Question about D-Link DP-301U (790069251979) Print Server
DP-3001 has 2 ip addresses .10 and .73.  You can change .10, but .73 still stay.  Problem is .73 is assigned to SQL on my net.Any ideas?
Dp-301u gets 2 ip addresses...on its own!!!
Posted on Mar 22, 2008
Change ip address
The IP address is configured through your DHCP server in your router. You're going to have to either look in your router for connected devices or use a tool like netscan.exe (free) to find the assigned IPs in your network, If you don't have too many connected devices, you can keep putting the IPs that are there into your web browser until the device page comes up. They SHOULD HAVE put a reset button on this thing, but they didn't.
Aug 17, 2013 | D-Link DP 301P (DP-301P) Print Server
Cable and ip address
A regular Cat5 ethernet cable will work just fine to connect it to the network. For an IP address there will be a networking option in the menu for the unit which will allow you to assign a static IP address to it. Just make sure that your router is set up to not hand out that IP address.
Good Luck!
Oct 30, 2009 | Panasonic Workio DP-1820E Copier
DP-300 Print Server Access Problem
Using a print server like this, you should not need to "browse" to find the printers. See what ip address has been assigned to the printer. Once you have the ip address, open a command prompt (start -> run -> cmd) and type:
ping <insert ip address>
ex: ping 192.168.0.24
See if you can ping the printer from each of your computers. If you can, great, install the new printer by adding a "local" printer at a new TCP/IP port with the IP address of your printer. If not, then you may have some routing issues.
Are all of the printers connected to the same switch? Do you have multiple "routers" on your network acting as DHCP servers?
Hope this helps.
May 27, 2009 | D-Link DP 300 (DP-300) Print Server
Nortel NetDirect error on Vista
Hi kt_rutherfor, Firstly apologies for my late reply. I thought that this was going to be a firewall problem, but looking at your error again, I now dont think that. So I'm afraid that I dont know the answer to this, I do have an idea, after researching the problem that this is a Remote-NDIS host problem. Your Uni should be able to help you with this even if it isn't at there end.
Again sorry for not being able to help
Apr 07, 2009 | ASUS T3200 Notebook
Need IP address of Workio dp-2330
"share" it on your server, then on each PC go to "add printer", select "network Printer", browse your network, and select the printer.
Mar 20, 2009 | Panasonic Workio DP-2330 Printer
Setting up my D-Link DP-301P+ print server
Print servers are typically controlled through a web interface, and do not need specific drivers. You can download the manual and installation guides here. You may need to change the default IP address; look at the section on Networking Basics in the manual.
Jan 11, 2009 | D-Link DP-301P+ Fast Ethernet Print Server...
Setting up IP address on server
Download and install <a href="http://www.wireshark.org/download.html">Wireshark</a>.
After installing, click the first button on the toolbar to list available capture devices. Select the interface you use to connect to your network (wired or wireless card) by clicking the "Start" button next to it.
Power off and back on the print server. Watch the log on Wireshark, and look for the D-Link identifier under the "Source" tab. In the same row, it will tell you the IP address the print server has assigned to it. You can then change your computer's IP to be in the same subnet (match the xxx's in the address xxx.xxx.xxx.yyy), allowing you to connect to it.
Oct 30, 2008 | D-Link DP 301U (DP-301U) Print Server
DP 301U and Lexmark 2550 (all-in-one)
1. Set up your print server with an IP address.
2. Ping your printer IP address.
3. If successful, Add printer wizard. Create a new port, Make it TCP/IP port. Put the IP address in the IP address field. Click next and Use Generic 9XXX Raw.
4. Install the driver provided by the manufacturer for your printer and assign it to the Network port.
5. Print.
Hope this helps.
Jun 03, 2008 | D-Link DP 301U (DP-301U) Print Server
IP Assignment....
No, a tranceiver cannot be assigned an IP address. It just converts the signal between two types of lines (fiber, copper, etc.). This is mainly used for connecting together networking equipments such as switches or routers.
Depending on the type of interface you plotter have, you may need a device called a Print Server. This device has an IP address and allows a conventional printer signal to travel through an IP network. If your plotter is designed to be connected using a LPT (Parallel) cable, like old printers, you may look for the D-Link DP-301P+ or DP-300U.
Feb 12, 2008 | D-Link DE 853 (DE-853) Transceiver
DP-303
Perhaps the XP firewall software is preventing PS Admin from connecting to the print server?
Jan 16, 2008 | D-Link DP 303 (DP-303) Print Server
D-Link DP-301U (790069251979) Print Server Logo
256 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
