Question about Brother MFC 7420 All-In-One Laser Printer
Software Installation Unsuccessful
So, It says that my hardware is installed and ready to go, but my software is not being installed properly. It goes up to 60 percent, and then it keeps trying to install, but no avail. A window pops up that says that installation failed...i don't know why, and it is really frustrating!~ *HELP*
  • Brother Master
  • 1,113 Answers
Unplug usb, delete installed printer driver, install software first wilst mfc is not connect, connect when software (not windows) ask you connect device.
Posted on Oct 17, 2007
I just downloaded the Ableton live 8 preview and no sound is coming out. Can someone help with this?
You must go to the Control Panel - Audio and change the setting to use the new sound card. There is a pull down list for you to select the sound system. Test it with the sounds box at the bottom of the audio window. Make sure the software for the new card is installed. To properly install new hardware you must reboot the computer. Then the Windows main screen will say "New Hardware Found" in the lower right screen. When finished it will tell you the the Installation is Complete or Ready to Use.
If the audio does not come on go to Control Panel / System / Hardware and see if there is a yellow astrek next to the Audio. If so it is not working properly. Click on the Audio to bring up the item. The right click on the sound card title and select "Update Driver". Your computer will search for the new software already installed which is compatible with the sound card and install it. If the astrek goes away your audio should work fine.
If the sound card is not on the audio list, check to make sure that it is properly installed on the motherboard, all the way in with no metal contacts showing above the card holder. Also look for any wires which may have been caught in the slot when you put it in. And finally make sure your audio cable is plugged into the new sound card (and not still in the old location).
Apr 15, 2011 | Computers & Internet
Tip
Hardware installation is different from the installation of software. I will...
Hardware installation is different from the installation of software. I will give you a tips that will help you ever in your life. Always remember that first you should install its software or driver and then attach the hardware or if the software or driver installation require attachment of the device then you should attach the device or hardware with computer during installation. After the installation you should reboot your PC once a time. Kindly, follow my instructions, you will get succeed in installation of any hardware.<br /> <br /> <br /> Good Luck
on Feb 14, 2011 | Computers & Internet
"product installation unsuccessful, please
check to see if fire wall is blocking it.
Feb 02, 2011 | Computers & Internet
Can not install printer software. Goes through installation program and then has "The installation was unsuccessful." Used the Kodak clear utility, reinstalled software, receive the error message. Can't...
You need to remove the software completely to avaoid getting conflicts when installing back the software
Follow the basic steps
1) enable show hidden files and folder
2) delete C:\Documents and Settings\All Users\Application Data\Kodak
3) delete C:\Program Files\Kodak
4) run clear again at www.kodak.com/go/clear
5) reinstall the software at www.kodak.com/go/downloads
Dec 20, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Palm T5 installation disk is damaged. HELP!
HI,
Here is the info you are looking for. There is a whole section of help topics on the palm website. This is the link to download the software.
Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/t5/unlocked/downloads/page_en.html
Oct 25, 2009 | Palm Tungsten T5 Handheld
Brother DCP165c Driver installation Problem
I would boot in safemode (hold down f8 immediately when it starts (when it says Starting Windows xp), then delete all printers (associated with this) in device manager.
remove any printer software as well (add remove programs or start programs (printer program name, remove software IF listed),
also remove the port you are using in device manager be it lpt or usb. if the drivers siuggests installking without it connected do so, otherwise, just restart and it shoudl start installking the hardware amnd software it finds. be sure you have the correct drivers ready as well>
Good Luck
Jul 09, 2009 | Office Equipment & Supplies
Software installation unsuccessful
Normal 0 Try disconnecting the camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jan 17, 2009 | Logitech QuickCam Connect Webcam
Trouble with installing software for PCI FLASH Memory Dell All-in-one
First uninstall the Lexmark and unplug it from your system. Next, do a SHUT DOWN. Turn on your system, load the CD, go through the installation process, then plug in your Lexmark.
Jul 15, 2008 | Lexmark P4350 All-In-One InkJet Printer
J5780 Installation Problem on Windows 2000 PC
hi this is due to improper Software Installation stapes below
  • Un install all printer driver & software u install
  • disconnect printer from computer
  • restart u r computer
  • insert Software cd in to cd rom
  • install software ,follow instruction & fill up Information.
  • when notify you to please connect printer thorgh USB please connected Usb cable to your Printer.
  • printer shuld be ditected then follow instruction
  • complite Installation & cheak it out..
If this information is useful for u please rate me....
Jun 09, 2008 | HP Officejet J5780 All-In-One InkJet...
Brother MFC 7420 All-In-One Laser Printer Logo
136 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
