Question about Admiral AW22 Top Load Washer
I have a kenmore top loader it will do everything except empty water and spin when it reaches this point nothing happens and there is no sound at all
  • Admiral Master
  • 3,361 Answers
Probably a bad lid switch. Open the control console and use a insulated jumper wire to jump out the lid switch connector and try the spin cycle. If it works, replace the lid switch.
If not, replace the timer.
Posted on May 15, 2009
My kenmore washer don't spin
Probably need more information but guessing its a top loader and the motor is turning but the drum is not spinning but the water is being emptied? If that is the case it is probably a worn out coupling that needs replaced. The pump shaft runs through the gear of the pump body and also through a coupler. The coupler will eventually wear to the point the motor shaft just spins inside the coupler. If it is a front loader there is probably a V belt that is broken or damaged.
Oct 05, 2015 | Kenmore Washing Machines
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
Kenmore 111 stuck mid cycle with water in barrel
Try unplugging it for a hour - see if it clears..
Hope this helps !!
Jul 13, 2009 | Washing Machines
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer quit working
it may be waiting for a faulty heater to kick in. try it on a cold water wash, no heat and see if it continues the full wash. if it does not then it may have a faulty timer.
Mar 16, 2009 | Washing Machines
Washer won't drain.
Sounds like the pump is clogged or stripped out. It's mounted on the front of the motor in the middle of the bottom. There's only 2 clips and hoses that hold it on. These are known for stripping out in the middle. They are just plastic, but fairly easy to fix.
Mar 14, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will wash and drain but not spin
Sounds like the lid switch is not working.It is a safety feature to prevent the washer from spinning if the lid is open.If you look a the lid,you will see a small point that sticks out,The switch is locate under the rim,right where that point would contact with lid closed.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
Does not spin
There is a coupling that connects the motor to the transmission it about a 5 dollar part. Turn the washer on it's side and look at the motor in between you will see the coupling.
Nov 26, 2008 | Kenmore 24032\24036 Top Load Washer
Admiral AW22 Top Load Washer Logo
50 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
