Question about Kenmore 84052 Dryer
Stopped working Dryer will be working, but then will stop (usually before completing the cycle). When I try to start it again, it will not start. I have run it through the Function Test Sequence and do not have any problems. I have run it in to the mode for reading fault codes and no fault codes come up.
  • HomeGrom Nov 15, 2007
    I'm having the same problem. The dryer will come on for a few minutes, stop and all the lights will blink. No phone tech support!! Sears was just here yesterday (and two weeks ago!) for problems with the washer=$470 in repairs. This is insane!
  • 94 Answers
It might be overheating.  Make sure your dryer vent is clear.
Posted on Oct 17, 2007
Kenmore dryer stopped working, still has power.
When the timer stops during the duration of the time set the timers cogged tooth gearing has stripped out. A new timer will be needed to get your dryer working again
Apr 07, 2010 | Dryers
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Dryers stopped working during cycle
My dryer stopped working during a cycle last night and won't start again. The light is no longer coming on either. The first thing I checked was the circuit breaker which was fine. Can anyone tell me other possibilities? What is the anser
Jul 17, 2009 | Magic Chef CYE4000AWW Electric Dryer
Crosley Electric dryer stopped in mid cycle and will not start
if the machine is completly dead an not doing anything locate your fuse panel ,check your fuses for the dryer ,if you can find wich one is it reset the breakers again you probably popped one of the 2 lines since you need 2 for a 220v.
good luck!
May 26, 2009 | Crosley CDE6000 Electric Dryer
It stopped warning, and wouldn't start again.
Unplug your dryer for ten min. This will reset the circuit board and reboot the system. Sometime small power surges can disrupt the curcuit and cause the unit to get confused. Rebooting usually will fix this type of problem with surges.
Apr 29, 2009 | Dryers
Dryer stopped working mid-cycle.
I presume she pushed the start button again. Can you hear the motor running? If so, it's a broken belt. The door switch can fail anytime. If the dryer started ok later, the motor was overheated. Lighter loads will avoid a lot of problems, and the dryer will probably work better.
Apr 21, 2009 | Dryers
Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Nov 11, 2008 | Kenmore 63942 Dryer
Stopped running in middle of cycle
hi thanks for the question when your dryer stopped and you tried to restart if no noise the over load thermostat embedded in motor is suppose to open and not allow it to start then the motor cools down now it works till the motor over heats again and shuts off again. i would vacuum out the inside clean motor and check the venting right to the outside and try it again but remember do this with power off thanks the appliance doc
Aug 31, 2008 | Whirlpool LER5636P Electric Dryer
Sometimed error being displayed but also not completing cycles and not performing a fast spin
Hi there, I've also had this problem a few times. I've found cleaning out the filter can help solve the problem of the E20 message. Also when it doesn't spin fast it usually means the load is uneven. I found it happens with towels or bedcovers, heavier loads, if the load is uneven it will spin slowly for a good few minutes and then just stop with the clothes still dripping. I found rearranging the load more evenly usually sorts it out. I've had my machine for 18months now and usually love it. It washes and dries well, however, my dryer has stopped working again! I'd only had the machine 7 months when the dryer first stopped working another 11 months down the line and it's not working again! Hope this helps. Lelly2003
Oct 27, 2006 | Zanussi WJD1667W Front Load Washer / Dryer
Kenmore 84052 Dryer Logo
75 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
