Question about Toshiba e-Studio163 Copier
Memory upgrade A memory upgrade board came with our copier but no instructions regarding how to install. Can anyone advise how to install the memory.Tom
  • Tneis Oct 23, 2007
    Thank you Soulvisitor.  You gave me enough information to find a home for the memory board.  I removed one screw holding an unmarked 4X4 access cover on the back near the location of the USB connector and spotted the mating connector for the memory board. I kept myself grounded to the chassis and plugged the board in along with a little plastic retainer supplied to hold the board in place. I made no further PC adjustments and the printer function was faster and seemed to work fine as is.  Thanks for the help with this Toshiba e-studio 163 copier. Tom
  • Toshiba Master
  • 1,113 Answers
I think these machine have a GDI Printer Board and the mem stick will go in that, now that jibberish means, that somewhere usally external rear or sides there is a board that is slotted into the machine, this thing will have 2 turnable long finger screws about 7cm apart attached to a rectangle face with gdi or expansion board written on it
 Power off/undue screws remove board, insert memory module etc
Check driver on pc is GDI for copier and that it also has correct extra memory options selected
Hope this helps I'm not sure on the model but that how most of em r
Posted on Oct 16, 2007
Upgrade memory
You can grab the instruction manual here:
http://h10032.www1.hp.com/ctg/Manual/c00224567.pdf
The memory installation process is on page 191.
Feb 21, 2014 | HP LaserJet 2420dn Printer
IR 1600 printing problem
These are the features u need for the connectivity of your printer.........
Parallel ( IEEE1284)
USB
10 Base-T, 100 Base-TX (RJ45)
Full Duplex/Half Duplex
CPU - 200MHz RISC Processor
RAM - Std, 8MByte (upgradeable with 32MByte DIMMs to max 72MByte)
Storage - Optional 10GByte Hard Disk
Is your printer satisfying all these options?
Or
Reason is different IC ROM (IC4,IC5 on control board).
You can reprogram for this IC.
All the best
Oct 03, 2007 | Canon ImageRunner 1600 Copier
How to upgrade Sharp AR 5516 copier Memory?
Hi.
You cannot upgrade the memory on the copier as the memory is in-built into the system thus giving you no chance of upgrading.
Regards.
Feb 04, 2013 | Computers & Internet
1. Has anyone installed 2Gb RAM memory in a Sony PCG-TR3A? please give details of memory specification. 2. Has anyone installed a HDD bigger than 40GB? please give me details of HDD specification.
You can only upgrade the memory to 1GB in that model Vaio laptop.
The memory supported is DDR SDRAM which runs at 333MHz. There are 2 memory slots which support 1x512 module in each slot.
I recommend Kingston RAM as the manufacturer.
As for the HDD the laptop supports EIDE (IDE/ATA) hard drive. you can have anything up to 320GB. Seagate are excellent drives as well as Fujitsu.
Regards.
Sep 29, 2009 | Sony PCG-TR3A Notebook
What are the exact instructions for upgrading my
Crucial has a very good guide:
http://www.crucial.com/install/dimm.aspx
And they also have a auto system checker that will detect current ram Spec's and show you whats available .
http://www.crucial.com/systemscanner/index.aspx
Jun 09, 2009 | E-Machines eMachines Desktop PC
Manual for RAM upgrade
Memory Upgrade for Dell Color Laser Printer 3100cn Printers, the Dell Color Laser Printer 3100cn Printers takes the PC133 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Dell Color Laser Printer 3100cn Printers to up to a maximum of 576 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed.
http://www.memorystock.com/memory/DellColorLaserPrinter3100cn.html
You should be able to get crucial or the likes to send you the correct memory - as for where it goes that will be in the manual
May 25, 2009 | Dell 3100cn Laser Printer
Please advise how to install additional memory into a Toshiba Tecra A3. Is it something a layman can do or must it be taken to a computer store. Many thanks
Generally it is very simple. You need to find where the upgradable memory slot (s) are. This is generally under a panel on the base of the laptop. Unscrew the panel and, all being it's the correct panel, you will see the memory. There is normally a clip on either side, push these back and slide memory out. Replace with a bigger memory. There may even be an empty memory slot.
Only two things to watch out for, one is that your computer can take the memory upgrade (check Toshiba website) and secondly that you buy the correct memory (pins have to be in same place).
Well within the grasp of anyone that can use a screwdriver.
Feedback is always appreciated.
May 02, 2009 | Toshiba Tecra A3 Notebook
Ram change on Packard Bell easyone 2120
Memory Upgrade Instructions
128 MB SDRAM on-board, max. 256 MB upgrade (384 MB total), PC-133
Remove the memory module according to these steps:
1. Turn off system power.
2. Remove the battery and disconnect the AC-adapter.
3. Open the top cover.
4. Press the locking latch downward to unlatch the Easy Start panel.
5. Then push it leftward and lift it up from the left side.
6. Slightly lift up the keyboard and disconnect the cable from the system board to free the keyboard.
7. Pull the retaining clips outwards (1) and remove the SO-DIMM module.
Keith Stoffer
Comptia A+ Certified Technician (20+ years)
Oct 30, 2008 | Packard Bell Easy One Silver 2120 Notebook
Cannon Laser Class 8500- Memory Upgrade problems
How can i get information from the memory beginning in 2005
Jan 22, 2008 | Canon Laser Class 8500 Printer
Need help with Jornada 680 Memory Upgrade Installation
http://home.freeuk.com/gogmagog/installation_guides/6xx/installation_guide_memory_680_680e_690_690e.html
Sep 12, 2005 | HP Jornada 680 Pocket PC
Toshiba e-Studio163 Copier Logo
51 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
