THE CAMERA SAYS THE 2 GB SD CARD BY PNY NEEDS FORMATTING. WILL NOT FORMAT (CARD IS NEW). tRIED ANOTHER NEW SD CARD SAME RESULTS. HOW DO I GET THE CARDS FORMATTED TO USE?
SOURCE: Can't format 8 GB SD memory card
The camera doesn't support this memory card.
Memory card support : SD/MMC up to 2 Gigabyte only.
Sorry you will have to downsize.... :)
If helpful pls. rate me and/or recommend me TXS
SOURCE: camera will not format 4 gig card
I am having the same problem. I phoned a camera store and they said the camera is too to accept a 4GB card may only accept to a 2 Hope this helps
SOURCE: Kodak Z740 camera sd card formatting problem
Remove the card...turn on the camera and go into the menu...find "reset"...follow the on-screen instructions. Then try to format the card again.
SOURCE: Z740 camera repeatedly formating memory card
Hi there , after formate if you face the same problem then, its look like the memory card life is end. He complete his total image serial number. For example:
Life time card capacity is DSC 00000 to DSC49999.
If he reach on end then he does not have any serioul no for further photos. In that case you need to replace the card. Thanks.
