Avoid razor scooters. I bought one at the goodwill thinking what a deal ... After new bats and wiring still no working. I got taken for a ride alright !
Bought a Vespa and it works beautifully. Hondas are great too. Kids ride very summer. All summer same scooters . Razor is a scam.
This Orion TV made by Sansui was bought by me two weeks ago. It didn't last a week. The sound was terrible, picture was great, and it wouldn't hook up to soundbar without hearing a long delay in sound (A/V or Digital output tried two). I contacted their customer support twice, they were awesome. Told me this model has know issues and said to just bring it back. I found another TV for same price ($399) and same size (46) but it's LCD not LED, better picture and great sound! It is Insignia don't remember the model #. Bought at Best Buy (their house brand).
There are any number of commercial protection products available over the counter.. of any auto part store, or online.
In my own humble opinion... Your best protection is regular washing with clean water, and some WD40 on all unpainted surfaces. Any coating you put on will eventually trap moisture and contaminants under it, causing corrosion faster.
Easy way to prevent undercarriage rust is to power wash the entire undercarrage, then spray the entire undercarriage with WD-40 before the onset of winter.
WD-40 displaces water, helping to keep rust under control. Suprisingly, it doesn't come off as easily as you'd think in wet winter driving. Use use two medium size cans of WD-40 to do all undercarriage, making sure to spray every nook and cranny (but avoiding the brake rotors/pads) until it is saturated.
Believe it or not, one good coating will last all winter--at least enough to prevent rust. Each spring, use a high pressure sprayer to clean the undercarriage and reapply a new coat of WD-40 for the spring/summer/fall months.
Your blend door in the Venture is on the driver side of the van, under the dash just above your right knee at the side of your plenum. You will see a white arm that will move to adjust the blend door. The blend door actuator sits on top of the plenum held down with 3 screws. If you did not want to diagnose the problem you could just wire it in place for summer or winter. Personally I would try and diagnose the problem. Hope this helps.
If you can hear sound and the sound coems from your TV, try changing the volume with teh TV remote control. Your TV isn't off it is still on. Just the video board or portion is cutting out. this could be a ton of things, I would try changing out the power strip or plugging the tv into the wall directly to make sure it has enough power. other then that you can try a home brew solution like putting a fan next to your tv to cool the component that seems to be overheating and shutting down your picture.
