Question about Plantronics CS-50 Professional Headset
Static in headset
When I use my headset I am now getting a lot of static on the line.
  • 32 Answers
Here is an even simpler solution that works almost 99% of the time, do a system reset:
1. Take the headset off the charging cradle.  Make sure that the headset is not turned on (i.e. the green light on the base is not on) 2. Hold the mute button and the call answer button down at the same time.  (The mute button is the little black wheel on the top of the headset.  Push it straight in with the tip of your finger). 3. Hold these both down until you see the green light on the headset blinking a few times.  After 2 sets of blinks release. 4.  Put the headset back on to the charging cradle, wait 30 seconds, pick it up and try it now.  It should work.
Posted on May 22, 2009
  • 2Christian Jan 27, 2011
    Awesome!!! The best headset EVAH is back in business. Thanks for the solution!
  • 67 Answers
Unfortunately they make the wires very flimsy - you have a short in the wire most likely - replace the wire if you can - if not you need a new headset
Posted on May 15, 2009
How do I get rid of the static sound in my 4PR908?
There causes varies from types of headset to another. In respect of a wireless headset, the static sound is caused by interference. Whereas in a cord headset, a loose wire somewhere in your headset or cord is responsible for the static sound or crackle. It might also emanate from the mic in respect of a one calling, or from the ear-piece.
The solution with a wireless headset is to move away from any device e.g computer which might have cause the static sound. Resetting the wireless headset is also a solution measure.
In the case of a cord headset; Get the cord wiggled at the plug and at the headset; and then move the mic to locate the loose connection. Where the problem occurs, loop the wire, taping it down at the point. soldering the affected wire is best than taping.
Finally, if the static sound persist;which it should not after all the treatments; check on the volume of the device. Reduction of the device volume can go a long way to bringing the longed solution. Similar problem occured with my headset;and was solved via the same recommended possibility.
Jan 30, 2015 | Wireless Gear 4PR908 Bluetooth v2.0 EDR...
How do I eliminate static?
A lot of times when head phones of a head set have static it could mean that dust and/or water have gotten into the ear piece and the sound wave rattle around the gunk. that's about all i know.
Jul 08, 2012 | Televison & Video
Static lines
when you hear static you lines on your cellphone it maybe the time to replace your earpiece, if you don't hear static lines when you use a headset then your earpiece is busted but if you still hear static lines while on your headset it means that something's on your surroundings that interrupts your signal it could mostly be a radio or a metal that could strongly blocks your radio wave. if this is helpful, please vote for me
Jun 27, 2011 | Nokia 3110 Cellular Phone
Hi, I have an issue with my Avaya headset...it has a lot of static. When I put it on mute, I can hear clearly but of course the reps can't hear me. And when I unmute it, there is a bunch of static. The...
Try on another phone. I the headset then works fine the headset port on your phone is bad.
If there is still static on the new phone, the headset is bad....
Dec 29, 2010 | Avaya AWH-55 Professional Headset
We are experiencing a lot of static from the headsets - when the phone is muted the other people on a conference call won't hear the static, but once the mute is off then the static is back. There are at...
Try re-pairing the headset to the Plantronics 500A base unit to make sure that it has a good connection. And of course you also need to be within the 30ft range of the 500A base, and you can typically only use around 6-7 of those units together in the same area. Here is the link for the pairing instructions:
Plantronics Voyager 510S Pairing Instructions
Good luck from Headsets Direct!
Sep 22, 2010 | Plantronics Voyager 500A Deskphone Adapter...
When I am talking to someone on the phone i get a lot of static.
see what TTY mode your phone is in. TTY mode is under call settings or go to voice command and say TTY mode. I keep mine off. This mode is for people who are deaf, and people who are hard of hearing and use hearing aids.
Dec 12, 2009 | Plantronics Discovery 925 Bluetooth...
When I speak it's all static
Get another headset,,,,its ur mic....I should noe,,,i play cs a lot,,,,,I usually go through some headsets,,haha
Jun 14, 2009 | Logitech Stereo 350 Headset
Bluetooth headset static
BOOHOO - The phone needs to be diagnosed to determine the issue so take it to a mobile service center
RLECANDAR - from my experience the JAWBONE is an awful headset most customers that buy then replace them with another headset
May 22, 2008 | Samsung SCH-u740 Cellular Phone
Motorola HS850-
almost all of moto bluetooth headset get this problem. i think H680 is much better that HS850 or H700. i'm using RAZR2 V8 and almost all BT headset have static problem. So i end up with korean's and french's BT headset which have much lower static.
Dec 05, 2007 | Motorola Mobility HS850 Consumer Headset
Plantronics CS-50 Professional Headset Logo
289 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
