110.82980 top load washer (kenmore) agitates when it should spin. In the spin cycle the machine agitates, the drum rotates slowly wrapping the clothes around the agitator, the pump works OK.
  • 4 more comments
  • dstrns May 15, 2009
    We bought the machine new in 1990 and it has never been worked on by anyone.
    Thanks jumptrout51. Is it not worth the trouble to take it apart and replace the shift actuator.
    Thanks again jump. I will replace the transmission.
  • Michael Masters
    Michael Masters May 11, 2010
    There are a couple of numbers missing form the model number you posted along with your original post above. i will need the complete model number so that i may give you a accurate diagnosis.
  • Michael Masters
    Ok, can you give me your model number so that i may direct you to the correct part and make sure of the direct drive build please?
  • Michael Masters
    has this unit been rebuilt or bought used?
  • Washing Mach... Master
  • 3,361 Answers
The shift actuator in the gearcase is bad.
Replace the transmission.
Posted on May 15, 2009
  • steve
    steve May 15, 2009
    It is much easier to replace the entire gearcase unless you are just curious or ambitious. About $110.00 for the complete transmission with all new gears.
    Replacing individual gears requires a tech sheet for alignment and timing,etc. If anything is not done exactly correct you have to tear it down again.
    They currently make only one transmission for the top load direct drive washer.
Frigidaire topload washer inner drum not rotates during wash cycle
inner drum is not supposed to rotate . just the agitator .spin cycle is when that will rotate
Sep 28, 2016 | Frigidaire Washing Machines
My clothes doesn't get agitated in the wash or rinse cycle. I don' t see how it can get my clothes clean this way
Need more info, what kind of washing machine do you have? I am going to assume you have a front load washer. There is no agitater, instead the drum rotates, as the drum rotates the cloths roll up the side of the drum. When they are almost to the top of the drum they fall and the weight of the cloths themselves provides the agitating action. I have been using a front load washer for years, wouldent think of using a top load. Hope this helps..
Oct 08, 2015 | Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Washer is not rotating fully during wash cycle
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Some Kenmore washers have a two piece agitator. The lower section will rotate back and forth both ways.
The top section has "agitate Dogs" that allow it to rotate only one way (to keep the clothes moving downward.
If yours has a two piece agitator there shouldn't be a problem.
Oct 18, 2009 | Kenmore 24032\24036 Top Load Washer
Doesn't agitate and spin cycle work when reset
you have a worn motor coupler
you can order a new one at sears
and its a ver y easy repair
Oct 06, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer washes and wont spin clothes in either the wash or rinse cycle
If you have little to no agitation (as well as spin), look for a broken motor coupling (connects motor to transmission).
If the motor coupling is ok, open the lid and select a spin cycle, insert a flat screwdriver or pen into the lid switch and try pushing the drum along in a clockwise direction. If it doesn't spin or spins slowly then the brake/clutch assembly is slipping and will need to be replaced.
Feb 25, 2009 | Kenmore 24032\24036 Top Load Washer
Series 70 prob: Recently started wrapping clothes around agitator
some fabrics are known to do that you have on wrong cycle setting there should be a setting for delicates and clothing and blankets and things when loaded to close to agitator will attract each other together so its wise when loading machine load in a circle leveled out till desired fullness away from agitator they shouldnt attract as much
Nov 19, 2006 | Kenmore 24902 Top Load Washer
Washing Machines Logo
247 people viewed this question
Top Washing Machines Experts
