Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
To whom it may concern, I have a 42" Deck Craftsman Lawn Mower which I bought 10 years ago. Last year, when ever I going over tall grass, excessive smoke came out of the exhaust. I kept loosing oil. At time, the engine looked like it is about to be on fire. After some research and questions from friends, I realized that it is time to change piston rings. Last week, I took the engine apart to replace the rings and put the engine back according to how I took it apart. I was very proud of my self since I never work on engine to this extend before. Yesterday, I was looking forward to starting it, however, it did not turn over at all. Battery power was there. I hooked it to a running car for power, with the battery on the tractor of course. All I heard was a single click from the starter. The fly wheel did not turn even I tried to turn it with a metal bar and a wrench. A friend told me that when putting the engine back, I must have missed the "Top Dead Center?", therefore, the engine will not crank. Would you kindly point me to the right direction if I take it apart again and put it back properly. Is there a mark somewhere I should follow in side the engine crank shaft, crank case, etc.. Is there an instruction I can purchase for someone who know very about engine but willing to work on it due to my interested in fixing and learning. Thank you for your assistant! Tri
    Sniper:
  • 57 Answers
Recommend going to auto parts store and getting a small engine repair manual. Or, if time is not an issue, most repair manuals can be ordered online. Try M & D Mowers. Very inexpensive.
Posted on May 15, 2009
Toro 24038 blade speed governor not working
Not enough torque. Only use 1/2 width of deck on tall grass, go real slow, Ensure side discharge is open! Ensure blade is sharp. Replace spark plug once a year and clean replace air filter. check oil level 30woil.
Aug 10, 2012 | Toro Power Lawn Mower
Need a troubleshooting manual for a craftsman mod. 917.287070
Went out to cut grass and the blades will not engage and when I put it in gear it does not move. Belts are intact. I cleaned the deck of dirt and grass. Still nothing. Just replaced the cable to engage the blades last year. Cable seems to be working.
Jun 25, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My craftsman 18.0 42" lawn
First check to make sure you can turn each blade by hand, with the mower off. If neither blade spindle is frozen remove the deck and make sure all the pulleys move freely and function like they should. The cable should have been operating a spring loaded pulley arm that applied tension to the deck belt to make the blades function. Some times build up with block that from moving or rust will make it stick.
May 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman gt 5000 model 917.276220 runs fine but when mowing deck is engaged it wants to die when under a load or cutting tall grass, it will stay running but when i start to cut it bogs down?
not possitive, but sounds like 1 of the bearings on the mower deck is starting to seaze up.I would start with that. Remove the deck and belts and check all the pullys and bearings for free movement.
Mar 08, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
The mower just stopped dead.
clean and tighten all connections from the battery to the starter and selenoid connections too
Jun 03, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riding mower noise when blades engaged
With blades on and engine off reach under and wiggle each blade up and down. If you have excess play you will need bearings.
Aug 12, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
May 17, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
296 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
