Question about Brother MFC 6800 All-In-One Laser Printer
I have replaced the drum and toner in my brother MFC 6800 and now it will not grab the paper from the paper feed. Is there a way to fix this?
Same problem let me know if you figured it out
Posted on Sep 09, 2010
My Brother MFC-9840CDW keeps jamming every time I print mailing labels. I've had it four 1.5 years with no trouble. The label gets stuck and I have to pull out the toner tray to fetch it. I also...
hello, sounds like there are many possible solutions for you machine, first with paper jamming, are labels going thru manual feed tray, or paper tray, it might be possible that mp feed roller needs cleaning or replacing. if paper tray, simple would be feed roller, clean or replace, if jams continue with normal paper from paper tray, the problem will be front door, i have yet to be able to repair paper jams when front door assembly fails. as far as colors, both drum and toner can cause this problem, if using 3rd party toner, this will also cause some color problems. sorry no real quick fix for this machine, i've tried.
Sep 24, 2010 | Brother MFC-9840CDW Laser Printer
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
Brother MFC 7420. New Brother Toner, New Drum, cleaned feed and separator rollers, changed paper, still jamming. Paper stuck around brown fuser roller. What can I do next?
Check whether the fuser rollers are free turning. If the paper is stopped at the ejection roller, the ejection roller needs to be replaced.
Dec 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-6800 - Mysterious Vertical Lines
This unit has a brom tube unit and need to be replacement . By repair tec.
Oct 05, 2009 | Brother Multi-Function Center MFC-240C...
Screen says drum near end
Drum for Brother MFC-6800 All in One Machine
You can expect it to print 12,000 Page Yield
Whats the difference between a DRUM and a TONER Cartridge? The toner cartridge is a cartridge holding the toner (ink). The drum does the work to transfer the ink to the paper. You will need to replace the drum every 5-6 toner cartridges you use.
Sep 24, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC 6800 printing blank pages after fuser, toner, and drum was changed
hi
i have the same problem after replace the fuser
the problem is in the little board ,where all the connectors are on
the , 7812a , a positive voltage regulator ,was loose ,
only resoldering and ok..!
excuse my english, i write from el salvador , im really never speak english, but i just try to help
reggards..!
carlos c.
Apr 07, 2008 | Brother MFC 6800 All-In-One Laser Printer
Brother MFC 7420 Paper Jam. Paper will feed from tray to Toner/Drum then Jam. Feeds only about 4 inches of the sheet then Jams. I have replaced the toner/drum unit. Any help is appreciated. Thanks.
After changing the drum, toner and running around town for days trying to find a reliable place to get this printer repaired, I realized I was spending a lot more money than what the printer actually costs. the drum was over $100, toner was $80, and the printer is $250. I bought a new one, and I can now use the old one for parts.
Nov 13, 2007 | Brother MFC 7420 All-In-One Laser Printer
Replaced both toner and drum- prints too light
remove drom and toner, in base of machine is a glass slit, clean it.
Oct 14, 2007 | Brother MFC 6800 All-In-One Laser Printer
Brother MFC 6800 All-In-One Laser Printer Logo
90 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
