Lamp timer will not cause it to shut down. The timer should have been reset when you first turned the TV on after replacing the bulb. Make sure your bulb is an Osram brand bulb. If not, then you do not want to use it as it may not be very good.
May 27, 2015 | Mitsubishi Televison & Video
How do I know if I need a new lamp?
Yes, if you have not replaced the lamp since you purchased this TV.
Lamps usually last about 6000 hours.
I've seen lamps last much longer than 6000Hrs, it all depends on the usage.
Remove the lamp from the TV and do a visual inspection, see if there's a crack on the glass or the bulb.
If the TV is few years old then the Lamp may be bad.
Buy original Lamp: 800 638-3328
https://www.encompassparts.com/
DO NOT BUY the cheap lamp from ebay
Good luck to you.
Nour Sabre
www.tvservice.com
May 24, 2012 | Sony Grand WEGA KF60WE610 60" Rear...
No yellow colour
If the yellow cartridge is full then you may have blocked yellow printhead nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new printhead is required.
A new printhead maybe expensive and it maybe more cost effective to purchase a new printer.
May 02, 2012 | Office Equipment & Supplies
Where can I find a Ballast for HP ID5220 DLP TV?
It looks as if you have to return it personally, and have them fix it. I saw nothing on the HP ID5220 DLP TV in the ballast lists. Sorry, man. Wish I could be of more help. Maybe someone else has a better site, or connections, that can help you. Your best bet is to get professional help with someone, like the company that manufactures the hardware.
Mar 13, 2011 | HP Televison & Video
My projector is a Marantz VP4001 and it is really hard on bulbs first bulb lasted 1500H send bulb maybe 600H third one 20H Not sure if I should buy any more bulbs or a new projector
I'd buy a new projector - notice how the bulbs life has decreased significantly each time you replace it. This is how they've designed these things - it's a "consumer" product. The ink cartridges for printers is the same method - they're designed to consume your money. I recommend getting a Hitachi brand projector. I used to work for them as an engineer and I know they make them last longer.
Dec 15, 2010 | Marantz VP4001 DLP Projector
How long do bulbs generally last?
Generally, a DLP bulb lasts about 8,000 hours (if a TV is on 10 hours a day, every day, the bulb will last about two years). A bulb can last longer if it's used less frequently. Typically, a bulb in a DLP TV for household use should last at least three to four years before it starts to flicker and needs to be replaced.
Thanks!
Tim
Oct 02, 2010 | Samsung HL-67A510 67" DLP HDTV
My jvc model #hd-61z456 is working at too dark of a picture. I have replaced the light bulb twice and have reset the picture setting to factory setting and I don't know what else to do can you help me....
Both times bulbs was replaced it lasted 1 1/2 or 2 years right?Use tv on like 4 or 5 hours a day?That the avervage life span of a projection bulb.Try to buy an original JVC pojection bulb last little longer.
Sep 12, 2010 | JVC HD-61Z456 Television
Bulb went out
This maybe a McGuyver thing. Last thing you want to do is block the air flow to cool down your TV set. I would blow out all the dust, get a HEPA filter for house ventilation, get a computer cooling fan. Cut and put the filter in front of the fan, make the fan blow in to the TV vent in the back, that way it blows clean air in and keeps dirty air out. I hope that's one good idea.
Jan 24, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Mishubishi ws-65819
Very common problem Its the convergence IC's in the set and are not cumseumer replaceable unless you know your way around the inside of a tv set. Theres way to much Hi voltage inside these sets tp tinker around with them . This repair should only be done by a qualified technician, as it probably will need a good alighnment after the ICs are replaced . Should cost about 3 to 4 hundred bucks to have fixed. Good Luck
Jun 14, 2006 | Mitsubishi WS-55807 TV
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
